Switching from Git master back to stable
Hi
I have all the components of Emoncms currently running Master to enable my system to function correctly. I see stable now has all the master updates I need.
What is the simplest way to switch back to stable. Do I have to go through all the components individually?
Ian
I use this script. It can be used to switch between master/stable. If there is not a stable branch it just fails that command with an error.and continues. Does the main emoncms repo and then loops through the Modules.
Run a full update after.
#!/bin/sh
# emoncms switch branch script
EMONCMS_DIR=/var/www/emoncms
BRANCH=stable
printf "***** git -C $EMONCMS_DIR checkout $BRANCH *****\n"
sudo git -C $EMONCMS_DIR checkout $BRANCH
sudo git -C $EMONCMS_DIR status
for M in $EMONCMS_DIR/Modules/*
  do
    if [ -d "$M/.git" ]; then
      printf "\nUpdate emoncms/$(basename $M)....\n"
      printf "***** git -C $M checkout $BRANCH *****\n"
      sudo git -C $M checkout $BRANCH
      sudo git -C $M status
    fi
  done
In the home directory
nano update.sh
paste the code above (uaually a right click) and then CTL+x and ‘y’ to save
Then… (make the script executable & run it)
chmod +x update.sh
./update.sh
