I need a second controller.
Unfortunately minimum 5 controller have to be ordered.
I have a cpl file which contains all parts.
And the controller could be ordered completely soldered.
( I do not want to solder anything. Its cheap with JLC.
And when I compare the time I need… economical nonsens. )
Exept the part “unused header” and the 3 pin header in the left upper sector.
Both are not used for my purposes.
So if there are some guys in who also need a controller.
I would order 5 and could give 4 away.
For manufacturing cost ( Expect around 50€ ) plus shipping.
@JoshyJS I am keen on a Controller as I have the same issue, minimum order of 5, can you confrim are you saying each controller would be 50euro or the whole order of 5 is 50euro and you would pro rata the cost out ?,
Nein. Jedes fertig bestückte Board kostet all in all mit Weiterversand etwa 50€.
Was fehlt ist die RGB LED. Und den unused Header und den 3 pol Header habe ich nicht verbaut.
5 Stück kosten komplett etwa 200€.
Dann muss ich in Deutschland noch verpacken und weiter schicken.
Also gut 50€ all in all.
Die LED kostet nur ein paar Cent.
Dooferweise hat die nur ein Shop in Polen.
Der 15€ Versand haben will…
Yes my family is German, we live in South Africa, unfortunatly I was never taught to speak it, but I can understand German, but South Africa german is slighty diffrent to the Hochdeutch in German which makes it harder to understand.
I am still interested , you would need to find out the cost to send to South Africa registered Airmail.
You don’t by any change had a shund board as well ?
Ah OK. No problem. I´m from time to time in Namibia.
And along the coastline in the north German is also spoken.
A little old fashioned. But however…
I will be on holiday till end of August.
And at first I wanted to know if there is someonhe who needs a board or two.
I only need one. And I do not want to solder to much.
If I would take the board only with the SMD parts the board costs about 25€.
But If you want to have all the relays, terminals, pinheader etc. its about 40€.
And I need the shipping and packing costs.
Be so kind and give me your adress.
I will figure out what is possible to do.
And sorry. I have no shund. No need for.
I do not want to cut off the system and my Inverter measures the voltage and current.
In the moment I have no economical solution to sent to SA.
Maybe I find one who takes it with him to Joburg.
Hey Marius, Yes not probelm, I have an amorex global shopper account, Joshy will be sending it from GER to my Frankfurt address, currently it looks like it’s going to be about R400 shipping. and we can just split that. @JoshyJS So we’ll be looking for 2 units then
Sorry for intruding, Joshy, but if possible I’d love to jump into this wagon and get two controller boards for myself if there’s still room available. I’m in Italy, so forwarding / shipping shouldn’t be much of a problem.
I’m not in a hurry, but joining a group order would save me a possible huge headache
