Updating Emoncms Git error
Continuing the discussion from Emoncms v9.8.25:
I Tried this on a fairly fresh install on DietPi and I get this.
root@DietPi-Emoncms:/var/www/emoncms # git pull
remote: Counting objects: 239, done.
remote: Compressing objects: 100% (10/10), done.
remote: Total 239 (delta 128), reused 129 (delta 126), pack-reused 102
Receiving objects: 100% (239/239), 54.73 KiB | 0 bytes/s, done.
Resolving deltas: 100% (176/176), completed with 34 local objects.
From https://github.com/emoncms/emoncms
   b8a10f9..d1bce95  stable             -> origin/stable
 * [new branch]      device-integration -> origin/device-integration
   efe402a..f6b0220  device-support     -> origin/device-support
   69476c9..255a422  master             -> origin/master
 * [new tag]         9.8.25             -> 9.8.25
 * [new tag]         9.8.27             -> 9.8.27
Updating b8a10f9..d1bce95
error: Your local changes to the following files would be overwritten by merge:
        Lib/tablejs/custom-table-fields.js
        Modules/input/Views/input_api.php
        Modules/input/input_methods.php
        Modules/input/input_model.php
        Modules/input/locale/fr_FR/LC_MESSAGES/messages.mo
        Modules/input/locale/fr_FR/LC_MESSAGES/messages.po
        Modules/process/process_model.php
        Modules/process/process_processlist.php
        Modules/user/user_model.php
        Modules/user/user_schema.php
        index.php
        scripts/phpmqtt_input.php
Please commit your changes or stash them before you merge.
Aborting
Have I done something wrong?
Can anyone suggest what I should do?
(disclaimer I am not a git expert)
Are any of these files something you’ve modified for your own use?
    index.php
if those files are not something you’ve modified then they can be ignored and overwritten.
Look up git reset and git clean commands. (these are done from the same /var/www/emoncms directory). One of those should remove or ignored those files so the git pull will work.
I don’t think you did anything wrong. It is just one of those git issues that pop up once in awhile!
Hi Jon, no nothing I have changed. A very clean install this one!
that is a good thing. much easy to fix!
read thru this post:
Thanks. Looked up a couple of such items and settled on
git fetch --all
git reset --hard origin/stable
Seems to have done the trick with no adverse effects!
