Good spot. I had a mental note in my head that I was getting around that by setting BOOT0 manually with a jumper, powering off and on the board and then its ready for STLINK upload. Double checked it now and it does work. But I’m not actually sure why I didn’t include a pin for NRST as that would of course be easier… I do have it routed to a pin on the RPI header so I can always test with that.
Yes, I guess if you’re using individual flying leads and pins it doesn’t matter too much. I think you do need to run Vcc as well (3.3V definitely NOT 5V) so that the programmer can see the target is powered (and see what voltage it runs at). I’m still a bit nervous about having 5V anywhere near that header… but so long as everyone knows what they’re doing it should be ok.
Thanks @dBC, I’ve modified the board to include NRST and routed 3.3V to the UART header for easy access. I’ve put the 3.3v line through a jumper as the UART 3.3v will otherwise potentially conflict with the 3.3v on the board from the VREG, not sure if that’s an issue or not.
I also realise I had left in a 3.3v track to the RPI header which was not needed now removed.
It shouldn’t be necessary, but I remember one user who did this found the op.amp. was taking off and oscillating, so don’t take anything for granted! You may well find a much smaller value or even a Zobel network might be needed - it all depends on what the centre rail looks like as a load on the op.amp.
Thanks @Robert.Wall I will keep an eye on it. I though I had better include it on the design just in case.
Using the forum search tool uncovers Learn | OpenEnergyMonitor which you of course added and I’ve been reading through some of the older threads too.
So you inspired me to look into how this serial programming stuff works, it all seemed just a bit too flexible to be true. As I mentioned before I’ve only ever used the SWD interface for flashing, so I’ve not tried any of this and it’s based solely on some quick research this morning.
I came across AN2606. Section 6 seems to be the relevant one for your device. The good news is it does indeed poll multiple UARTs for an incoming 0x7f and then uses that UART. The bad news is, it requires the UARTs to be mapped to known pins (PA9 and PA10 for UART1 and PA14 and PA15 for UART2).
In your experiment here, you used PA9 and PA10 (UART1). Are you sure when you tried UART2 you used PB3 and PB4, and not PA14 and PA15?
The schematic has the FTDI programmer header connected to PB3 and PB4. Once your f/w is up and running it can easily map those pins to UART2, but until then I think the bootloader will have UART2 mappped to PA14 and PA15 (at least according to AN2606).
And on the Vcc stuff…
I think this is the critical point I missed, and I agree it’s a great goal to be able to program it with your existing USB<->UART programmer.
I think you should be ok there. For both the ST-LINK programmers and the serial programmer the 3.3V pin is an output from the target and an input to the programmer (it’s not used to power the target).
In the case of the ST-LINK programmer, it’s pin 1 on CN4 in your schematic excerpt here. Although as you point out, on the ST-LINK strip programmer that pin is disabled (hence your n/a). On more advanced ST-LINK programmers, the programmer senses the voltage at that pin to know the target’s Vcc. I guess for the Nucleo strip programmer they can safely assume everything is running at 3.3V and it clearly works fine without it.
Checking the schematic of your shop-sold serial programmer here it looks like that 3.3V pin is how the programmer gets powered, i.e. the target board is powering the Vcc of the SILabs CP2101 via that pin.
Thanks for spotting and looking into it @dBC. I did not test PB3 and PB4 unfortunately but really appreciate you looking into it. I will test with the f303re I have here tomorrow. Il have to get some mini wire links on those small stm pins on the prototype to test or send for another.
No problem. I’ll be interested to hear what you find, but it seems impossible for the UART to be plumbed to two sets of pins at once so I suspect PB3/PB4 won’t work, unless there’s a typo in AN2606.
The other thing I noticed in AN2606 is that the bootloader only polls two UARTs (UART1 and UART2), so if you ever do go the three UART approach I suggested above, be sure to use UART3 for something that you don’t plan booting over (OneWire or ST-LINK debug printfs).
[EDIT] - and the bootloader is burnt in at the factory and is un-erasable. So once you get the pin issue sorted, I think you should be able to use either method (ST-LINK Vs Serial) to program your virgin chips as they arrive from Farnell etc.
I’ve updated the design to use PA9 & PA10 for UART
The DS18B20 has now been moved to UART3:PB10, the pulse counter to PB15 and LED to PB14
Ragworm have kindly allowed me to update the order that was in process.
I’m happy to say everything worked with the first prototype PCB!
