So I pulled up the debug option in OpenEVSE to see if maybe I could see what the EVSE was seeing when it tried to connect via MQTT.
"mqtt_connected":0}
{"amp":0,"voltage":240,"power":0,"pilot":40,"temp":387,"temp_max":387,"temp1":387,"temp2":false,"temp3":false,"temp4":false,"state":254,"status":"disabled","flags":513,"vehicle":0,"colour":5,"manual_override":0,"freeram":174564,"divertmode":1,"srssi":-60,"time":"2023-07-15T23:44:59Z","local_time":"2023-07-15T17:44:59-0600","offset":"-0600","session_elapsed":0,"session_energy":0,"total_energy":157.2954046,"total_day":0.223048336,"total_week":23.13938604,"total_month":43.64040468,"total_year":43.64040468,"total_switches":35,"elapsed":0,"wattsec":0,"watthour":157295.4046}
{"session_elapsed":0,"session_energy":0,"total_energy":157.2954046,"total_day":0.223048336,"total_week":23.13938604,"total_month":43.64040468,"total_year":43.64040468,"total_switches":35}
{"emoncms_connected":0,"emoncms_message":"Failed to connect"}
So, from what I can see. It looks like it EmonCMS is reporting it failed to connect (or OpenEVSE is). Though, my understanding is the “0” is a response that it connects. Anyone have any incite here?
@borpin I know you used Proxmox with a container and EmonCMS. Not sure if you used OpenEVSE and connected it via MQTT or not. I’ve tried this with both a container and VM and it’s the same either way which is odd. It’s like something has changed under the hood in EmonCMS here because I would expect through a VM and Ubuntu Server 22.04 to be as it would on a stand alone system.
