I would expect it to be instant. Since the last code change with the new relay rules in it, I think when the rules are saved, all the rules are reset but the default relay logic isn’t applied correctly.
Now I will describe how it actually works (Firmware HysteresisRules, All rules X):
Relay default - OFF → On the corresponding output, logic 1
Relay default - ON → On the corresponding output, logic 0
And all the rules work out in exactly the same style. Logically correct to do the opposite.
Okay, my relay board is happy with the outputs of the PCF chip - it must internally invert as its using an optocoupler to drive the relay.
What external relay board are you using?
I am using standard aliexpress relays or relay via conventional power transistor. They all wait at the input for ON 1 and OFF 0
Right, sounds like we need a simple INVERT option on the configuration screen. Can you raise a feature request on GitHub?
Done #43
Is there a guide/video/document that explains all the parameters that can be set inside the Webinterface and how one can set those parameters correct considering what kind of battery one has ?
I am trying to learn how the diyBMS works so i am testing with a bench power supply to simulate the battery.
@stuart or anyone that can help,
The recommended thermistor on the GitHub page is a
NTC 10 kohm 3950k, B57891M Series.
I have a bunch of NTC 10K 3950 thermistors. MF58 series.
The specs on the data sheet are fairly close to the one that you had listed. I’m assuming I should be okay using them. Just wanted to verify.
And my package from jlcpcb finally arrived today with 40 cell monitor boards and 15 controller boards. It took over two weeks because of the Chinese holiday and I guess they were switching factories. Even though I ordered them before the deadline date… but at least I got them. When I get home from work I’ll inspect them.
So I’m sure I’ll have some more questions fairly soon
Thx Again everyone
Thx but I haven’t seen a video that explains how to set the parameters in the diyBMS for example for a life battery. I made the build and most of the videos if not all is about how to build and compile and not so much about the configuration.
Looks great, why is the round trip showing 60,000 ? For your setup should be more like 4500.
hi to all,
I´m late “” We don’t have enough diyBMS V4 Module Populated PCB KIT x4 stock on hand for the quantity you selected. Please try again. “”
I need only more 2
Does anyone have a spare programed ESP8266 for sale in the uk ie so i can just enter my internet details? I am trying to see if its my pc thats causing my programing problems. I know its not me as i have had help step by step on programing them from Stuart, thank you again
If anyone has one can you private message me.
Cheers Mike
