Hi , nice building
Now i know this board fit to GEN1 cell
But with such cell in // the balancing working nice? not to low?
how many cells can we stack? I see 25 on yourâs, how much can the lower one withstand?
Hi , nice building
Hi
the components are the same between v4.21 and leaf 4.00?
thanks
ISSUE after flashing existing and new cell modules and controller with newest firmware⌠the Contoller cant communicate with any of the cell modules.
When flashing the modules and controller it uploads and reads/verifies just fine.(using PlatformIO(which i prefer) - AVRDUDE keeps giving errors)
But i noticed that new modules and modules that were previously flashed, the leds act(flash) differently. After flashing the new modules the red led blinks quickly and the green led blinks every 2sec on the modules. But When flashing Existing modules which were previously running older firmware it writes and reads/verifies just fine with no errors but the green led flashes quickly and the red led is flashing super fast and almost appears to be steady because its flashing so fastâŚ
Regardless, neither modules will communicate with the controller⌠Ive tried reuploading bootloader and eeprom and both write and read/verifies fine but still same issue.
ANY IDEAS?
Ok, you can always go back to the older version, however try the set fuses option before programming.
It sounds like the clock speed is running strange.
Are you using the code from the master branch?
What I have done yesterday (one option for each try)
-B16 option on/off
-disconnect USBASP from USB Port and connect after pressing upload right before flashing starts.
first flash old fw then new one
combine
there is a bom with the gerber files its a hybrid of 4.21 and v4
i couldnt see a reason in why you woud want to stack more than 26 high, they get very top heavy and unstable if you was to go any higher
Thanks , I just want to know the stack limit if it is documented, even 25 seem to be heavy for the first module.
yea i belive it is from the master branch. at the bottom of github page in the readme section under âhow to use codeâ i click on releases link then download the source code.zip for version Release-2021-01-25-14-42
ive tried the reset fuse option in platformIO but not sure if i tried reflashing afterwards.
ill give that a shot and report back
thx
When flashing the latest firmware, do we still need to flash the system image âdiybms_controller_filesystemimage_espressif8266_esp8266_d1mini.binâ ? when i tried to flash it it gave an error.
4 posts were split to a new topic: Module temperature in freezing conditions
No, not with the latest version for ESP8266.
Hi @Jon_Coop, if you follow the instructions to program from here [diyBMSv4Code/README.md at master ¡ stuartpittaway/diyBMSv4Code ¡ GitHub] you donât use Platformio at all.
Just download the âCompiled_Firmware_2021-01-25-14-42.zipâ file and follow the above instructions.
Hi
I have place an order to jlpcb for leaf module
I have see it is AZ432ANTR for D1 (nice )
I have a doubt about what revision need to flash v4.00 or v4.21?
Thanks for this information
2 posts were split to a new topic: Canât get the batteries to appear in the browser
If its using the 432 chip, then v4.21 will be the one to use, if its using the LM4040 chip, v4.00.
Thanks Stuart
Hi Stuart
Thanks a lot
it is the 432 from last bom download 1 week ago on github
I think you have update the schematic but not the revision, so it is confused for me, maybe add v421 on this last leaf pcb can help to avoid mistake in firmware selection?
have a nice day
@GeorgeBoudreau
Hi
Please can you confirm this point on shematic difference between leaf and v421?
Why there is a C2 capacitor on leaf pcb and not on v421 pcb?
They use 432 on both schematic.
I think C2 is required only for LM4040 for better stability, but is it ok to have it with 432 on leaf pcb ?
thanks
Hi @stuart,
I saw the latest update video on yt and I was wondering if the controller board can handle 55 cell module in series or not? Currently I have 55 cell modul from V3 board and I want to upgrade my system.
Thanks,
Adam.
