Ah Ok that branch is on the older feedwriter cron job (strangely came across this this week).
I think first check the cron job
crontab -l
crontab -l
Seems like crontab is default
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h dom mon dow command
One last try then Iām out of ideas (not familiar with the older feedwriter service)ā¦
The command in the script to restart it is
sudo /etc/init.d/feedwriter restart
That works, but reboot of the feedwriter.service worked too!
Log is turned off
Restarting feedwriter (feedwriter.php was not running...)
Still doesnāt explain/help as to why the feed writer is not restarted after emonpi update button is pressed.
Iāve raised it as an Issue.
But also note what the actual emoncms buffer status is, it changes on the live server info, but the copy and paste version always says āloadingā¦ā so itās effectively meaningless.
When the line below is showing, the buffer will continue increasing with a number of points to write.
Daemon is not running, start it at ~/scripts/feedwriter
Yes but I do not think that is fixable because of the way the Ajax call works. Just one to be lived with I suspect unless you could make a special call to the function and append the data at the end of the text buffer.
I wasnāt aware of that.
No one has commented on the issue I raised.
If it canāt be reported (copied) accurately, it shouldnāt included. So the best fix would be to remove it I guess, even if only temporarily. Simples!
I donāt think feedwriter was ever cron based⦠it changed from SystemV Init based startup to systemd based startup⦠Youāre thinking of service-runner (which was initially cron and changed to systemd)
Not as simple as that I suspect. The output HTML is copied by using a class ID
within that copied area is the ajax call to update the number in the buffer
I suspect removing this section when copied might be well nigh impossible (but Iām no expert).
Ah yes - getting myself confused.
2 posts were split to a new topic: MQTT not working after restore
@borpin I had a similar problem when updating emonBase (using emonSD-30Oct18). After update noticed feeds was not updating, so tried sudo systemctl status service-runner.service and also sudo /etc/init.d/feedwriter restart. All seemed OKā¦
but still no feed updates.
But a reboot of the rPi fixed it.
A post was split to a new topic: Keeping an EmonSD installation up to date
A post was split to a new topic: No SSH Password
