koki
(Mahran Sujau)
14 November 2019 20:22
21
here is a copy of the log file
LAST ENTRIES ON THE LOG FILE
2019-11-14 07:55:20.365|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=5
2019-11-14 07:55:20.456|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=7
2019-11-14 07:59:54.485|ERROR|index.php|Not Authenticated|feed/data
2019-11-14 07:59:54.509|WARN|index.php|406 Not Acceptable|feed/aget
2019-11-14 11:09:52.029|ERROR|index.php|Not Authenticated|feed/data
2019-11-14 11:09:52.053|WARN|index.php|406 Not Acceptable|feed/aget
2019-11-14 12:08:01.344|ERROR|index.php|Not Authenticated|feed/data
2019-11-14 12:08:01.361|WARN|index.php|406 Not Acceptable|feed/aget
2019-11-14 12:42:05.987|ERROR|index.php|Not Authenticated|feed/data
2019-11-14 12:42:06.010|WARN|index.php|406 Not Acceptable|feed/aget
2019-11-14 15:26:49.732|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-11-14 15:26:49.757|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-11-14 18:44:54.827|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-11-14 18:44:54.850|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-11-14 18:50:08.878|ERROR|index.php|Not Authenticated|feed/data
2019-11-14 18:50:08.938|WARN|index.php|406 Not Acceptable|feed/aget
2019-11-14 18:59:14.804|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-11-14 18:59:14.833|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-11-14 19:00:22.846|ERROR|index.php|Not Authenticated|feed/view
2019-11-14 20:05:03.932|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-11-14 20:05:03.955|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-11-14 20:07:46.591|ERROR|index.php|Not Authenticated|feed/data
2019-11-14 20:07:46.638|WARN|index.php|406 Not Acceptable|feed/aget
2019-11-14 20:08:34.731|ERROR|index.php|Not Authenticated|feed/data
2019-11-14 20:08:34.755|WARN|index.php|406 Not Acceptable|feed/aget
borpin
(Brian Orpin)
22
Yes, that issue has not been fixed yet.
koki
(Mahran Sujau)
15 November 2019 10:01
23
i managed to replicate the “received data not in correct format” issue
i get this error when i change the fixed length variable from 20 to 3
this is the emon CMS log
2019-11-14 20:23:57.051|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-11-14 20:23:57.075|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-11-15 03:31:05.572|ERROR|index.php|Not Authenticated|user/get
2019-11-15 03:31:10.048|ERROR|index.php|Not Admin|admin/view
2019-11-15 06:25:21.404|WARN|index.php|406 Not Acceptable|feed/aget
2019-11-15 06:25:21.487|ERROR|index.php|Not Authenticated|feed/data
2019-11-15 06:25:21.658|ERROR|index.php|Not Authenticated|user/get
2019-11-15 06:25:57.773|ERROR|index.php|Not Authenticated|feed/data
2019-11-15 06:26:36.222|ERROR|index.php|Not Authenticated|feed/data
2019-11-15 09:54:23.682|ERROR|index.php|Not Authenticated|feed/data
2019-11-15 09:57:41.890|ERROR|index.php|Not Admin|admin/view
borpin
(Brian Orpin)
15 November 2019 10:37
24
Not sure what fixed value you have changed.
This is a bug in the Graph Module that @TrystanLea has not fixed yet AFAIK.
TrystanLea
(Trystan Lea)
16 November 2019 09:04
25
I realise the original feed_model fix that I made was incorrect, the default settings key name was incorrect in the ini settings file, now fixed fix csv_settings · emoncms/emoncms@3736a74 · GitHub
I’ve also bumped the version and merged to stable.
I don’t quite follow the graph error, could you describe the steps to replicate this error @koki @borpin ?
koki
(Mahran Sujau)
16 November 2019 09:21
26
@TrystanLea what I meant was , say for example if the start date and time was 16/11/2019 05:00:00 and the end date is 16/11/2019 13:00:00 I can get the error when I change the fix value for from say 3 to 50.
does that make sense ?
koki
(Mahran Sujau)
16 November 2019 10:00
27
I went to admin >updates : updated emoncms only
is the verion i am supposed to have 10.1.11
TrystanLea
(Trystan Lea)
28
Thanks @koki , found the issue and fixed. If you run update now you should have 10.1.13
borpin
(Brian Orpin)
16 November 2019 10:03
29
@TrystanLea brilliant, thanks
koki
(Mahran Sujau)
16 November 2019 11:26
30
@TrystanLea thanks mate,
just one more thing, how do i revert the changes i suspect this is why its not updating
From GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data
branch stable → FETCH_HEAD
error: Your local changes to the following files would be overwritten by merge:
Modules/feed/feed_model.php
Please commit your changes or stash them before you merge.
Aborting
Updating 25e84370…90f39158
i tried the
cd /var/www/emoncms
git checkout .
koki
(Mahran Sujau)
16 November 2019 11:46
31
cool worked the second time around
borpin
(Brian Orpin)
16 November 2019 12:13
33
Ah but do a
git checkout stable
git pull
and see what the message is…
