[Moved discussion to new thread as unrelated to topic of original thread]
Hi there,
I also am having issues seeing Inputs. I have an old EmonTxv3, and a emonbase with Raspberry Pi B and RMF12B. My config looks like the below. I changed the baud to 9600, and the node and pi are running at 868MHZ. Struggled to follow the above discussion, can someone help?
Chris
[hub]
loglevel = DEBUG
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[RFM2Pi]]
Type = EmonHubJeeInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 9600 # 9600 for old RFM12Pi
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
group = 210
frequency = 868
baseid = 5 # emonPi / emonBase nodeID
quiet = true # Report incomplete RF packets (no implemented on emonPi)
calibration = 230V # (UK/EU: 230V, US: 110V)
# interval = 0 # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 1
nodevar_format_enable = 1
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 1 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 30 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
[nodes]
## See config user guide: http://github.com/openenergymonitor/emonhub/blob/master/configuration.md
[[5]]
nodename = emonpi
[[[rx]]]
units = W,W,W,V,C,C,C,C,C,C,p
[[6]]
nodename = emontxshield
[[[rx]]]
names = power1, power2, power3, power4, vrms
datacode = h
scales = 1,1,1,1,0.01
units =W,W,W,W,V
[[7]]
nodename = emontx4
[[[rx]]]
units =W,W,W,W,V,C,C,C,C,C,C,p
[[8]]
nodename = emontx3
[[[rx]]]
[[9]]
nodename = emontx2
[[[rx]]]
datacode = h
[[10]]
nodename = emontx1
[[[rx]]]
datacode = h
[[11]]
nodename = 3phase
[[[rx]]]
names = powerL1, powerL2, powerL3, power4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6
datacode = h
scales = 1,1,1,1,0.01,0.1,0.1,0.1,0.1,0.1,0.1
[[19]]
nodename = emonth1
[[[rx]]]
names = temperature, external temperature, humidity, battery
datacode = h
scales = 0.1,0.1,0.1,0.1
units = C,C,%,V
[[20]]
nodename = emonth2
[[[rx]]]
datacode = h
units = C,C,%,V
[[21]]
nodename = emonth3
[[[rx]]]
datacode = h
units = C,C,%,V
[[22]]
nodename = emonth4
[[[rx]]]
datacode = h
units = C,C,%,V
[[23]]
nodename = emonth5
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h,h,h,h,L
scales = 0.1,0.1,0.1,0.1,1
units = C,C,%,V,p
[[24]]
nodename = emonth6
[[[rx]]]
units = C,C,%,V,p
[[25]]
nodename = emonth7
[[[rx]]]
units = C,C,%,V,p
[[26]]
nodename = emonth8
[[[rx]]]
units = C,C,%,V,p
