And finally getting there… something wrong with the update to do with the database changing from root as user to emoncms as user with v9… below is where it goes wrong.
`Update Emoncms database
PHP Warning: mysqli::query(): Couldn’t fetch mysqli in /var/www/emoncms/Lib/dbschemasetup.php on line 24
PHP Warning: mysqli::query(): Couldn’t fetch mysqli in /var/www/emoncms/Lib/dbschemasetup.php on line 98
[“CREATE TABLE app_config (userid int(11), data text) ENGINE=MYISAM”,“CREATE TABLE feeds (id int(11) not null auto_increment primary key, name text, userid int(11), tag text, time int(10), value double, datatype int(11) not null, public tinyint(1), size int(11), engine int(11) not null, processList text) ENGINE=MYISAM”,“CREATE TABLE input (id int(11) not null auto_increment primary key, userid int(11), name text, description text, nodeid text, processList text, time int(10), value float) ENGINE=MYISAM”,“CREATE TABLE schedule (id int(11) not null auto_increment primary key, userid int(11), name varchar(30), expression text, timezone varchar(64) Default ‘UTC’, public tinyint(1)) ENGINE=MYISAM”,“CREATE TABLE users (id int(11) not null auto_increment primary key, username varchar(30), email varchar(30), password varchar(64), salt varchar(32), apikey_write varchar(64), apikey_read varchar(64), lastlogin datetime, admin int(11) not null, gravatar varchar(30), name varchar(30), location varchar(30), timezone varchar(64) Default ‘UTC’, language varchar(5) Default ‘en_EN’, bio text) ENGINE=MYISAM”,“CREATE TABLE rememberme (userid int(11), token varchar(40), expire datetime) ENGINE=MYISAM”,“CREATE TABLE multigraph (id int(11) not null auto_increment primary key, name text, userid int(11), feedlist text) ENGINE=MYISAM”]`
emoncmsdbupdate.php seems to take its login from somewhere up he script chain… is there a config file that already got overwritten with new defaults before the update is made?
Anyway around this, maybe grant user emoncms database access directly?
I kinda bust my local emoncms, its still uploading just fine to emoncms.org, when I login, which I can’t do after upgrade runs as I get the error:
Can't connect to database, please verify credentials/configuration in settings.php Error message: Access denied for user 'emoncms'@'localhost' (using password: YES)
And have to set settings.php back to root/raspberry which is why I am thinking its a DB issue?
When I do login, I don’t see my feeds, the emonpi inputs are all under “unknown”… yeah I broke it…
Any suggestions welcome
Going to sleep on it for now…
