Older Samsung EHS Mono - SNET-Pro (non-NASA) for monitoring?
Hi All,
New user here, hoping to get some advice from a community of experts.
I inherited an ASHP through a property purchase a few years ago, so a complete novice who has been attempting to self-educate. I’ve made good gains to-date from research and trial-and-error control panel adjustments etc. and am now at the point where I need a view of system data over time.
I recently found @SarahH 's thread “Monitoring Your Samsung ASHP Controller” which has been a great source of info, but it’s written around the newer MIM-E03*N controllers and SNET-Pro2. My heat pump is an older generation, so I’m not sure how much of it applies.
My system:
  • Outdoor unit: Samsung RC090MHXEA (9kW monobloc, UK)
  • Control kit: no model number visible on my indoor board. Samsung’s installation manual for this outdoor unit names the MIM-E03A as the required control kit, and my control kit manual is reference DB98-34412A(1)
  • Service documentation I’ve seen describes this range as dating from 2010-2015
What I want: read-only monitoring so I can understand how the unit behaves against outdoor temperature over time (flow/return temperatures, pump state, anything the controller reports). I’m not looking to control it, and I’d like to avoid changing any settings through the software.
What I’ve found:
  • A reply in that thread suggests older non-NASA heat pumps might need SNET-Pro rather than SNET-Pro2, which also connects at F1/F2.
  • Samsung’s own SNET-Pro download page describes it as service software for DVM Plus I/II/III and FJM systems. It doesn’t mention EHS heat pumps, so I can’t tell whether it supports my unit.
  • The heat-pump-specific ESPHome NASA component lists newer MIM-E03CN/DN/EN boards and says older non-NASA systems aren’t supported.
Questions
(disclaimer - I’ve been using Claude AI to help me with this - some of these are AI-suggested - don’t assume I have any significant system/install knowledge! Although on IT/Network/Software side in general I’m relatively competent)
  1. Has anyone used SNET-Pro (not Pro2) with an RC090MHXEA, or any EHS Mono with a MIM-E03A?
  2. Does that generation use NASA, NonNASA, or something else on F1/F2?
  3. If it does work, did a cheap USB RS-485 adapter on F1/F2 (similar to the Waveshare one in the thread) do the job, and what data did you get (water temperatures, flow, pump state, refrigerant-side values)?
  4. Is it safe to leave an adapter connected for a monitoring run, and any tips on avoiding accidental writes?
  5. If SNET-Pro doesn’t support these units, did anyone get data out via Samsung’s Modbus module, or is clip-on flow/return sensors plus a CT meter on the heat pump circuit the sensible fallback?
Would be grateful for any advice from the experienced community here, before I go ahead and spend some time & money on a basic proof-of concept.
Thanks,
Mark
Welcome @markjwilliams321 - unfortunately I couldn’t find anything specific for that module. In the service manual, there is a reference to RS485 inputs. My suggestion would be to pick up an RS485 adapter and see if any of the existing integrations work at all. Hopefully they wouldn’t have changed the register layout between generations. Not too helpful, but that would be a reasonable place to start :slight_smile:
Thanks for the reply @awjlogan - I’ve gone ahead and done just that, so will feed back here on results, after attempting setup and initial test etc. over the weekend - I’m starting from scratch here so need to configure the end-to-end (mini PC, VM, software setup etc, as well as the RS485), so bear with me!
Fingers crossed, but if this method is a complete dead end, my fallback option will be to see what I can achieve with isolated component monitoring (Shelly clamps or something similar).
Probably too late for you @markjwilliams321, but I’d go along with @awjlogan’s reply.
The SNET-Pro2 software predates 2015 so there’s a good chance that it is compatible with your HP.
Your MIM-E03A (if that is indeed what you have) supports F1/F2 communication with the OU, and I’m pretty confident that SNET-Pro2 will talk to it.
You could test proof-of-concept at pretty low cost - just wire a cheap (£50 or so) RS485-to-Ethernet (or USB) adapter to F1/F2, and (if you can) temporarily move your laptop close enough to the adapter to plug in the adapter Ethernet (or USB) cable, download a VCOM and SNET-Pro2 onto your laptop (both free), set up a suitable IP address for the adapter (if Ethernet), and you should be in business.
If SNET-Pro 2 (or SNET-Pro) don’t work, there are Python NASA sniffers around that would allow you basic monitoring of the controller outputs that you are looking for. No need (yet) for a mini-PC or a VM…
Not too late @SarahH and thanks for replying - I’d already committed on the miniPC/VM setup for broader Home Assistant capabilities through the house. That’s all set up and working fine.
I then got hit by an unexpected issue - my Samsung control panel lost all power! So far, I know it’s a downstream component which is drawing excess power and shorting the panel out - I haven’t resolved that issue yet, that’s the current priority…
Once this is resolved, I’ll pick up again on the monitoring. Fingers crossed, you are right about SNET-Pro2 compatability.
Will post back here when I have a tangible update to share - thanks all :+1:
