I’m now on 10.2.0 image from 2017.
I was thinking about upgrade to 2019 image but inside backup section this message :
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 1 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 3 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 5 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 6 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 7 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 9 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 11 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 16 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 19 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 22 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 25 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 28 in /home/pi/backup/backup-module/backup_controller.php on line 25
Deprecated : Comments starting with ‘#’ are deprecated in /home/pi/backup/config.cfg on line 31 in /home/pi/backup/backup-module/backup_controller.php on line 25
Warning : Cannot modify header information - headers already sent by (output started at /home/pi/backup/backup-module/backup_controller.php:25) in /var/www/emoncms/index.php on line 377
what shoud I do ?
thx
