Somebody managed to sync all to a local emoncms?
Is the somebody out there who managed to sync the data from emoncms.org to a local running emoncms SD?
Till 2 days trying but only a big mess is the result, nothing works as it should.
This should work fine. What is the result that you are seeing? Is this without the settings.php file that you mentioned in your last post? If settings.php is present it will likely mess things up.
Thank you TrystanLea,
I’ve deleted settings.php and reached the point of allmost succeed.
