There have been a number of requests for making it easier to copy dashboards across accounts and between different emoncms installations. E.g copying an emoncms.org dashboard to run on an emonpi.
tag:name reference
For sometime dashboards have used unique feedid’s for their configuration which means that a dashboard on one account cant be copied to another account because the feedid’s will be different on the second account.
I’ve put together a solution to this problem providing the option to use tag:name reference for feeds in dashboards as well as feedid reference. The option to use either reference mode can be selected on the dashboard settings page:
After switching the feedmode from feedid to tag:name, go through each widget in the dashboard and re-save its feed configuration to use the new reference mode to complete the conversion.
You should then be able to copy the dashboard html following the next step to a dashboard on another account but with feeds of the same tag and name.
dashboard html acess
I have also added a second feature on the dashboard configuration page suggested by @pb66 which makes it simpler to access the html for the dashboard as well as making it possible to copy and paste dashboard content between installations:
XSS Filter
There is also a new xss filter that removes javascript to help protect against XSS attacks, using https://github.com/voku/anti-xss
Testing
Im looking for help testing these features before they are merged into the master branch.
To switch to this tagname_option development branch on an emonpi/emonbase the terminal commands are:
cd /var/www/emoncms/Modules/dashboard
git checkout tagname_option
You may want to backup your mysql database before doing this, just in case there’s a bug that overwrites a previously created dashboard.
The github issues created by @pb66 can be found here:
