On my local emonbase, I’ve a virtual feed which simply sums the logged feeds for each of my PV installations. Been doing that since I set it all up a few years ago.
Now the feed is showing zero all the time.
Only change before I noticed it this was a full update a couple of days back to pick up the new emontx4 firmware for the config fix. If I click on the the feed to show the graph, all the numbers are there.
I’ve attached a screenshot from yesterday - the virtual PV feed in the middle should display the sum of the three PV feeds at the top.
