Maybe shipping costs will make it uneconomic to send to NZ. I will probably want two myself for a couple of projects, so I’m thinking now I will order 5 populated boards, hopefully sell the others more locally…
If you like I can sent you the modified bom and cpl for the V4.4
That would be great, thanks - much appreciated.
Hi you all,
please contact stewart. He can offer actual boards and has a shipping method for 12€.
Maybe its not more expensive than with me.
If the solution does not fit inform me.
BR,
Joshy
Hi Joshy,
I just followed this dikussion. did you ordered the controller or not? If so, would there still be one left? I’ve been dealing with the topic for a few months and would like to try the DiyBMS. unfortunately, the minimum order quantities of 5 are currently too much for me. If that works the way I imagine, then I would also order more. I also come from Germany. Since the shipping is then not too expensive. ![]()
Have one left.
Do you still have one left?
greetings Markus from Germany
Guckt ihr private Nachricht bitte.
In the meantime I ordered some V4.4 on my own.
If someone still needs one contact me.
In Germany I can ship for 5,49€.
In the EU we have to check.
I also have some Attinys left, 1.9f and Controller holder with clear cover.
And maybe in the next days some short data cables.
Best Regards
Hi Joshy,
You ordered v4.4 from JLCPCB ?
At the moment, 3.3 ohm resistors are not available.But when I try to order v4.4, I can’t see how the elements are arranged in the preview, they do not match the board. The problem affects both the new version of the controller and the modules
Does not matter.
- Take an other 3.3 ohm resistor. Does not change the function.
- The engineer at JLC puts the parts to the right position.
