While clip on CTs are good, would like to know the recommended solid core (I am getting electrician to install) CTs for 20A circuits, with a decent 3.5mm lead length
thanks
thanks
Iāve been looking for the same! But with a 1m to 1.5m length of cable. A 3.5mm lead length seems very short. Mounting the CT to a circuit board?
And Iād like to find a solid core for a 30 amp circuit breaker. This is for the HVAC compressor and Iām afraid Iād damage something using a 20A CT.
I have had great success with the HWCT-004. I used to be able to get them on eBay for about $2 in lots of 10 or 15. Not so much anymore. They are available from a variety of suppliers on AliExpress for $3 -$5 free shipping from Shenznen. Takes 2-3 weeks. Iāve bought quite a few various items on AliExpress and AliBaba. To me, thereās no difference buying from China via eBay vs AliExpress. I think Iāve said this before - what do you have to lose? Order them today and youāll have them before Christmas.
I donāt know of any inexpensive small solid core CTs that come with long leads. They all come with a couple 6" wires. I buy cheap 3.5mm male-male audio cords, cut them in half, and solder them to the CTs. Nice little piece-work project.
The HWCT-004ās are good to about 40 amps in an IoTaWatt. They do the 20A circuits fine as well. Iāve got a bunch in my panel. If you come across any DL08CL2ās, they look identical to the HWCT-004 and work the same.
oops, sorry I mean 3.5mm jack
I found your post from earlier this year. Thank your for the test info and images!
I found very little info about the HWCT-004 on the internet.
⢠What physical size are the CTs?
⢠Are any additional components needed to use these (e.g., diode, resistor)?
OD = 26mm
ID = 9mm
width = 14mm
You can add a TVS diode if you want to be able to unplug it while the primary circuit is hot. I donāt have diodes on mine.
The burden resistors in the IoTaWatt (or TX) are fine. Turns = 1000.
Would be great to get a picture of the zener diode soldered onto the lead,
(I am a real newbie at this) (orientation and specific zener diode specs, would be really nice)
I suspect that with solid core CT, you are more likely to plug/unplug while the circuit is hot,
although I suppose I could just trip the circuit breaker.
Although thinking about this, I want to put a clamp around the main feed into house, so I can
measure import/export (I have Solar PV) as well. And that one is hard to get at, and I supppose
it will always be āhotā
Or is it just safer to power down the IotaWatt when plugging in CTs
Does this pic make sense - I am assuming the CT on the domestic supply will show me import or export, depending on current flow
Looks good as far as what gets monitored and where. conceptually I might indicate the 20A circuits with a blue arrow going out of the panel. Thee algebraic sum of the red power flow would then equal the blue power flow.
Yes the main can be negative, and you must check the box to āallow negativeā when configuring the main.
I donāt have pictures or a source for CT TVS diodes. Iād recommend an sct013-000 for th3 main if it will fit on the cable. They have diodes built in.
I just got 15 HWCT-004ās off AliExpress. Was a but reluctant as they (They being AliExpress) donāt get the most glowing of reviews, but they got here as ordered and DHL delivered on a Sunday to boot (Wasnāt expecting that - DHL driver didnāt seem terribly happy though lol).
Dave, do you have a schematic of how you wire up the diodes and what āmodelā of Diode you use? Canāt really tell how itās wired up in the pic. Iām going to need to get these wired since they only have about 5" leads.
I am curious what day you ordered the HWCT-004 CTs? I ordered from AliExpress also (and I am in the US).
I ordered them on 11/15 and they were delivered today. But I also selected their āAliExpress Premium Shippingā for a little more.
Ahhh! I paid the $0.90 to get tracking and I should have paid a few $$ more to get it faster.
Thanks Dave - Is this how you have them wired up? Assuming so, is there any technical reason they couldnāt be wired up closer to the CT, such as where Iāll have to extend the wires (I wouldnāt think so, just checking)?
I have to be honest, Iāve never really looked all that closely into how Zener Diodes work before - so the way they are wired up, Iām assuming they function like an open circuit until 9.1v is reached, at which time they allow current flow and dissipate the built up voltage long before it becomes hazardous to a person or damaging to the CT?
So I got all f my HWCT-004ās wired up - For grins, I put one on a circuit, and attached my meter to the connector and when I turned the circuit on, it pretty quickly shot up to 4 or 5 volts. Based on further reading, it seems that the Zener diodes donāt just āshortā when they hit their limit, but instead āregulateā the voltage at tier breakpoint, so in theory, if they werenāt working right, the voltage I saw should have continued to climb āforeverā (or until the circuit was shut off).
Hereās how I wired them up, rather than trying to shove them in the connector at the end (since I had to extend the leads anyway).
Then shrink tubing over each diode to isolate them and larger shrink tubing over the entire package to isolate any part of the diodes from ever contacting something in the panel.
Iām guessing, based on how the Zener diodes work, that the orientation of the diodes donāt really matter for this circuit other than to make sure that the Anode of one is joined to the anode of the other, or cathode to cathode? Either way, unless the voltage hits the breakpoint, which it shouldnāt if itās hooked up and working as intended, a complete circuit will never be completed to shunt some/most of the voltage.
Thats a great help Dkramkowski
