Reading data from energy meter through modbus protocol
Hi All,
Im trying to read holding register values of Elmeasure LG1129 and BM5140 energy meter using Modbus protocol through Arduino. I used RS485 to TTL converter between Energy meter and Arduino Mega but I haven’t succeeded. Please help me
This is the board i used for RS485 communication:
https://robokits.co.in/control-boards/interface-boards/max485-ttl-to-rs485-converter-module?gclid=EAIaIQobChMIhMDH_d2J5gIVizUrCh2MKwVHEAQYAiABEgKyZvD_BwE
Typical circuit diagram connection:
Some reference Code I got from forum and burned the same in Arduino:
#include <SimpleModbusMaster.h>
#define baud 9600
#define timeout 1000
#define polling 2000 // the scan rate
#define retry_count 10
#define TxEnablePin 2
#define TOTAL_NO_OF_REGISTERS 31
enum
  PACKET1,
  PACKET2,
  TOTAL_NO_OF_PACKETS // leave this last entry
// Create an array of Packets to be configured
Packet packets[TOTAL_NO_OF_PACKETS];
// Masters register array
unsigned int regs[TOTAL_NO_OF_REGISTERS];
void setup()
  // Initialize each packet
  Serial.begin(9600);
Serial1.begin(9600);
  modbus_construct(&packets[PACKET1], 1, READ_HOLDING_REGISTERS, 40133, 2, 10);
  modbus_construct(&packets[PACKET2], 1, READ_HOLDING_REGISTERS, 40135, 2, 12);
  modbus_configure(&Serial1, baud, SERIAL_8E1, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);
void loop()
  modbus_update();
  int A, B, C, D, E, F, G, H, I, J, K, L, M, N, O;
  A = regs[10];
  B = regs[12];
  Serial.print("A = ");
  Serial.println(A);
  Serial.print("B = ");
  Serial.println(B);
  Serial.println("============================================");
  delay(1000);
  Serial.print("successful_requests: ");
  Serial.println(packets[PACKET1].successful_requests);
  Serial.println("                        || ");
  Serial.print("failed_requests: ");
  Serial.print(packets[PACKET1].failed_requests);
  Serial.print("exception_errors: ");
  Serial.print(packets[PACKET1].exception_errors);
  Serial.print("connection: ");
  Serial.print(packets[PACKET1].connection);
 delay(1000);
Also Please clarify me this line of code what does number 10 represents although we have register number starting from 0 to 30
I’ve tried to find documentation for that library, but I cannot find anything that explains in words what each API call does, and it appears that the library is no longer supported and maintained.
I can suggest that either you look inside the library and work out what each parameter does, or look at using a better supported library.
Have you searched here? There are many threads mentioning Modbus.
To prevent duplication, I’m locking this thread.
