Recent changes to emoncms master and associated modules have now been merged to stable and are now available via emonPi/emonbase update.
This release is marked as v10.2.0: Release v10.2.0 · emoncms/emoncms · GitHub
Thankyou to everyone who contributed to development associated with this release!
To update: run emonPi/emonbase update from the Admin tab of emoncms.
CHANGE LOG SUMMARY
Emoncms core 10.2.0:
See full commit log: Merge master to stable by TrystanLea · Pull Request #1510 · emoncms/emoncms · GitHub
- fix ‘unsupported’ process labels in feed view
- stopped input name from overflowing to next line (long input names)
- fix link to graph view from input process labels
- fix configurable feedviewpath
- fix virtual feed lastvalue false issue
- clear feed controls selection after feed deletion
- fix editrealtime vis support
- remove hardcoded /home/pi paths for describe:emonpi/emonbase
- additional checks for redis
- change settings.php errors to settings.ini
- removed admin_db_view.php
- fix feed clear - now resets to zero
- fix order of input processes
- updated default hidden engines
- fix feed engine_hidden issue
- removed deprecated get_magic_quotes
- improved error handling on admin page
- env variable support @borpin @anna_carboncoop
- vis module improvements @alexandrecuer
Graph module v2.0.8
See full commit log: merge master to stable by TrystanLea · Pull Request #116 · emoncms/graph · GitHub
- js implementation of csv downloader
- remove unit from legend
- reinstate automatic feed selection at start
App module v2.1.0
See full commit log: Merge master to stable by TrystanLea · Pull Request #132 · emoncms/app · GitHub
- remove openevse app - as same as myelectric2
- fix feed selection to allow feeds with same name but different tags
- fix tablet css to resize graph in portrait mode
- add extra check for empty data
- added caching param to list.json requests
- fix: mysolarpv graph not correctly updated
Dashboard module v2.0.5
See full commit log: Merge master to stable by TrystanLea · Pull Request #248 · emoncms/dashboard · GitHub
- new kwhperiod widget thanks to @danbates
- dashboard fullscreen property
- battery widget NaN value fix
Backup module v2.2.1
See full commit log: Merge master to stable by TrystanLea · Pull Request #54 · emoncms/backup · GitHub
- fix disk check in usb-import
- old data folders archived rather than deleted in usb-import
- updated installation process to use php ini drop in and new backup location, thanks @borpin
- updated readme to reflect new installation process
DemandShaper module v1.2.0
See full commit log: Merge master to stable by TrystanLea · Pull Request #40 · emoncms/demandshaper · GitHub
- add wifi-relay support
- use user timezone
EmonScripts v1.0.3-beta
See full commit log: Merge master to stable by TrystanLea · Pull Request #76 · openenergymonitor/EmonScripts · GitHub
- chmod +x on the install/emoncms_emonpi_modules.sh
- Use /var/opt/emoncms/backup for backup files
- load update config from install config
- move backup module config.cfg file creation to backup module install script
