I recently tried to export a feed from both the graph view and also feed view, but run into an issue (using emonCMS Version: low-write 10.1.8) where even tiny amounts of data won’t download. The error message is:
<br />
<b>Notice</b>: Undefined index: csvdownloadlimit_mb in <b>/var/www/emoncms/Modules/feed/feed_model.php</b> on line <b>676</b><br />
{"success":false,"message":"CSV download limit exeeded downloadsize=440640"}
Checking line 676 in the file refers back to settings.php where download limit is “25,” (note the “,”). If I edit this and remove the comma, emoncms won’t load, even after a reboot. I don’t use php so not sure if the comma means anything or is ignored.
Any suggestions welcome…
That’s fixed the download from the feed view (good for 24 MB!), but still an error when downloading from the graph csv menu. Is that using a different script?
<br />
<b>Warning</b>: Invalid argument supplied for foreach() in <b>/var/www/emoncms/Modules/graph/graph_controller.php</b> on line <b>97</b><br />
<br />
<b>Warning</b>: file_get_contents(http://192.168.20.24/emoncms//feed/aget.json?id=87): failed to open stream: HTTP request failed! HTTP/1.0 406 Not Acceptable
in <b>/var/www/emoncms/Modules/graph/graph_controller.php</b> on line <b>130</b><br />
"Date-time string",": ()"
