Is should be in wifi ap mode. Can you see a wifi network called
emonPixel-xx? If you connect to thus you should be directed to a captive
portal to setup wifi and mqtt settings.
  • sent from my mobile device
Hi Glyn
There’s no SSID being broadcast :frowning: and the LEDs are also different colours.
My daughter likes it though.
Regards
Dave
Hi Glyn
I managed to connect to the emonPixel, I think it was booting and then crashing, turned out that it needed a flash wipe and then a firmware upload as the previous firmware upload had the same result.
I need to get my head around what the different commands are to get an idea what the flashing and whizzing colour LEDs mean as I cant make head or tail ATM, below is what’s its doing.
- YouTube
Regards
Dave
That’s strange, can you see the serial output of the ESP @115200 baud?
Could you post the serial output at startup? Maybe I loaded the incorrect
FW.
@glyn.hudson are there any dimension diagrams/plans for the emonPixel - I want to build a 3d printed case for it !
Hi Glyn
The serial is as follows…
▒rl▒▒r▒▒#▒n▒▒▒
▒▒p▒<▒▒▒▒8▒▒ǒ▒▒p
▒nn▒▒;▒nĒ▒▒
b▒$     rrp▒n▒▒▒
▒▒▒l▒▒▒▒
b▒n▒▒n▒$▒
b▒▒>~▒n▒▒▒▒l`▒▒#▒n▒▒rnr▒▒▒;▒▒
▒;r▒ےn▒▒▒b▒▒`▒▒l▒▒Ìr▒n▒b▒
EmonESP 432894
Firmware: 0.0.1
Connecting as client to SiFi epass:WPA_CODE
Try Again...
Try Again...
Try Again...
Try Again...
Try Again...
Try Again...
Try Again...
Try Again...
Try Again...
Try Again...
Try Again...
Connected, IP: 192.168.10.127
Server started
MQTT Connecting...
MQTT connected
Message arrived [
emonpixel
background/133/0/0
parsed command: background
Set backgorund to red: 133 Green: 0 Blue: 0
Message arrived [
emonpixel
background/134/0/0
Set backgorund to red: 134 Green: 0 Blue: 0
Message arrived [
emonpixel
background/133/0/0
Message arrived [
emonpixel
background/134/0/0
Regards
Dave
Thanks for the serial OP:
It looks like it’s successfully connecting to your network SiFi, and getting IP address 192.168.10.127, do you see the emonPixel webpage if you browse to this address?
It’s also successfully connecting to your MQTT server and receiving MQTT data to set the background red. All looks like it’s working correctly. You just need to send a fill command to set pixels either clockwise or anticlockwise.
The laser cut CAD design for the case is available on the emonPixel repo:
You can get the dimensions from the CAD design.
Latest prototype now has USB support with direct serial uploading via auto-reset :grinning:
Crowdfunding video has been filmed and is being edited as we speak!
