Using dial widget to display daily charge
I would like to add a dial widget to display kWh per day. I already use a cumulative kWh dial but I have not been successful in adding a daily resetting dial.
This is probably a common requirement so I hope someone can share details on how this was achieved.
Current display:
It’s not a dial, just a value but the ‘kWh period’ dashboard item should do what you need:
Screenshot 2020-09-09 at 01.54.15