With special thanks to @danbates designer of emonDC for helping to assemble the board with his SMT soldering skills and @dBC for finding the issues fixed above that meant all of this worked.
So far we have tested:
- Power supply
- ST-LINK firmware upload
- Serial firmware upload
- RaspberryPi automated serial upload procedure
- LED indicator
- 8MHZ HSE oscillator
- CT and ACAC power measurement
- DS18B20 temperature sensing input
- Pulse counting input
- Datalogging to emoncms via raspberrypi serial and emonhub
All working well.
Here are a couple of pictures of the board, http://ragworm.eu/ where very kind to update the order with the fixed design and then fit it on one of their black soldermask board runs which looks particularly nice:
Here’s the latest hardware schematic and board files:
https://github.com/openenergymonitor/STM32/tree/master/Hardware/5
and 3CT energy monitoring firmware for the STM32F303CBT6 chip:
https://github.com/openenergymonitor/STM32/tree/master/Emon3CT_CB
The next step is to test the filter design in more detail and run the unit in parallel with an EmonTx. @danbates is looking into firmware libraries for RFM69 support and we will be revisiting the requirements of a fully featured board as discussed here STM32 Hardware Development.
Overall very happy with how this first prototype turned out
Hi Trystan
Do you have a BOM for the prototype board. I might give it ago as part of my continual learning curve.
Ian
Hello Ian, Great! I haven’t put a BOM together for this design yet. I ordered the stm32f303cbt6 from RS: https://uk.rs-online.com/web/p/microcontrollers/8107660 and this crystal https://uk.rs-online.com/web/p/crystal-units/8136031. The rest of the components were all in the office and we just read off the schematic.
I could order more PCB’s if there was interest? but we will be moving forward soon with additions
I’ve been helping @TrystanLea with the RFM69 side of things. I’ve made some good progress, with special thanks to @dBC for help over pm.
I’ve written a guide to the implementation which can be found here:
. STM32/RFM69.md at master · openenergymonitor/STM32 · GitHub
This is compatible with LowPowerLab radio packets. I’ve looked at JeeLib packets and think I have a good understanding of the main differences, yet can’t quite get it working. So there’s something I’m missing there. For the ‘jeecompat’ project, I have a github branch here.
I’ve brought together the emon3CT and RFM69 code here:
. https://github.com/openenergymonitor/STM32/tree/master/Emon3CT_RFM69
For the TxShield, it might be worthwhile developing a bit-banging SPI approach to accessing the RFM69 module.
If testing the emon3CT sketch on a TxShield, only CT2 and CT4 are available.
Just a heads up to anyone who might have cloned my 1-wire uart off-load example above (@TrystanLea @danbates): you get better results if you enable “Single Sample” on the uart(s) involved:
When I get a chance I’ll write up a spiel on why - complete with scope traces, and I’ll freshen the tar file with that and a few other features.
I was reminded of this project by @Robert.Wall WiFi only EmonTX - #5 by Robert.Wall.
It seems this design is wedded to an RPi setup? What is the rationale for that design decision?
I’d like to see the option for a WiFi setup. Maybe a daughter board that could plug into the RPi header for a Wemos D1?
Hello all,
First post here.
Has an external voltage reference been considered for the VDDA supply on the STM32, e.g. LT6656?
https://www.analog.com/media/en/technical-documentation/data-sheets/6656fc.pdf
It has five times lower ppm/deg C drift (20ppm vs 100ppm), with 0.1% accuracy, so should improve accuracy, at least related to the reference error. I guess if calibration is performed the 3% inherent accuracy of the STM32 internal reference will be overcome, but not everyone has access to an accurate multi-meter. Having an accurate external reference on the VDDA means the internal reference would not be needed to be used in any calculation of the supply voltage, and hence full scale value.
I’ve bought an STM32F303 Nucleo board and intend to get an energy monitor working using it. My background is RF engineering, I am not a programmer, although I do dabble, so I wont be able to help much with the software. I’d be happy to help with the hardware design if I can be of help with the project.
It looks like great progress has been made!
Best regards,
Paul
Welcome Paul,
I’ve been sifting through the stm32 manuals and followed most of the design recommendations. This has ended up with my choosing a voltage reference, it’s 0.1% and 50ppm.
MCP1501T-33E.pdf (1.1 MB)
The decision for this one is made mostly on cost… I’ll check the one you posted now…
Seems no longer supplied by farnell! Seems the price is a fair bit higher too.
I’ve put a solder junction on the prototype to bring either 3.3V source into VDDA, so we can keep exploring the options.
