emonPixel Development
Following on from thread:
The development of the ESP8266 based WiFi pixel display has been continuing, the unit is now called emonPixel . @David_Hunnisett has been doing an amazing job designing a laser cut plywood enclosure for the unit.
Here are a few photos of the emonPixel simulating displaying % solar PV generation Vs Consumption:
We would be interested to hear any feedback.
Firmware is based on emonESP in development on github:
GitHub - openenergymonitor/emonPixel: WiFi LED Pixels
Fantastic, when can I buy one?
Only one suggestion would to put a segment in the middle but that might be difficult with the space on the board.
Regards
Dave
Thanks, the plan is to launch a crowdfunder soon.
That would be nice, but difficult since that’s where the ESP chip is!
Can this be made the same size as a standard UK back box/socket so it could be put on the wall easier ?
On top of Stuarts suggestion, 12/5v terminals at the back to hide the cables when mounted on a back box/patress.
Regards
Dave
It already has a 5v in power pims exposed via the programming header on the back.
Ill check and see how it would fit onto a 1g patress iirc its ~80mm wide and a 1g is I think 75mm so it should fit nicely on top and hide the box.
I haven’t got a rear mounting plate but it wouldn’t be too hard to take a blanking plate and screw that into the back of the emonPixel with short screws!
ok so its a bit too small in its current incantation to totally cover a 1g face plate.
It cover the hole but the plates have a few extra mm on the sides that show :frowning:
Here’s a little video clip showing the emonPixel in operation
Hi Glyn,
Is there a example flow of the node-red emonpixel library? I’ve installed it but I can’t figure out how to use it.
Yes, there is an example here in the emonPixel repo:
Glyn
Are the kits on sale yet?
Regards
Dave
Not officially, however we have a few (10’s) of fully working prototype units. I can sell you one for £20. This is for just the fully assembled PCB running latest FW and not the laser cut enclosure.
If you want to go ahead, please order 20 x customised payment units and leave a comment with your order: Specials - Shop | OpenEnergyMonitor
Thanks Glyn,
I’ve used it and made some improvements to it, uploaded a pull request on github!
https://github.com/openenergymonitor/emonPixel/pull/2
  • Updated names MQTT power input to 'Solar Power Feed'
  • made comment boxes with short explanation how to use it
  • Updated debug message boxes with names and connected to more useful places
  • Updated the RANGE nodes with the "Round result to the nearest integer" option. no need for decimal digits in the output string.
That’s great! Thanks so much :thumbsup:
Hi Glyn
Ive just tried importing the NodeRED flow in preparation but have received the following error, I presume that I should have installed a module?
Regards
Dave
Yes, you need this module:
You can install via the UI: manage palatte> Install > seach for emonPixel > install
Spot on Glyn!
Many Thanks
Dave
No problem, your pixel has been shipped today :smiley:
Fantastic! :smile:
Hi Glyn
I’m struggling to connect the emonPixel to a wireless network, the LEDs keep racing round in different colours which isn’t identified in any documentation and I cant force it by holding down the boot button while powering up as this enters the bootloader.
I have tried reloading the firmware to check that it has the right firmware but I get the same?
Regards
Dave
