koki
(Mahran Sujau)
14 November 2019 03:39
1
Hi All,
I setup my emon-Pi yesterday. It was working all fine, until this morning I keep getting this on the top of the graph.
Request error: Received data not in correct format. Check the logs for more details
the logs under errors shows this.
I tried down loading the data as well and all i get is this
icenov
(Anthony Vassallo)
14 November 2019 06:22
2
Try logout and login again. I get the same message when connection is lost due to power failure (had a lot of these recently!).
koki
(Mahran Sujau)
14 November 2019 06:42
3
hmm, I have tried that still seem to be getting the same message? any suggestion on how to retrieve the data.
borpin
(Brian Orpin)
14 November 2019 09:12
4
Hi Mahran, welcome,
The log you posted is the EmonHub log, not the EmonCMS log (under Admin).
Try refreshing the page (ctl-reload) and clearing the browser cache. You can also try opening the page in a ‘private’ window.
Under Admin, can you click on the button ‘copy as markdown’ next to ‘Server Information’ and paste here (no further formatting required).
koki
(Mahran Sujau)
14 November 2019 09:46
5
thanks Brian,
here you go, I cannot seem to download locally , but setup the remote one, that seems to work. but my application will mainly be local.
Server Information
Server Information
Services
emonhub :- Active Running
emoncms_mqtt :- Active Running
feedwriter :- Active Running - sleep 300s 48 feed points pending write
service-runner :- Active Running
emonPiLCD :- Active Running
redis-server :- Active Running
mosquitto :- Active Running
demandshaper :- Active Running
Emoncms
Version :- low-write 10.1.11
Modules :- Administration | App v2.0.9 | Backup v2.1.7 | EmonHub Config v2.0.4 | Dashboard v2.0.5 | DemandShaper v1.1.0 | Device v2.0.3 | EventProcesses | Feed | Graph v2.0.6 | Input | Postprocess v2.1.2 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.2
Git :-
Server
OS :- Linux 4.19.75-v7+
Host :- emonpi | emonpi | (192.168.1.142)
Date :- 2019-11-14 09:40:13 UTC
Uptime :- 09:40:13 up 3:01, 0 users, load average: 0.11, 0.08, 0.08
Memory
RAM :- Used: 18.83%
Total :- 975.62 MB
Used :- 183.74 MB
Free :- 791.88 MB
Swap :- Used: 0.00%
Total :- 100 MB
Used :- 0 B
Free :- 100 MB
Write Load Period
Disk
/ :- Used: 46.58%
Total :- 3.92 GB
Used :- 1.83 GB
Free :- 1.9 GB
Write Load :- 884.88 B/s (2 hours 7 mins)
/var/opt/emoncms :- Used: 0.04%
Total :- 9.98 GB
Used :- 3.78 MB
Free :- 9.47 GB
Write Load :- 27.23 B/s (2 hours 7 mins)
/boot :- Used: 20.55%
Total :- 252.05 MB
Used :- 51.79 MB
Free :- 200.26 MB
Write Load :- 0 B/s (2 hours 7 mins)
/var/log :- Used: 9.36%
Total :- 50 MB
Used :- 4.68 MB
Free :- 45.32 MB
Write Load :- n/a
HTTP
Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
Host :- localhost:6379 (127.0.0.1)
Date :- 2019-11-14 09:40:13 (UTC 00:00)
Stats :- Uptime: 10966 Threads: 12 Questions: 9431 Slow queries: 0 Opens: 46 Flush tables: 1 Open tables: 40 Queries per second avg: 0.860
Redis
Version :-
Redis Server :- 5.0.3
PHP Redis :- 5.0.2
Size :- 100 keys (834.96K)
Uptime :- 0 days
MQTT Server
Version :- Mosquitto 1.5.7
Host :- localhost:1883 (127.0.0.1)
PHP
Version :- 7.3.9-1~deb10u1 (Zend Version 3.3.9)
Modules :- apache2handler | calendar v7.3.9-1~deb10u1 | Core v7.3.9-1~deb10u1 | ctype v7.3.9-1~deb10u1 | curl v7.3.9-1~deb10u1 | date v7.3.9-1~deb10u1 | dom v20031129 | exif v7.3.9-1~deb10u1 | fileinfo v7.3.9-1~deb10u1 | filter v7.3.9-1~deb10u1 | ftp v7.3.9-1~deb10u1 | gd v7.3.9-1~deb10u1 | gettext v7.3.9-1~deb10u1 | hash v7.3.9-1~deb10u1 | iconv v7.3.9-1~deb10u1 | json v1.7.0 | libxml v7.3.9-1~deb10u1 | mbstring v7.3.9-1~deb10u1 | mosquitto v0.4.0 | mysqli v7.3.9-1~deb10u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $ | openssl v7.3.9-1~deb10u1 | pcre v7.3.9-1~deb10u1 | PDO v7.3.9-1~deb10u1 | pdo_mysql v7.3.9-1~deb10u1 | Phar v7.3.9-1~deb10u1 | posix v7.3.9-1~deb10u1 | readline v7.3.9-1~deb10u1 | redis v5.0.2 | Reflection v7.3.9-1~deb10u1 | session v7.3.9-1~deb10u1 | shmop v7.3.9-1~deb10u1 | SimpleXML v7.3.9-1~deb10u1 | sockets v7.3.9-1~deb10u1 | sodium v7.3.9-1~deb10u1 | SPL v7.3.9-1~deb10u1 | standard v7.3.9-1~deb10u1 | sysvmsg v7.3.9-1~deb10u1 | sysvsem v7.3.9-1~deb10u1 | sysvshm v7.3.9-1~deb10u1 | tokenizer v7.3.9-1~deb10u1 | wddx v7.3.9-1~deb10u1 | xml v7.3.9-1~deb10u1 | xmlreader v7.3.9-1~deb10u1 | xmlwriter v7.3.9-1~deb10u1 | xsl v7.3.9-1~deb10u1 | Zend OPcache v7.3.9-1~deb10u1 | zlib v7.3.9-1~deb10u1
Pi
Model :- Raspberry Pi 3 Model B Rev 1.2 - 1GB (Sony UK)
Serial num. :- A29A66D4
Temperature :- 56.38°C - 56.4°C
emonpiRelease :- emonSD-17Oct19
File-system :- read-write
Client Information
Client Information
HTTP
Browser :- Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.97 Safari/537.36
Language :- en-US,en;q=0.9
Window
Screen
borpin
(Brian Orpin)
14 November 2019 11:26
6
I’m not sure what you mean. Are you referring to emoncms.org as ‘the remote one’? If so these are 2 completely different things or instances of the software that are only loosely related.
