Not necessarily an immediate concern, but just something to bear in mind whilst structuring the more pressing stuff as something we may want down the line. We can use the http “fetch” api, I just assume that at some point someone will want a fully mqtt setup, it seems daft to go to so much effort to ensure emonhub is posting to emoncms by mqtt not http, and then need to use http for something else.
Maybe, but we maybe able to look at expanding the bulk api to help emonhub with this task, maybe change the api to accept text input values as names rather than rejecting all non-numerical data (eg [[ts,id,v1,v2,v3],[ts,id,“power1”,“power2”,“Power3”][ts,id,v1,v2,v3]]). this way emonhub can just buffer the name changes just as it would any values.
Yes I guessed it would be a significant amount of work, I really have no idea at this point how long it might take. But I do know it will be slow getting started due to needing to familiarize myself with the code again. I doubt much will progress that far at all in 2 weeks, but once we’re rolling it will get quicker, just as well really as I’m sure more work will become apparent as we progress. I already had a snagging list for the experimental version when you released the emon-pi version. I will need to find those notes too.
