Hello All
I have been running a Daikin Altherma 3 HHT, model EPRA18DV3, since August 2025
Can anyone help explain some rather puzzling readings from my heat pump.
1) Heat Pump ‘COP’
The tiny user interface on the Daikin indoor unit has some information screens. These include data about Electricity Input and Produced Heat, I have been taking daily readings of totals since installation. This lets me calculate Electricity Input per day and Produced Heat per day. I ran the heat pump for a few months at its installed Leaving Water Temperature (LWT) of 55C. I wanted to see how it would perform with the installer setup.
I have taken my daily readings and divided the Produced Heat for each day by the Electricity Input. I am provisionally calling this Heat Pump ‘COP’, although I don’t know enough yet to be sure that’s what it is. The plot attached below shows that with LWT = 55 my Heat Pump ‘COP’ varies between about 3 and well above 5. (Delta T is the difference between internal and external temperature, measured in a rather labour intensive way using two outside Min / Max thermometers and ten inside)
Two or three weeks ago I reduced the LWT to 50. As expected the Heat Pump ‘COP’ is higher. There seems to be a kink in the plot. But it may simply be that I don’t have enough LWT = 50 data points yet
Heat Pump COP.pdf (9.8 KB)
Here is what is puzzling me.
2) Heat Pump System Electricity Consumption
My second plot below shows that with Delta T less than 11.5 C, the heat pump system as a whole uses more energy at LWT = 50 than at LWT = 55. In this plot the electricity is measured from the dedicated consumer unit that was installed to power the heat pump and all the related heating system equipment
Heat Pump_Consumer_Unit_Elec_vs_Delta_T.pdf (12.2 KB)
Reducing LWT has apparently increased ‘Heat Pump COP’ but made the system as a whole less efficient. Can anyone explain what is happening?
I should add a couple of other points.
I believe the heat pump has been over-sized
I don’t have specific DHW data, but I think our usage is fairly constant, apart from the weekly disinfection days.
Any thoughts will be much appreciated.
Chris Gordon-Smith
