I seem to have a problem with Virtual Feeds
On 2 of my devices which have the following Versions
My Virtual Feed which is configured as:
Shows a zero value when added to my Dashboard.
However with the following versions (on another device)
It works fine
I reported the same issue a while back - Virtual feed not updating
Same here. Virtual feed are broken after update to v11.2.10. It seems that the values are calculated correctly, however neither the first nor the last values. Therefore, 0 is shown in the feed overview.
This has been reported also here: Calculations in Virtual Feeds failing
Please put all comments on this thread.
