Are there any plans to update the available apps within the iOS version?
MySolarBattery would be fantastic. Currently limited to MyElectric, MySolar and MySolarDivert
@mattjgalloway
Hi thanks for your iOS app for emoncms.
I’ve just updated to 11.0.7 total day counter on the top right corner is adding yesterday + today kWh. In the bottom the kWh are correct divided on the day.
Hope you understand the prob whith my poor English. I’m Italian
Inside emoncms local lan the total counter is correct using only today kwh and not the 2 day sum. Same on emoncms online. Feed seams ok display
Hope you can solve
Thanks in advance
Can you provide a screen shot of what you mean please? Will be easier to see like that.
@mattjgalloway
You can see in the upper right corner the difference. iOS app report a sum of yesterday plus today kwh
Emoncms over lan report correct value 6.1kwh
13.8 on your app = yesterday 7.7 + 6.1
Hope you better understand
Thx
Curious. My theory is time zones. Where is the server located that you have emonCMS installed on?
Rome Italy
Time zone seams correct inside emoncms and on emonpi using ssh to connect.
Plus at midnight it discharged correct a part of kwh. But not all.
It’s always one day backards.
Got it. I’ll take a look. Thanks for the very useful screenshots!
It’s confusing me but must be timezone related somewhere. I bet the iOS app is requesting the wrong day of data somewhere. And the fact I don’t have the problem will likely be that I’m on GMT and so is the server I use. Everything being UTC means timezone issues never arise!
Thanks for all
Ps : maybe could help… I don’t know
Look here last comment
It should be interesting on Sunday! We change to UTC+1
Nothing changed at least for now whith time change in Italy.
Same problem
I managed to take a look into this today. It’s strange. I definitely see some weird things when I change my time zone to be in Australia (really crank it away from GMT!). I’m still working on figuring out what’s going on. I’m a bit confused still to be honest! But at least I can reproduce some differences between the iOS app and emoncms on web.
Sorry I haven’t said anything here all week - I came down with COVID on Monday and so I’ve been a bit out of it! Not too bad symptoms fortunately other than being tired mainly. So not had chance to really get into this yet. I will do though I promise!
Sorry to hear you keep covid but happy low symptom. Hope you’ll be 100 % in few days
Thanks for your promise
I managed to take a look into things here. I think actually that the iOS app is doing the right thing here and it’s the web that’s wrong. What I’ve discovered is that if your timezone is not precisely the timezone of the server, then the emoncms web app will show the previous day’s kwh used for the “used today” field in the MyElectric app.
But from what I can tell, this was all fixed in this commit:
Could you confirm what version of emoncms web you’re using please @lord_valex?
[I did however find a fun issue where if you’re a very far timezone from where the server is then the iOS app will not correctly show the today kwh and it will instead show the entire kwh value as the today data. But that is a different and isolated issue which I’ve pushed a fix for to the repo.]
