borpin
(Brian Orpin)
19 April 2019 06:25
1
Just flashed the Oct18 image to an SD Card with Etcher.
I want to expand the file system but raspi-config comes back with mmcblk0p2 is not the last partition.
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 96663 88472 43.2M c W95 FAT32 (LBA)
/dev/mmcblk0p2 98304 8290303 8192000 3.9G 83 Linux
/dev/mmcblk0p3 8290304 15125000 6834697 3.3G 83 Linux
pi@emonpi:/var/log $ sudo blkid -o list
device fs_type label mount point UUID
/dev/mmcblk0p1 vfat boot /boot 3725-1C05
/dev/mmcblk0p2 ext4 rootfs / fd695ef5-f047-44bd-b159-2a78c53af20a
/dev/mmcblk0p3 ext2 /home/pi/data 9d452b0a-cb89-4ec2-a32c-6b85dcbcc1c2
/dev/mmcblk0 (in use)
Filesystem Size Used Avail Use% Mounted on
/dev/root 3.9G 1.6G 2.2G 42% /
devtmpfs 484M 0 484M 0% /dev
tmpfs 489M 0 489M 0% /dev/shm
tmpfs 489M 50M 440M 11% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 489M 0 489M 0% /sys/fs/cgroup
tmpfs 30M 20K 30M 1% /tmp
tmpfs 50M 28M 23M 55% /var/log
tmpfs 1.0M 0 1.0M 0% /var/tmp
/dev/mmcblk0p3 3.3G 113M 3.0G 4% /home/pi/data
/dev/mmcblk0p1 43M 22M 21M 52% /boot
tmpfs 98M 0 98M 0% /run/user/1000
I’m not completely comfortable with what needs to be done to expand the file system.
pb66
(Paul)
19 April 2019 08:26
2
What size sd card is this? It looks like the fs is expanded already since you have 2.2G space on the root fs and 3G left in the data partition.
The 3rd partition has always blocked raspi-config from being used, there is a OEM utility called emonSDexpand (or something similarly named) that is aimed at expanding both the root and data partitions, I think it can be run manually but is included in the emonsd image to run when the image is first run AFAIK.
[edit - I just looked for where is gets expanded for another discussion and cannot find it, maybe the image doesn’t auto expand, if that’s the case the image must come semi-expanded (ie it wasn’t reduced before being packaged)]
borpin
(Brian Orpin)
19 April 2019 11:12
3
Ah yes. Solution is as per documentation
sudo emonSDexpand
pi@emonpi:~ $ df -h
tmpfs 489M 13M 476M 3% /run
tmpfs 50M 128K 50M 1% /var/log
tmpfs 30M 0 30M 0% /tmp
/dev/mmcblk0p3 11G 113M 9.7G 2% /home/pi/data
warning, you can login by SSH while it is happening but the p3 is apparently missing. As the Pi does not actually shutdown and the LCD does not change, it is difficult to know if it has finished. Not being able to SSH indicated to me it was done.
pb66
(Paul)
20 April 2019 09:45
4
pb66:
Saw this when looking for something else
File System
Note: the emonSD pre-loaded SD cards shipped via the OpenEnergyMonitor store or pre-loaded in emonPi / emonBase will be expanded to fill the 16GB card. The default download image is 8GB, if using a larger SD card follow the instructions near the top of this page to expand the data partition
$ df -h
tmpfs 50M 1004K 50M 2% /var/log
The filesystem was not reduced like previous/other images
