After upgrading from version 10.1.3 to 10.2.3 this evening (then running the db upgrade, flushing redis, restarting Apache,) I can see that my external services are correctly sending data into my install. I can view the data on the Visualization area as well. But if I try to access a feed directly, I just get the error “Not Acceptable” in the browser, and this in the emoncms logs:
2020-07-13 02:36:04.508|INFO|index.php|graph/125
2020-07-13 02:36:04.512|WARN|index.php|406 Not Acceptable|graph/125
If I click on any feed from the “Feeds” page, then it gives the error. However, if I view the feed from the “Visualizations” page, then it displays successfully.
Just tried it again this evening on 10.2.4, and am experiencing the same thing.
406 Not Acceptable
URI not acceptable. Graph cannot respond to “127” .
The emoncms.log file just says:
2020-08-10 01:09:45.261|INFO|index.php|graph/127
2020-08-10 01:09:45.264|WARN|index.php|406 Not Acceptable|graph/127
I did some poking around and found that I needed to manually install the graph module. In the past I hadn’t been using it, my old settings.php file had
$feedviewpath = “vis/auto?feedid=”;
I didn’t think anything of that when I did the upgrade; the new one defaults to
feedviewpath = “graph/”
Which apparently doesn’t work unless you manually also install the graph module.
So, it’s working for me now. But something that I’ll need to make a note of for future upgrades.
