Update emonSD-17thOct19 on new install
How do I go about getting get emonSD-17thOct19 updated on a new install
LAST ENTRIES ON THE LOG FILE
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
ERROR: emonSD base image old or undefined...update will not continue
See latest verson: https://github.com/openenergymonitor/emonpi/wiki/emonSD-pre-built-SD-card-Download-&-Change-Log
Stopping update
Can’t see any information in the link to github and a search on the forum hasn’t turned much up other than to only use the update button through the webadmin and not to use apt.
thanks
That should update - @TrystanLea?
Sometimes it is an issue with pulling the safe update file from github. Can you try again please?
One of the problems with the update script, is it doesn’t allow for an empty file returned by this command.
I have added an Issue
I manually ran the curl command and have now run the update from the admin page and it is now working.
It seems to be a transient error that GitHub sometimes does not return the contents.
We have seen a few emonhub issues on update so please check everything is OK.
All seems well.
