I added a couple of wvc700 inverters and just tried collecting data with Stephen’s wvc bash script and it looks like it’s misreading the inverters.
I have compiled the C code version posted here setting it to the 0d20 inverter, and 0c65 inverter so you can see it shows output of that inverter over 450W while the wvc bash script is showing incorrect temps and output wattages.
~/Testing/WVC-Inverter-R2-R3-HC-12–and–Modem$ ./wvc-hc12-0d20
DC voltage : 27.79
AC voltage : 244.79
DC current : 17.90
Energy kWh : 2.43
Output Watt : 455.8
Temperature : 64.00
DC voltage : 27.68
AC voltage : 244.79
DC current : 17.90
Energy kWh : 2.43
Output Watt : 457.6
Temperature : 64.00
~/Testing$ ./wvc-hc12-0c65
DC voltage : 27.79
AC voltage : 243.96
DC current : 17.80
Energy kWh : 2.38
Output Watt : 455.0
Temperature : 65.00
DC voltage : 27.79
AC voltage : 243.96
DC current : 17.90
Energy kWh : 2.38
Output Watt : 457.6
Temperature : 65.00
~/Testing/WVC-Inverter-R2-R3-HC-12–and–Modem$ ./wvc /dev/ttyUSB0 ./wvc.ini 20111839 hc
Using ModemID 20 11 18 39 at port /dev/ttyUSB0 Using inverter list ./wvc.ini on a hc Device
virtural port /dev/ttyWVCDUMMY0
Inverter Type WVC700 R3
no input from inverter 40000D02
no COM detected
restarting COM
started
f220111839e91b000040000d20650ad05f4c06fe00f1000011ce1900
Inverter ID 40000D20
Temp 527.53
VDC 27.68
VAC 243.96
ADC 17.90
AAC 1.86833
Watt1 3.839
Watt2 61.696
Watt3 7.936
Panel Efficiency .91
f220111839e91b000040000c65650adb5f4c06f400ed000011c61964
Inverter ID 40000C65
Temp 507.05
VDC 27.79
VAC 243.96
ADC 17.80
AAC 1.86505
Watt1 4.863
Watt2 60.672
Watt3 56.832
AC watts 910.79
DC watts 990.13
Overall Efficiency .91
f220111839e91b000040000d02650d6d2ff9005a6d590000010c1004
Inverter ID 40000D02
Temp 30.73
VDC 34.37
VAC 122.81
ADC .90
AAC .21822
Watt1 9.874
Watt2 22.893
Watt3 38.358
Panel Efficiency .86
f220111839e91b000040000d20650adb5f9f06fe00f1000011ce1964
Temp 527.53
VDC 27.79
VAC 244.79
ADC 17.90
AAC 1.86200
Watt1 3.839
Watt2 61.696
Watt3 7.936
f220111839e91b000040000c65650ad05f4c06f400ed000011c61964
Temp 507.05
VDC 27.68
VAC 243.96
ADC 17.80
AAC 1.86505
Watt1 4.863
Watt2 60.672
Watt3 56.832
Panel Efficiency .92
AC watts 804.25
DC watts 1096.04
Overall Efficiency .73
