Thanks Brian
Update log has this line.
mv: cannot stat '/etc/cron.daily/logrotate': No such file or directory
Is this a problem?
Thanks Brian
Is this a problem?
I moved this to a new topic.
Probably not as it is trying to move a file that has already been moved I suspect.
Can you please do this command for me please and post the output.
ls -la /etc/cron.hourly/
cheers
I have looked at the code, and no check is made to see if the logrotate system has already been modified for emoncms. Because of this it attempts to move a file that will not exist on second running.
I have opened an issue but your system should be fine