Is it just the one graph that does not work? Have you tried other graphs with other data?
If so you will need to provide screenshots showing the feeds you are trying to graph(from the feeds page) and the graph page including the left menu.
koki
(Mahran Sujau)
14 November 2019 12:40
7
yes the remote one i am referring to is emoncms.org .
the issue is when i try to download on my local network. I can generate a graph but i cannot down load the CSV file from the graph.
For example this is for temperature , i can see the data on the CSV output , but the content of file is as same as before. I have also tried to do this from the feeds, by selecting all the feeds.
this is a screen shot of the graph
this is a screen shot of the settings to generate the graph.
this the bottom of the CSV output, it seems the last few readings are null
borpin
(Brian Orpin)
14 November 2019 12:42
8
Ah, see this thread - same issue.
I recently tried to export a feed from both the graph view and also feed view, but run into an issue (using emonCMS Version: low-write 10.1.8) where even tiny amounts of data won’t download. The error message is:
<br />
<b>Notice</b>: Undefined index: csvdownloadlimit_mb in <b>/var/www/emoncms/Modules/feed/feed_model.php</b> on line <b>676</b><br />
{"success":false,"message":"CSV download limit exeeded downloadsize=440640"}
Checking line 676 in the file refers back to settings.php where down…
@emrys @TrystanLea 2 reports.
koki
(Mahran Sujau)
14 November 2019 12:56
9
thanks Brian,
does this mean I need SSH into the PI so that I can change the PHP file?
/var/www/emoncms/Modules/feed/feed_model.php add in an underscore after csv .
or should i wait for the patch ?
borpin
(Brian Orpin)
14 November 2019 14:32
10
So you can wait for the patch or put the fix in, but note it only fixes one of the issues.
Once the fix goes into a release, you will need to undo it to be able to update.
koki
(Mahran Sujau)
14 November 2019 15:38
11
hmm, I see i am guessing these updates will take more than few days ?
Not sure if I can do the fix manually, any instructions on this.
As for 2nd issue I deleted the feed today, I will see it repeats again.
borpin
(Brian Orpin)
14 November 2019 15:41
12
Quite probably
nano /var/www/emoncms/Modules/feed/feed_model.php
find the right line and add in the underscore.
Ctl-x to exit nano editor.
koki
(Mahran Sujau)
14 November 2019 19:14
13
Unfortunately this didnt fix it (line 672)
i keep getting this error.
Notice : Undefined index: csv in /var/www/emoncms/Modules/feed/feed_model.php on line 790
TrystanLea
(Trystan Lea)
14 November 2019 19:47
14
I’ve fixed the second issue re line 790, thanks @koki and thanks @borpin for the fix for the first.
I’ve merged the fix into emoncms stable as well.
koki
(Mahran Sujau)
14 November 2019 19:53
15
@TrystanLea what is the fix ? does that mean the emoncms update would have fix ?
sorry i am a bit of a noob on this.
TrystanLea
(Trystan Lea)
14 November 2019 19:54
16
Yes sorry available via emoncms update, if you have made any local changes you will need to clear them first, you can do this via command line like this:
cd /var/www/emoncms
git checkout .
koki
(Mahran Sujau)
14 November 2019 20:00
17
M Modules/feed/feed_model.php
Your branch is up to date with ‘origin/stable’.
does that mean i am ok to do the update then ?
koki
(Mahran Sujau)
14 November 2019 20:20
19
@TrystanLea sorry mate,
this is what I get
Warning : Invalid argument supplied for foreach() in /var/www/emoncms/Modules/graph/graph_controller.php on line 97
Warning : file_get_contents(http://192.168.1.142//feed/aget.json?id=8 ): failed to open stream: HTTP request failed! HTTP/1.0 406 Not Acceptable
in /var/www/emoncms/Modules/graph/graph_controller.php on line 130
“Date-time string”,": ()"
the content of the feed download was huge .
how do I know if the update was successful? I went Admin >Update on emoncms view
borpin
(Brian Orpin)
14 November 2019 20:22
20
@TrystanLea Have you pushed this to stable without a version update?
You have also missed the problems with the graph module.
