EDIT: I posted this not fully differentiating in my mind emonhub and emonbase. I understand emonhub software runs on emonbase.
Can I make another suggestion regarding RF.
As much to make a record of fact there’s been issues with 433Mhz RF in noisy environments. (I’m also predicting noise issues for a setup I’m soon building).
- To design for a easy transition between Wire and RF for each connected device, using 4-wire single-core telephone cable.
- In the case of RF to have sent 3 sets of data each time for the 3 most recent packets, 30 seconds worth for 10s updates: this could be an optional mode perhaps, although if this route was taken I’d see advantage in making it default unless there’s a battery consumption issue.
-A: to have memory on the sending side so the 3 most recent packets can be stored and sent each interval, applies to node sensors and the emonTx.
-B: to have emonhub parse the received information correctly relative to timestamps, and bulk upload if necessary.
-C: emonhub made sensitive to version information from transmitting devices. Such that received information can be parsed correctly from legacy and future devices. Also, future devices could communicate two-way with emonhub for settings and modes, in which case version recognition could be useful again.
Does that make sense? I think each step is quite simple to implement.
