Ok so a bit of context, I use a Victron system with the Victron battery monitor reporting battery discharge which is a negative figure (while the charge is a positive number) I noticed the solar battery application is not designed to accept negative numbers. .eg battery discharge shows 0 when I am discharging the battery because the battery discharge values are negative.
Is there a way to work around this?
