Hi Darren, welcome to the forum!
The CSV energy report contains raw minute-by-minute data for selected parameters for your device in comma separated variable format. This file will be 30-40Mb in size, and may take several minutes to generate and download. It is intended to be imported into a spreadsheet for further processing rather than read directly as a report.
Fields returned: TimeStamp, RoomTemperatureZone1, RoomTemperatureZone2, OutdoorTemperature, FlowTemperature, EnergyConsumed, EnergyProduced, OperatingMode
Energy is in Wh, multiply by 60 to get power (W). Expect to be processing around 525,600 rows.
OperatingMode can be one of: Stop, HotWater, Heating, FreezeStat, LegionellaPrevention.
Note that the csv is very big, and not really suitable for constant monitoring. There are alternate methods that can work better, depending on how much programming you want to do, as well as monitoring via 3rd part dongles and HomeAssistant.
- Daily extract of MELCLOUD data for ECODAN
- Preparing to monitor a new Mitsubishi Ecodan
- WiFi + MQTT dongle for Mitsubishi Ecodan
- Monitoring & Controlling Ecodan via CN105 (long)
I can also provide real-time monitoring for you; message me for details.
Hope that helps.
