Community
OpenEnergyMonitor
OpenEnergyMonitor Community
Emoncms v11 master branch testing before merge to stable
Help with testing of the latest master branch including latest master for all modules would be much appreciated
Hello all!
This update, currently in the master branch for testing, brings together a lot of work over recent months on the emoncms feed engines and related tools, as well as improvements to menu’s & the admin interface.
I’ve put together a short video here of the main changes:
Visible changes to the end user:
Backend changes for the interest of developers
Help with testing of the latest master branch including latest master for all modules would be much appreciated. I will post a second post below with the steps to do this.
Thanks all!
Github v11 pull request Merge to stable v11.0.0 by TrystanLea · Pull Request #1762 · emoncms/emoncms · GitHub
If you would like to test v11 while it’s in the master branch for testing, the steps are as follows:
  1. Make sure that you are up to date with the main updates on the Admin > Update page (click on Full update)
  1. Navigate to Admin > Components and click on the yellow Master button at the top:
  1. Once complete restart the emoncms_mqtt and feedwriter services on the System info page:
That should be it, the latest version should be displayed as 11.0.4 (as of the time of this post) in the emoncms footer.
Seems to work for me, but I had to adjust one of my graphs because one of the lines on it kept returning to zero between measurement points. After removing and re-adding that feed, it seems to work fine again. Anything I should try to break?
Is redis needed to update from Admin?
Thanks for the update! Just a documentation fix: my (mabi) small contribution was on “php7.0 compatibility mode for remember me” not on sendmail support.
@TrystanLea
should that not be 11.0.4 :slight_smile:
Thanks @mjr ok good to know that fixed it, cant think of things specifically but Im sure issues will surface through wider testing :slight_smile:
@mabi yes redis is needed and sorry I will amend above, thanks again!
I’ve got a problem with some of the colours - it’s not new, but is carried over from V10.7.4
The sub-menu item, as in Graph, and when the light sidebar is chosen, is only barely visible when not highlighted (on my LCD laptop screen anyway). It is invisible when highlighted.
A question: In this screenshot
Screenshot 2022-01-05 16:05:49
what is the name of the highlighted Node under the cursor (without cheating by putting the image into Gimp and enhancing it)?
To my (nearly 73 years old) eyes, even the 3 nodes above don’t have sufficient contrast to be easy to read, and “My Graph” in white is almost invisible.
Have you used one of the readability tools to evaluate things like this against WCAG guidelines, for example? These suggest a contrast ratio of 3.5:1.
Using this contrast grid I think the ‘no mouse-over’ ratio is about 1.5, and highlighted it is below 1.1. “My Graphs” comes out at about 1.2.
[Hint: Type each colour in use - background, text, highlighted text - into the text box “Rows & Columns”] and then look up the contrast ratio at the intersection of the appropriate row & column.]
Thanks @Robert.Wall I will have a look at that.
My inputs are not updating now
on emonpi
I have reboot
> service-runner trigger sent for '/var/www/emoncms/scripts/serialmonitor/start.sh 38400 /dev/ttyAMA0'
> |emonPiCM V1.0.0
> |OpenEnergyMonitor.org
> LCD found i2c 0x27
> OK 5 0 0 7 0 7 0 182 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 15 106 0 0 0 40 43 24 5 253 255 0 0 8 0 36 3 0 0 255 255 255 255 0 0 0 0 2 0 0 0 48 117 48 117 48 117 0 0 0 0 (-64)
> OK 5 0 0 7 0 7 0 184 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 1 0 4 0 5 0 109 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 1 0 4 0 5 0 90 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 2 0 4 0 6 0 82 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 2 0 4 0 6 0 80 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 15 109 0 0 0 34 43 85 8 253 255 0 0 76 0 212 2 0 0 255 255 255 255 0 0 0 0 39 0 0 0 48 117 48 117 48 117 0 0 0 0 (-75)
> OK 15 109 0 0 0 7 43 26 5 253 255 255 255 7 0 47 3 0 0 255 255 255 255 0 0 0 0 2 0 0 0 48 117 48 117 48 117 0 0 0 0 (-66)
> OK 5 2 0 4 0 6 0 78 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 2 0 4 0 6 0 83 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 2 0 4 0 6 0 78 89 163 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 2 0 4 0 6 0 60 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 5 2 0 4 0 6 0 86 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 15 111 0 0 0 4 43 23 5 253 255 254 255 7 0 54 3 0 0 255 255 255 255 0 0 0 0 2 0 0 0 48 117 48 117 48 117 0 0 0 0 (-65)
> OK 5 2 0 4 0 6 0 89 89 176 4 48 117 48 117 48 117 48 117 48 117 2 0 0 0 0 0 0 0 237 3 0 0 201 3 0 0 (-0)
> OK 15 112 0 0 0 11 43 15 5 253 255 255 255 7 0 57 3 0 0 255 255 255 255 0 0 0 0 2 0 0 0 48 117 48 117 48 117 0 0 0 0 (-66)
Edit - Formatted text. BT, Moderator
Hi @TrystanLea
Looks pretty good, I can see many of the new features working as described.
