DIYBMS v4
Hi @stuart, if you have time, i sent few questions towards you :stuck_out_tongue: thx
Unfortunately manual is the only way possible (at present). I’m trying to make it easier with the next revision of the controller board, but suspect it will still be a manual process.
Hi @donnib I missed that post sorry.
Is the voltage accurate whilst not balancing?
Have you calibrated the module using the web interface - to set the calibration multiplier?
@stuart thx, no biggie, yes it seems to measure correct when not in bypass. It pulls down the voltage around 0.07V but if you think that’s within limits that’s good. Here is a video showing the setup : 4 November 2020 - YouTube
btw i tried flashing one v4 cell module with master and it fails all the time when it checks the flash, but i guess you are aware of that ?
That shouldn’t be happening, no problems with flashing any of the modules I have.
Hi, I’ve prepared a 14S100P battery controlled with your cells manager and a M5stack a controller filling an influx database.
Thanks for all the work done and for sharing it.
I’ve started some tests and actually have two questions :
  • how should I calibrate each modules to have consistant and accurate measurements ?
  • is the bank voltage measured and shared performed with bypass active when it is activated ? I clearly see tensions drops when in bypass mode, what’s making the overall tensions evaluation not consistent.
    bypass impact snapshot
    Thanks for your tips
Measure the cell the module is monitoring (directly at the cell terminals) using a quality multimeter. Enter that voltage reading into the “Modules” page on the controller web interface and click “calculate” to automatically set the calibration value. Then click Save.
You should find the default configuration value is fairly close.
The bank voltage simply adds up the voltage each module measures and shows it on screen. It will be bouncing around during balancing.
An external current shunt and voltage measurement board/device is currently being worked on which would sit outside of the modules and measure the whole pack.
Hi
It might be that this already has been answered and in that case as do apologise in advance.
Compiling cell module worked fine but not the controller. Have tried both on windows and on mac but getting a number of errors. I compared my version with posting from a couple of days ago and I’m running exactly the same version. Probably I’m missing something simple but can’t find what.
This is the error:
In file included from src/PacketRequestGenerator.cpp:1:0:
include/PacketRequestGenerator.h:26:34: error: expected ')' before '*' token
      PacketRequestGenerator(Queue* requestQ) {_requestq=requestQ;}
include/PacketRequestGenerator.h:44:5: error: 'Queue' does not name a type
     Queue* _requestq;
src/PacketRequestGenerator.cpp: In member function 'void PacketRequestGenerator::pushPacketToQueue()':
src/PacketRequestGenerator.cpp:168:3: error: '_requestq' was not declared in this scope
   _requestq->push(&_packetbuffer);
src/PacketRequestGenerator.cpp: In member function 'uint16_t PacketRequestGenerator::QueueLength()':
src/PacketRequestGenerator.cpp:173:10: error: '_requestq' was not declared in this scope
   return _requestq->getRemainingCount();
src/PacketRequestGenerator.cpp:174:1: warning: control reaches end of non-void function [-Wreturn-type]
*** [.pio/build/esp8266_d1minipro/src/PacketRequestGenerator.cpp.o] Error 1
src/SoftAP.cpp: In static member function 'static void DIYBMSSoftAP::SetupAccessPoint(AsyncWebServer*)':
src/SoftAP.cpp:91:41: warning: 'SPIFFS' is deprecated (declared at /Users/matced/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:269): SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
   _myserver->serveStatic("/softap.htm", SPIFFS, "/softap/softap.htm").setTemplateProcessor(DIYBMSSoftAP::TemplateProcessor);
In file included from include/DIYBMSServer.h:21:0,
                 from src/DIYBMSServer.cpp:26:
     Queue* _requestq;
src/DIYBMSServer.cpp: In static member function 'static void DIYBMSServer::StartServer(AsyncWebServer*)':
src/DIYBMSServer.cpp:863:42: warning: 'SPIFFS' is deprecated (declared at /Users/matced/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:269): SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
   _myserver->serveStatic("/default.htm", SPIFFS, "/default.htm").setTemplateProcessor(DIYBMSServer::TemplateProcessor);
src/DIYBMSServer.cpp:864:37: warning: 'SPIFFS' is deprecated (declared at /Users/matced/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:269): SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
   _myserver->serveStatic("/files/", SPIFFS, "/files/").setCacheControl("max-age=600");
                 from src/main.cpp:106:
     Queue* _requestq;
src/main.cpp:111:1: error: 'Queue' does not name a type
 Queue requestQueue(sizeof(packet), 16, FIFO);
src/main.cpp:113:54: error: 'requestQueue' was not declared in this scope
 PacketRequestGenerator prg = PacketRequestGenerator(&requestQueue);
src/main.cpp: In function 'void timerTransmitCallback()':
src/main.cpp:250:8: error: 'requestQueue' was not declared in this scope
   if (!requestQueue.isEmpty())
src/main.cpp: In function 'void setup()':
src/main.cpp:1162:8: warning: 'SPIFFS' is deprecated (declared at /Users/matced/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:269): SPIFFS has been deprecated. Please consider moving to LittleFS or other filesystems. [-Wdeprecated-declarations]
   if (!SPIFFS.begin())
*** [.pio/build/esp8266_d1minipro/src/DIYBMSServer.cpp.o] Error 1
*** [.pio/build/esp8266_d1minipro/src/main.cpp.o] Error 1
This error has not been reported before - its generally referring to “queue” errors which is a 3rd party library from GitHub - SMFSW/Queue: Queue handling library (designed on Arduino)
Perhaps try a “clean” and “build” again and see what happens?
The automated check/build Travis system reports a good build/compile, so the code must be okay.
https://travis-ci.org/github/stuartpittaway/diyBMSv4Code/builds/740927771
Any mention of problems with SPIFFS can be ignored.
Thanks for quick reply. It seems that SMFSW library just about 24 hours ago released a new version and renamed their class from “Queue” to “cppQueue”…
Will try to rename and see of it works and maybe create a pull request on that change since I think there will be more people affected by this
Renaming Queue to cppQueue worked and it is now compiling as it should.
If you are interested I have a patch file for the change (just s couple of lines to update) :slight_smile:
Yes please
A patch can downloaded from here: Dropbox - Rename_class_Queue_to_cppQueue.diff - Simplify your life
Hi, it turns out that the problem I was putting down to a bad install of VS, are exactly the same as you are having.
Not being very aware of VS, how do I apply the Patch? I’ve downloaded it, but where does it go?
Or wait for Stuart to update his code?
Hi Simon
You need to apply the patch using git commands, I’ll guess that Stuart will fix it rather soon.
If you feeling adventurous you can always replace the references to “Queue” with “cppQueue” manually, only three places or so to update.
I’m not 100% sure that everything is working in my setup yet, have controller installed but not able to see any of my cell modules, that is my next “battle” to take on.
I’m soon of to bed (late here) so might be a while before any more reply.
would it be possible to add voltage sensing wires that are independent from the wires used for balancing?
Possibly but you would need a different circuit board to do that.