As you know I have a pretty hacky Docker container that looks like this. I added the BRANCH section so I could do this testing:
FROM openenergymonitor/emoncms
RUN rm -rf /var/www/emoncms
RUN mkdir /var/www/emoncms
ENV BRANCH master
RUN git clone --branch ${BRANCH} https://github.com/emoncms/emoncms.git /var/www/emoncms
WORKDIR /var/www/emoncms/Modules
RUN git clone --branch ${BRANCH} https://github.com/emoncms/dashboard.git
RUN git clone --branch ${BRANCH} https://github.com/emoncms/graph.git
RUN git clone --branch ${BRANCH} https://github.com/emoncms/app.git
RUN git clone --branch ${BRANCH} https://github.com/emoncms/device.git
RUN git clone --branch ${BRANCH} https://github.com/emoncms/postprocess.git
The only change I needed to make was to use vis.helper.js from the Lib:
David
Got it working but set 110v and reporting 220v why?
Problem was datacodes = h, h, h, h, h change to datacodes = h
Volts are working on EMONTX ok
[interfacers]
[[SerialTx0]]
     Type = EmonHubTx3eInterfacer
      [[[init_settings]]]
           com_port= /dev/ttyUSB0
           com_baud = 115200
      [[[runtimesettings]]]
           pubchannels = ToEmonCMS,
          nodeoffset = 8
[[SerialTx1]]
      [[[init_settings]]]
           com_port= /dev/ttyUSB1
           com_baud = 115200
          nodeoffset = 9
[[SerialTx2]]
      [[[init_settings]]]
           com_port= /dev/ttyUSB2
           com_baud = 115200
          nodeoffset = 10
[[RFM2Pi]]
    Type = EmonHubJeeInterfacer
    [[[init_settings]]]
        com_port = /dev/ttyAMA0
        com_baud = 38400                        # 9600 for old RFM12Pi
        subchannels = ToRFM12,
        group = 210
        frequency = 433
        baseid = 5                              # emonPi / emonBase nodeID
        calibration = 110V                      # (UK/EU: 230V, US: 110V)
        quiet = true                            # Disable quite mode (default enabled) to enable RF packet debugging, show packets which fail crc
        # interval =  300                         # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
    Type = EmonHubMqttInterfacer
    [[[init_settings]]]
        mqtt_host = 127.0.0.1
        mqtt_port = 1883
        mqtt_user = emonpi
        mqtt_passwd = emonpimqtt2016
        pubchannels = ToRFM12,
        subchannels = ToEmonCMS,
       node_format_enable = 1
        nodevar_format_enable = 1
[nodes]
[[5]]
    nodename = emonpi
    [[[rx]]]
       names = HotTub1,HotTub2,power1pluspower2,vrms,t1
       datacode = h
       scales = 1,1,1,0.01,0.01
       units = W,W,W,V,C
[[8]]
    nodename = emontx3cm15
    [[[rx]]]
       names = MSG,Vrms, Grid1, Solar1, Air1, Garage
       scales = 0,1,1,1,1,1
       units = n,V,W,W,W,W
[[9]]
  nodename = emontx3cm16
    [[[rx]]]
       names = MSG,Vrms, Grid2, Solar2, Air2, Furnace
       units = n,V,W,W,W,W
[[10]]
  nodename = emontx3cm17
    [[[rx]]]
       names = MSG,Vrms, Dryer1, Dryer2, Washer, Microwave
       units = n,V,W,W,W,W
[For future reference, when posting code or output, please put 3 ‘backticks’ (normally found at the top left of the keyboard) on a line of their own before the code, and 3 more backticks also on a line of their own after the code:
code
If it is something like php you can add a language identifier after the first 3 backticks: ```php or even ```text if you don’t want any language markup applied. - Moderator (RW) ]
Looks calibration = 110V is not work now
1st no power about 0
2nd power connecred 204v
How do Change it 110v?
OK 5 4 3 28 3 32 6 28 0 226 4 48 117 48 117 48 117 48 117 48 117 3 0 0 0 0 0 0 0 43 40 0 0 13 39 0 0 (-0)
OK 5 204 1 199 1 147 3 164 89 226 4 48 117 48 117 48 117 48 117 48 117 3 0 0 0 0 0 0 0 43 40 0 0 14 39 0 0 (-0)
I see in log:
MainThread Setting RFM2Pi calibration: 110V (2p)
Found ther problem:
Change back to JEELIB and show 110v
With the new emonPiCM software “Native RFM69 (New)” that you chose, there is no need for the complicated and inflexible calibration = 110V, you can calibrate the voltage exactly in emonCMS using Setup →Admin → Serial Monitor, using that to send calibration commands to the emonPiCM in exactly the same way as you would with a programmer and laptop to an emonTx.
The documentation is part of the emonPiCM release: The emonPiCM
Until now only 1 thing: in the dashboard, in element chart of type zoom the 5 and 1 minute zooms did not show a graph…
Thanks @Thelmike I can replicate that bug with the realtime visualisation, will have a look at what’s causing the issue, thanks!
@TrystanLea I have an ugly bug that I’ve found but it’s probably not gating because there’s a workaround.
The masthead sometimes dissappears when I go back to my phone after a while.
That’s clearly unhelpful. I can’t reproduce it, so I can’t tell you if it’s device specific, time related or some other thing. If I were to randomly guess I’d think it was most likely related to the browser snoozing the page and the content being mistakenly dropped.
It still holds the same space on the page, so it’s not being removed from the DOM.
I’m on:
Fairphone 4
Android 11
Firefox Beta
AdGuard AdBlocker
uBlock Origin
I didn’t see this behaviour a week ago or ever before that. Unfortunately since then I’ve changed my phone and my EmonCMS version to the master branch.
I’ve tried to reproduce on my old phone but seeing as I can’t purposefully reproduce it anywhere I don’t know if it’s just not appearing because of that.
I have seen it about five times now. I can always fix it by refreshing the page.
Specifically it’s the div with class menu-top bg-menu-top that is going completely white.
Aha, it looks like it’s related to scrolling and it not re-appearing when you scroll back up. I can now reproduce it reliably and on multiple mobile devices, but not on desktop. It might be related to this change, I’m investigating:
Yep, if I back out the changes to menu.css it stays broken but if I also back out menu.js the menu stays in place when you scroll (as you’d expect) and never goes white.
Of course I’m seeing this because I’m working on mobile with the side menus hidden. On desktop with the side menus hidden I see the menu transition back from the top a fraction of a second (yes, probably 0.3s) after I scroll back to the top.
@nchaveiro I’ve tried to see what I could tweak in menu.js but it’s a bit more than I can absorb as I’m not a front-end developer. I think I’d pretty much just be turning it all on / off which isn’t useful information for you.
Here’s my client info to help (I hope):
Ooh, here’s another client where it’s tripping up:
