Hi guys, all of a sudden every feeds have stopped to refresh their values. Inputs seem ok. I’ve tried to restart the raspberry, power down and up few times. The system is updated, there’s space on the SD. Please let me know if you need anything (logs etc) that helps in resolving this. Thank you in advance
Logs would be useful, recent emonhub.log and emoncms.log entries can be found via emoncms (assuming you have the config module installed).
Is this a self-build or an emonSD?
Where does the data come from?
Is the feedwriter used? if so is that running? (used for low-write emoncms and it’s status can be checked on the admin page if in use)
You say the inputs look ok, are the “updated” values in green? Is there any red “Error” tags in the input process lists?
Where are you seeing the “feeds have stopped” ? is it on a dashboard/visualisation or on the feeds page?
Hi, thank you for your reply.
I’m using an emonSD, october '17 release, update to 9.8.30. Data come from emontx and 2 units of emonth. It has worked well since 2016, until 4 days ago when something probabilly went wrong.
Here is my Server info:
Server Information
Emoncms Version low-write 9.8.30 : 2018.05.08 Modules Administration : App v1.1.0 : Backup v1.1.2 : EmonHub Config v1.0.0 : Dashboard v1.3.0 : EventProcesses : Feed : Graph v1.2.0 : Input : postprocess : CoreProcess : Schedule : setup : sync : Time : User : Visualisation : WiFi v1.1.1 Buffer loading… Writer Daemon is running with sleep 60s Server OS Linux 4.9.35+ Host emonpi emonpi (127.0.1.1) Date 2018-06-19 06:30:04 UTC Uptime 06:30:04 up 18:14, 0 users, load average: 0,72, 1,12, 1,12 HTTP Server Apache/2.4.10 (Raspbian) HTTP/1.1 CGI/1.1 50666 MySQL Version 5.5.60-0+deb8u1 Host localhost (127.0.0.1) Date 2018-06-19 06:30:03 (UTC 00:00) Stats Uptime: 65613 Threads: 2 Questions: 1421 Slow queries: 0 Opens: 59 Flush tables: 1 Open tables: 52 Queries per second avg: 0.021 Redis Version 2.8.17 Host localhost:6379 (127.0.0.1) Size 249 keys (526.52K) Uptime 0 days MQTT Version 1.4.14 Host localhost:1883 (127.0.0.1) Pi CPU Temp 49.77°C Release emonSD-26Oct17 File-system Set root file-system temporarily to read-write, (default read-only) Memory RAM Used: 47,98% Total: 481,7 MB Used: 231,12 MB Free: 250,57 MB Disk Mount Stats / Used: 60,53% Total: 3,33 GB Used: 2,02 GB Free: 1,15 GB /boot Used: 36,27% Total: 59,95 MB Used: 21,74 MB Free: 38,2 MB /home/pi/data Used: 27,28% Total: 968,33 MB Used: 264,18 MB Free: 654,16 MB PHP Version 5.6.33-0+deb8u1 (Zend Version 2.6.0) Modules apache2handler : bcmath : bz2 : calendar : Core v5.6.33-0+deb8u1 : ctype : curl : date v5.6.33-0+deb8u1 : dba : dio v0.0.4RC4 : dom v20031129 : ereg : exif v1.4 : fileinfo v1.0.5 : filter v0.11.0 : ftp : gettext : hash v1.0 : iconv : json v1.3.6 : libxml : mbstring : mcrypt : mhash : mosquitto v0.3.0 : mysql v1.0 : mysqli v0.1 : openssl : pcre : PDO v1.0.4dev : pdo_mysql v1.0.2 : Phar v2.0.2 : posix : readline v5.6.33-0+deb8u1 : redis v2.2.7 : Reflection : session : shmop : SimpleXML v0.1 : soap : sockets : SPL v0.2 : standard v5.6.33-0+deb8u1 : sysvmsg : sysvsem : sysvshm : tokenizer v0.1 : wddx : xml : xmlreader v0.1 : xmlwriter v0.1 : Zend OPcache v7.0.6-devFE : zip v1.12.5 : zlib v2.0 :
Client Information
HTTP Browser Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.87 Safari/537.36 Screen Resolution 1920 x 1080 Window Size 1597 x 733
Inputs are ok, green values and no error tag, just red n/a values on the feed I’ve created.
Here is part of the emonhub.log
2018-06-19 06:24:19,457 DEBUG RFM2Pi 8670 NEW FRAME : OK 8 184 253 105 1 17 0 1 0 218 102 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-53)
2018-06-19 06:24:19,468 DEBUG RFM2Pi 8670 Timestamp : 1529389459.46
2018-06-19 06:24:19,470 DEBUG RFM2Pi 8670 From Node : 8
2018-06-19 06:24:19,472 DEBUG RFM2Pi 8670 Values : [-584, 361, 17, 1, 263.3, 300, 300, 300, 300, 300, 300, 1]
2018-06-19 06:24:19,475 DEBUG RFM2Pi 8670 RSSI : -53
2018-06-19 06:24:19,477 DEBUG RFM2Pi 8670 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:24:19,479 DEBUG RFM2Pi 8670 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:24:19,629 DEBUG MQTT Publishing: emon/emontx3/power1 -584
2018-06-19 06:24:19,642 DEBUG MQTT Publishing: emon/emontx3/power2 361
2018-06-19 06:24:19,657 DEBUG MQTT Publishing: emon/emontx3/power3 17
2018-06-19 06:24:19,666 DEBUG MQTT Publishing: emon/emontx3/power4 1
2018-06-19 06:24:19,677 DEBUG MQTT Publishing: emon/emontx3/vrms 263.3
2018-06-19 06:24:19,688 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-06-19 06:24:19,704 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-06-19 06:24:19,712 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-06-19 06:24:19,718 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-06-19 06:24:19,723 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-06-19 06:24:19,729 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-06-19 06:24:19,734 DEBUG MQTT Publishing: emon/emontx3/pulse 1
2018-06-19 06:24:19,739 DEBUG MQTT Publishing: emon/emontx3/rssi -53
2018-06-19 06:24:19,745 INFO MQTT Publishing: emonhub/rx/8/values -584,361,17,1,263.3,300,300,300,300,300,300,1,-53
2018-06-19 06:24:21,937 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 18 31 9 67 233 114 118 97 156 77 217 42 185 231 119 157 195 9 59 154 187 (-102)
2018-06-19 06:24:26,138 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 7 231 150 135 252 134 227 115 1 253 255 254 8 205 88 217 107 129 183 199 0 (-100)
2018-06-19 06:24:26,973 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 7 182 126 252 55 252 116 125 191 191 101 216 87 191 219 223 171 54 190 170 251 (-97)
2018-06-19 06:24:27,709 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 3 120 112 180 164 188 4 75 24 141 162 84 198 168 59 123 189 16 115 191 110 (-100)
2018-06-19 06:24:28,564 DEBUG emoncmsorg Buffer size: 4
2018-06-19 06:24:29,433 DEBUG RFM2Pi 8671 NEW FRAME : OK 8 192 253 105 1 16 0 1 0 216 102 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-52)
2018-06-19 06:24:29,443 DEBUG RFM2Pi 8671 Timestamp : 1529389469.43
2018-06-19 06:24:29,446 DEBUG RFM2Pi 8671 From Node : 8
2018-06-19 06:24:29,448 DEBUG RFM2Pi 8671 Values : [-576, 361, 16, 1, 263.28000000000003, 300, 300, 300, 300, 300, 300, 1]
2018-06-19 06:24:29,450 DEBUG RFM2Pi 8671 RSSI : -52
2018-06-19 06:24:29,453 DEBUG RFM2Pi 8671 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:24:29,455 DEBUG RFM2Pi 8671 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:24:29,625 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 21 46 50 150 8 207 38 72 216 202 254 35 227 93 189 192 193 34 248 219 43 (-102)
2018-06-19 06:24:29,782 DEBUG MQTT Publishing: emon/emontx3/power1 -576
2018-06-19 06:24:29,789 DEBUG MQTT Publishing: emon/emontx3/power2 361
2018-06-19 06:24:29,794 DEBUG MQTT Publishing: emon/emontx3/power3 16
2018-06-19 06:24:29,800 DEBUG MQTT Publishing: emon/emontx3/power4 1
2018-06-19 06:24:29,805 DEBUG MQTT Publishing: emon/emontx3/vrms 263.28
2018-06-19 06:24:29,811 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-06-19 06:24:29,816 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-06-19 06:24:29,822 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-06-19 06:24:29,827 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-06-19 06:24:29,833 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-06-19 06:24:29,839 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-06-19 06:24:29,849 DEBUG MQTT Publishing: emon/emontx3/pulse 1
2018-06-19 06:24:29,865 DEBUG MQTT Publishing: emon/emontx3/rssi -52
2018-06-19 06:24:29,871 INFO MQTT Publishing: emonhub/rx/8/values -576,361,16,1,263.28,300,300,300,300,300,300,1,-52
2018-06-19 06:24:31,524 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 23 29 255 242 115 70 118 67 231 244 91 42 217 111 143 61 211 60 190 114 25 (-100)
2018-06-19 06:24:34,607 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 15 183 78 78 24 73 255 226 14 200 255 251 239 15 84 230 133 238 105 19 191 (-98)
2018-06-19 06:24:36,261 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 26 64 240 238 182 79 156 45 247 222 176 33 159 64 184 36 203 184 93 69 200 (-100)
2018-06-19 06:24:36,451 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 15 42 253 255 220 129 61 172 223 250 119 154 40 100 215 248 0 237 31 241 187 (-101)
2018-06-19 06:24:38,313 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 28 6 27 252 8 5 163 193 9 118 252 255 196 49 55 216 8 19 221 223 59 (-100)
2018-06-19 06:24:38,643 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 1 239 217 35 12 41 189 117 215 187 223 158 200 124 196 127 78 121 134 57 30 (-101)
2018-06-19 06:24:39,278 DEBUG RFM2Pi 8672 NEW FRAME : OK 8 187 253 104 1 16 0 0 0 227 102 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-53)
2018-06-19 06:24:39,289 DEBUG RFM2Pi 8672 Timestamp : 1529389479.28
2018-06-19 06:24:39,291 DEBUG RFM2Pi 8672 From Node : 8
2018-06-19 06:24:39,293 DEBUG RFM2Pi 8672 Values : [-581, 360, 16, 0, 263.39, 300, 300, 300, 300, 300, 300, 1]
2018-06-19 06:24:39,296 DEBUG RFM2Pi 8672 RSSI : -53
2018-06-19 06:24:39,299 DEBUG RFM2Pi 8672 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:24:39,302 DEBUG RFM2Pi 8672 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:24:39,421 DEBUG MQTT Publishing: emon/emontx3/power1 -581
2018-06-19 06:24:39,427 DEBUG MQTT Publishing: emon/emontx3/power2 360
2018-06-19 06:24:39,432 DEBUG MQTT Publishing: emon/emontx3/power3 16
2018-06-19 06:24:39,437 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-06-19 06:24:39,443 DEBUG MQTT Publishing: emon/emontx3/vrms 263.39
2018-06-19 06:24:39,448 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-06-19 06:24:39,466 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-06-19 06:24:39,473 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-06-19 06:24:39,485 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-06-19 06:24:39,497 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-06-19 06:24:39,528 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-06-19 06:24:39,546 DEBUG MQTT Publishing: emon/emontx3/pulse 1
2018-06-19 06:24:39,556 DEBUG MQTT Publishing: emon/emontx3/rssi -53
2018-06-19 06:24:39,567 INFO MQTT Publishing: emonhub/rx/8/values -581,360,16,0,263.39,300,300,300,300,300,300,1,-53
2018-06-19 06:24:39,565 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 14 24 126 186 217 166 203 28 138 175 7 206 80 77 141 38 181 209 31 241 127 (-101)
2018-06-19 06:24:40,572 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 14 227 63 190 246 112 143 47 240 247 199 13 103 136 105 138 104 184 65 244 (-101)
2018-06-19 06:24:43,381 DEBUG RFM2Pi 8673 NEW FRAME : OK 23 246 0 0 0 45 2 29 0 1 0 0 0 (-69)
2018-06-19 06:24:43,390 DEBUG RFM2Pi 8673 Timestamp : 1529389483.38
2018-06-19 06:24:43,392 DEBUG RFM2Pi 8673 From Node : 23
2018-06-19 06:24:43,395 DEBUG RFM2Pi 8673 Values : [24.6, 0, 55.7, 2.9000000000000004, 1]
2018-06-19 06:24:43,397 DEBUG RFM2Pi 8673 RSSI : -69
2018-06-19 06:24:43,399 DEBUG RFM2Pi 8673 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:24:43,402 DEBUG RFM2Pi 8673 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:24:43,651 DEBUG MQTT Publishing: emon/emonth5/temperature 24.6
2018-06-19 06:24:43,667 DEBUG MQTT Publishing: emon/emonth5/external temperature 0
2018-06-19 06:24:43,672 DEBUG MQTT Publishing: emon/emonth5/humidity 55.7
2018-06-19 06:24:43,681 DEBUG MQTT Publishing: emon/emonth5/battery 2.9
2018-06-19 06:24:43,687 DEBUG MQTT Publishing: emon/emonth5/pulsecount 1
2018-06-19 06:24:43,693 DEBUG MQTT Publishing: emon/emonth5/rssi -69
2018-06-19 06:24:43,698 INFO MQTT Publishing: emonhub/rx/23/values 24.6,0,55.7,2.9,1,-69
2018-06-19 06:24:44,105 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 7 254 42 245 163 142 185 153 197 173 54 32 133 80 38 188 236 148 166 253 21 (-101)
2018-06-19 06:24:45,456 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 6 15 215 103 63 117 254 107 127 65 35 255 194 91 196 130 5 149 8 82 110 (-99)
2018-06-19 06:24:49,226 DEBUG RFM2Pi 8674 NEW FRAME : OK 8 188 253 103 1 16 0 0 0 212 102 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-52)
2018-06-19 06:24:49,251 DEBUG RFM2Pi 8674 Timestamp : 1529389489.23
2018-06-19 06:24:49,255 DEBUG RFM2Pi 8674 From Node : 8
2018-06-19 06:24:49,258 DEBUG RFM2Pi 8674 Values : [-580, 359, 16, 0, 263.24, 300, 300, 300, 300, 300, 300, 1]
2018-06-19 06:24:49,260 DEBUG RFM2Pi 8674 RSSI : -52
2018-06-19 06:24:49,262 DEBUG RFM2Pi 8674 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:24:49,264 DEBUG RFM2Pi 8674 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:24:49,456 DEBUG MQTT Publishing: emon/emontx3/power1 -580
2018-06-19 06:24:49,461 DEBUG MQTT Publishing: emon/emontx3/power2 359
2018-06-19 06:24:49,467 DEBUG MQTT Publishing: emon/emontx3/power3 16
2018-06-19 06:24:49,472 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-06-19 06:24:49,478 DEBUG MQTT Publishing: emon/emontx3/vrms 263.24
2018-06-19 06:24:49,483 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-06-19 06:24:49,490 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-06-19 06:24:49,495 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-06-19 06:24:49,500 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-06-19 06:24:49,506 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-06-19 06:24:49,511 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-06-19 06:24:49,517 DEBUG MQTT Publishing: emon/emontx3/pulse 1
2018-06-19 06:24:49,522 DEBUG MQTT Publishing: emon/emontx3/rssi -52
2018-06-19 06:24:49,540 INFO MQTT Publishing: emonhub/rx/8/values -580,359,16,0,263.24,300,300,300,300,300,300,1,-52
2018-06-19 06:24:51,517 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 18 101 110 203 59 112 228 188 110 34 115 179 115 237 201 83 211 191 54 235 174 (-99)
2018-06-19 06:24:55,511 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 28 170 254 191 131 219 52 21 41 215 188 22 253 250 253 166 199 67 77 221 (-100)
2018-06-19 06:24:56,174 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 1 159 87 30 55 227 169 159 122 186 245 214 150 150 194 201 46 63 5 202 72 (-99)
2018-06-19 06:24:56,413 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 7 178 104 179 123 159 63 184 135 10 216 190 250 0 245 107 108 254 253 191 234 (-101)
2018-06-19 06:24:58,649 DEBUG emoncmsorg Buffer size: 4
2018-06-19 06:24:59,081 DEBUG RFM2Pi 8675 NEW FRAME : OK 8 182 253 105 1 16 0 1 0 228 102 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-52)
2018-06-19 06:24:59,101 DEBUG RFM2Pi 8675 Timestamp : 1529389499.08
2018-06-19 06:24:59,103 DEBUG RFM2Pi 8675 From Node : 8
2018-06-19 06:24:59,105 DEBUG RFM2Pi 8675 Values : [-586, 361, 16, 1, 263.4, 300, 300, 300, 300, 300, 300, 1]
2018-06-19 06:24:59,119 DEBUG RFM2Pi 8675 RSSI : -52
2018-06-19 06:24:59,121 DEBUG RFM2Pi 8675 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:24:59,123 DEBUG RFM2Pi 8675 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:24:59,342 DEBUG MQTT Publishing: emon/emontx3/power1 -586
2018-06-19 06:24:59,348 DEBUG MQTT Publishing: emon/emontx3/power2 361
2018-06-19 06:24:59,354 DEBUG MQTT Publishing: emon/emontx3/power3 16
2018-06-19 06:24:59,360 DEBUG MQTT Publishing: emon/emontx3/power4 1
2018-06-19 06:24:59,366 DEBUG MQTT Publishing: emon/emontx3/vrms 263.4
2018-06-19 06:24:59,371 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-06-19 06:24:59,377 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-06-19 06:24:59,382 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-06-19 06:24:59,388 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-06-19 06:24:59,401 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-06-19 06:24:59,416 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-06-19 06:24:59,422 DEBUG MQTT Publishing: emon/emontx3/pulse 1
2018-06-19 06:24:59,434 DEBUG MQTT Publishing: emon/emontx3/rssi -52
2018-06-19 06:24:59,450 INFO MQTT Publishing: emonhub/rx/8/values -586,361,16,1,263.4,300,300,300,300,300,300,1,-52
2018-06-19 06:25:03,749 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 11 18 27 231 182 191 82 36 35 74 151 166 114 175 164 9 190 255 160 102 124 (-97)
2018-06-19 06:25:04,639 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 15 243 0 214 185 244 222 61 123 214 136 117 92 255 111 89 248 25 25 235 241 (-98)
2018-06-19 06:25:04,994 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 9 232 211 102 182 119 189 210 194 36 100 61 (-98)
2018-06-19 06:25:05,550 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 109 0 134 163 180 95 234 139 103 178 235 132 247 191 5 237 232 71 115 118 (-98)
2018-06-19 06:25:07,085 DEBUG RFM2Pi 8676 NEW FRAME : OK 24 253 0 0 0 104 2 26 0 1 0 0 0 (-78)
2018-06-19 06:25:07,102 DEBUG RFM2Pi 8676 Timestamp : 1529389507.09
2018-06-19 06:25:07,105 DEBUG RFM2Pi 8676 From Node : 24
2018-06-19 06:25:07,123 DEBUG RFM2Pi 8676 Values : [25.3, 0, 61.6, 2.6, 1]
2018-06-19 06:25:07,125 DEBUG RFM2Pi 8676 RSSI : -78
2018-06-19 06:25:07,143 DEBUG RFM2Pi 8676 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:25:07,151 DEBUG RFM2Pi 8676 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:25:07,313 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 9 22 22 182 110 160 159 138 67 100 219 30 215 115 89 35 32 107 143 253 206 (-97)
2018-06-19 06:25:07,344 DEBUG MQTT Publishing: emon/emonth6/temperature 25.3
2018-06-19 06:25:07,367 DEBUG MQTT Publishing: emon/emonth6/external temperature 0
2018-06-19 06:25:07,372 DEBUG MQTT Publishing: emon/emonth6/humidity 61.6
2018-06-19 06:25:07,377 DEBUG MQTT Publishing: emon/emonth6/battery 2.6
2018-06-19 06:25:07,391 DEBUG MQTT Publishing: emon/emonth6/pulsecount 1
2018-06-19 06:25:07,402 DEBUG MQTT Publishing: emon/emonth6/rssi -78
2018-06-19 06:25:07,417 INFO MQTT Publishing: emonhub/rx/24/values 25.3,0,61.6,2.6,1,-78
2018-06-19 06:25:09,274 DEBUG RFM2Pi 8677 NEW FRAME : OK 8 181 253 114 1 14 0 0 0 209 102 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-52)
2018-06-19 06:25:09,360 DEBUG RFM2Pi 8677 Timestamp : 1529389509.27
2018-06-19 06:25:09,363 DEBUG RFM2Pi 8677 From Node : 8
2018-06-19 06:25:09,365 DEBUG RFM2Pi 8677 Values : [-587, 370, 14, 0, 263.21, 300, 300, 300, 300, 300, 300, 1]
2018-06-19 06:25:09,400 DEBUG RFM2Pi 8677 RSSI : -52
2018-06-19 06:25:09,407 DEBUG RFM2Pi 8677 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:25:09,409 DEBUG RFM2Pi 8677 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:25:09,525 DEBUG MQTT Publishing: emon/emontx3/power1 -587
2018-06-19 06:25:09,554 DEBUG MQTT Publishing: emon/emontx3/power2 370
2018-06-19 06:25:09,603 DEBUG MQTT Publishing: emon/emontx3/power3 14
2018-06-19 06:25:09,630 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 30 118 53 249 251 180 116 27 245 115 19 140 199 45 28 197 135 59 74 169 40 (-100)
2018-06-19 06:25:09,645 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-06-19 06:25:09,663 DEBUG MQTT Publishing: emon/emontx3/vrms 263.21
2018-06-19 06:25:09,679 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-06-19 06:25:09,698 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-06-19 06:25:09,719 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-06-19 06:25:09,734 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-06-19 06:25:09,747 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-06-19 06:25:09,752 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-06-19 06:25:09,767 DEBUG MQTT Publishing: emon/emontx3/pulse 1
2018-06-19 06:25:09,773 DEBUG MQTT Publishing: emon/emontx3/rssi -52
2018-06-19 06:25:09,794 INFO MQTT Publishing: emonhub/rx/8/values -587,370,14,0,263.21,300,300,300,300,300,300,1,-52
2018-06-19 06:25:11,061 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 0 119 89 154 118 189 210 101 37 59 139 114 100 107 214 136 128 46 238 207 138 (-101)
2018-06-19 06:25:11,499 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 25 242 172 254 78 202 108 184 64 70 255 249 143 123 221 252 115 129 192 113 39 (-99)
2018-06-19 06:25:13,510 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 15 95 253 143 111 15 127 246 253 152 9 125 110 199 142 198 167 202 142 29 185 (-98)
2018-06-19 06:25:18,937 DEBUG RFM2Pi 8678 NEW FRAME : OK 8 179 253 56 1 16 0 0 0 147 102 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-52)
2018-06-19 06:25:18,947 DEBUG RFM2Pi 8678 Timestamp : 1529389518.94
2018-06-19 06:25:18,949 DEBUG RFM2Pi 8678 From Node : 8
2018-06-19 06:25:18,952 DEBUG RFM2Pi 8678 Values : [-589, 312, 16, 0, 262.59000000000003, 300, 300, 300, 300, 300, 300, 1]
2018-06-19 06:25:18,954 DEBUG RFM2Pi 8678 RSSI : -52
2018-06-19 06:25:18,957 DEBUG RFM2Pi 8678 Sent to channel(start)' : ToEmonCMS
2018-06-19 06:25:18,959 DEBUG RFM2Pi 8678 Sent to channel(end)' : ToEmonCMS
2018-06-19 06:25:19,076 DEBUG MQTT Publishing: emon/emontx3/power1 -589
2018-06-19 06:25:19,089 DEBUG MQTT Publishing: emon/emontx3/power2 312
2018-06-19 06:25:19,099 DEBUG MQTT Publishing: emon/emontx3/power3 16
2018-06-19 06:25:19,117 DEBUG MQTT Publishing: emon/emontx3/power4 0
2018-06-19 06:25:19,125 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 31 19 99 101 155 210 167 19 167 238 70 117 155 71 128 125 213 195 139 234 77 (-99)
2018-06-19 06:25:19,127 DEBUG MQTT Publishing: emon/emontx3/vrms 262.59
2018-06-19 06:25:19,133 DEBUG MQTT Publishing: emon/emontx3/temp1 300
2018-06-19 06:25:19,139 DEBUG MQTT Publishing: emon/emontx3/temp2 300
2018-06-19 06:25:19,144 DEBUG MQTT Publishing: emon/emontx3/temp3 300
2018-06-19 06:25:19,150 DEBUG MQTT Publishing: emon/emontx3/temp4 300
2018-06-19 06:25:19,155 DEBUG MQTT Publishing: emon/emontx3/temp5 300
2018-06-19 06:25:19,161 DEBUG MQTT Publishing: emon/emontx3/temp6 300
2018-06-19 06:25:19,166 DEBUG MQTT Publishing: emon/emontx3/pulse 1
2018-06-19 06:25:19,172 DEBUG MQTT Publishing: emon/emontx3/rssi -52
2018-06-19 06:25:19,177 INFO MQTT Publishing: emonhub/rx/8/values -589,312,16,0,262.59,300,300,300,300,300,300,1,-52
2018-06-19 06:25:19,930 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 4 185 244 149 216 188 88 247 233 177 133 (-101)
2018-06-19 06:25:23,009 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 17 239 117 8 181 160 36 167 175 131 53 180 120 93 180 191 189 68 219 247 70 (-98)
Nothing stands out as an issue, can you please clarify this point
what are you looking at there? Is it the feeds page or a processlist on the inputs page?
when was this feed created? does it relate to when the data stopped?
What is the status of these services?
sudo systemctl status {feedwriter,emonhub,mosquitto,redis-server,mqtt_input}
[edit - command corrected]
Feeds page
since the first installation
● feedwriter.service - LSB: feedwriter script daemon
Loaded: loaded (/etc/init.d/feedwriter)
Active: active (running) since Mon 2018-06-18 12:16:54 UTC; 23h ago
Process: 1991 ExecStart=/etc/init.d/feedwriter start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/feedwriter.service
└─2145 /usr/bin/php -f /var/www/emoncms/scripts/feedwriter.php
Jun 18 12:16:46 emonpi feedwriter[1991]: Log is turned off
Jun 18 12:16:46 emonpi feedwriter[1991]: Starting RPI
Jun 18 12:16:54 emonpi systemd[1]: Started LSB: feedwriter script daemon.
● emonhub.service - LSB: Start/stop emonHub
Loaded: loaded (/etc/init.d/emonhub)
Active: active (running) since Mon 2018-06-18 12:15:40 UTC; 23h ago
Process: 474 ExecStart=/etc/init.d/emonhub start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/emonhub.service
└─637 python /usr/share/emonhub/emonhub.py --config-file /home/pi/...
Jun 18 12:15:36 emonpi sudo[489]: root : TTY=unknown ; PWD=/ ; USER=root ; ...ub
Jun 18 12:15:36 emonpi sudo[489]: pam_unix(sudo:session): session opened fo...0)
Jun 18 12:15:37 emonpi sudo[489]: pam_unix(sudo:session): session closed fo...ot
Jun 18 12:15:37 emonpi sudo[545]: root : TTY=unknown ; PWD=/ ; USER=root ; ...og
Jun 18 12:15:37 emonpi sudo[545]: pam_unix(sudo:session): session opened fo...0)
Jun 18 12:15:37 emonpi sudo[545]: pam_unix(sudo:session): session closed fo...ot
Jun 18 12:15:38 emonpi sudo[568]: root : TTY=unknown ; PWD=/ ; USER=root ; ...ub
Jun 18 12:15:38 emonpi sudo[568]: pam_unix(sudo:session): session opened fo...0)
Jun 18 12:15:38 emonpi sudo[568]: pam_unix(sudo:session): session closed fo...ot
Jun 18 12:15:38 emonpi sudo[590]: root : TTY=unknown ; PWD=/ ; USER=root ; ...ub
Jun 18 12:15:38 emonpi sudo[590]: pam_unix(sudo:session): session opened fo...0)
Jun 18 12:15:39 emonpi sudo[590]: pam_unix(sudo:session): session closed fo...ot
Jun 18 12:15:40 emonpi emonhub[474]: Starting OpenEnergyMonitor emonHub: em...k.
Jun 18 12:15:40 emonpi systemd[1]: Started LSB: Start/stop emonHub.
● mqtt.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
● redis.service
● mqtt_input.service - Emoncms MQTT Input Script
Loaded: loaded (/etc/systemd/system/mqtt_input.service; enabled)
Active: active (running) since Mon 2018-06-18 12:16:45 UTC; 23h ago
Docs: https://github.com/emoncms/emoncms/blob/master/docs/RaspberryPi/MQTT.md
Main PID: 1989 (php)
CGroup: /system.slice/mqtt_input.service
└─1989 /usr/bin/php /var/www/emoncms/scripts/phpmqtt_input.php
Jun 18 12:16:45 emonpi systemd[1]: Started Emoncms MQTT Input Script.
Hint: Some lines were ellipsized, use -l to show in full.
Sorry that command should have said “mosquitto” not “mqtt” (I’ve corrected it now) so could you check the mosquitto service with sudo systemctl mosquitto status although I’m pretty sure it’s ok if you are seeing the inputs update.
I’ve also changed the command to use the more accurate "redis-serverrather than justredis` since this doesn’t work the same as it does on my system (Debian9 running just emoncms not emonSD)
pb66@test2:~$ sudo systemctl status {feedwriter,emonhub,mqtt,redis}
Unit feedwriter.service could not be found.
Unit emonhub.service could not be found.
Unit mqtt.service could not be found.
â redis-server.service - Advanced key-value store
Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2018-03-03 15:54:22 GMT; 3 months 16 days ago
Docs: http://redis.io/documentation,
man:redis-server(1)
Process: 995 ExecStartPost=/bin/run-parts --verbose /etc/redis/redis-server.post-up.d (code=exited, status
=0/SUCCESS)
Process: 981 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
Process: 955 ExecStartPre=/bin/run-parts --verbose /etc/redis/redis-server.pre-up.d (code=exited, status=0
/SUCCESS)
Main PID: 994 (redis-server)
Tasks: 3 (limit: 4915)
CGroup: /system.slice/redis-server.service
ââ994 /usr/bin/redis-server 127.0.0.1:6379
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
so can you also run sudo systemctl redis-server status or just re-run the full (corrected) command again
pi@emonpi(ro):~$ sudo systemctl status {feedwriter,emonhub,mosquitto,redis-server,mqtt_input}
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled)
Active: active (running) since Mon 2018-06-18 12:16:21 UTC; 23h ago
Docs: man:mosquitto(8)
https://mosquitto.org/
Main PID: 1430 (mosquitto)
CGroup: /system.slice/mosquitto.service
└─1430 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
Jun 18 12:16:21 emonpi systemd[1]: Started Mosquitto MQTT Broker.
● redis-server.service - Advanced key-value store
Loaded: loaded (/lib/systemd/system/redis-server.service; enabled)
Active: active (running) since Mon 2018-06-18 12:16:20 UTC; 23h ago
Process: 1388 ExecStop=/usr/bin/redis-cli shutdown (code=exited, status=0/SUCCESS)
Process: 1406 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
Main PID: 1413 (redis-server)
└─1413 /usr/bin/redis-server 127.0.0.1:6379
Jun 18 12:16:20 emonpi systemd[1]: Started Advanced key-value store.
That all seems fine.
When did you last run an update ?
Can we see your emonpiupdate.log?
Did you do anything around the time the data stopped, eg using the sync module, updating, change any settings etc?
[edit]
I also noticed that your server info showed the buffer as “loading…” is that still the case? Looking at one of your previous posts (Input list doesn't load - #10 by ivancaregnato) that has previously showed a status like “60 feed points pending write” but I do not know if this is significant.
Plus, have you recently updated the OS packages using apt-get? It’s just I notice you are now running Mosquitto v1.4.14 where as the images installed version was originally 1.4.10 (also seen in your previous post), but again I have no idea if this is significant yet.
I ran it sunday, pressing emonpi update (my bad, I know I have to press emonbase update but I didn’t do it intentionally…the problem was already present)
Here is the emonpiupdate.log:
Filesystem is unlocked - Write access
type ' rpi-ro ' to lock
I2C LCD NOT DETECTED on either 0x['27', '3f'] ...exiting LCD script
Starting emonPi Update >
via service-runner-update.sh
Service Runner update script V1.0.0
EUID: 1000
Argument: emonpi
Sun 17 Jun 17:31:48 UTC 2018
emonSD version: emonSD-26Oct17
emonSD base image check passed...continue update
git pull /home/pi/emonpi
* master
wifiap
On branch master
Your branch is up-to-date with 'origin/master'.
Untracked files:
(use "git add <file>..." to include in what will be committed)
1
hardware/emonpi/emonpi2c/
nothing added to commit but untracked files present (use "git add" to track)
Updating 9033993..d8baa47
Fast-forward
docs/SD-card-build.md | 4 ++++
emoncms-wifiscan.sh | 3 +++
emoncms_wifiscan.php | 27 +++++++++++++++++++++++++++
emoncmsupdate | 9 +++++++--
factoryreset | 1 +
fstab | 20 +++++++++++---------
service-runner | 29 ++++++++++++++---------------
service-runner-update.sh | 24 ++++++++++--------------
update | 2 +-
9 files changed, 78 insertions(+), 41 deletions(-)
create mode 100755 emoncms-wifiscan.sh
create mode 100644 emoncms_wifiscan.php
git pull /home/pi/RFM2Pi
* master
On branch master
nothing to commit, working directory clean
Already up-to-date.
git pull /home/pi/emonhub
K0den-wibeee_interface
* emon-pi
hmm01i-syslogging
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
Already up-to-date.
git pull /home/pi/oem_openHab
* master
On branch master
Already up-to-date.
git pull /home/pi/usefulscripts
* master
On branch master
Updating c51627e..8fd9f5d
Fast-forward
convertdata/phptimestore_to_phpfina.php | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
Start emonPi Atmega328 firmware update:
EmonPi update started
EUID: 1000
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
Stopping OpenEnergyMonitor emonHub: emonhub has been stopped ok.
Start ATmega328 serial upload using avrdude with latest.hex
Discrete Sampling
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/home/pi/emonpi/firmware/compiled/latest.hex
avrdude-original: Using autoreset DTR on GPIO Pin 7
Starting OpenEnergyMonitor emonHub: emonhub has been started ok.
[email protected] node_modules/node-red-node-emoncms
Start emonhub update script:
Running emonhub automatic node addition script
EUID: 1000
EUID: 1000
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.2.0
Sun 17 Jun 17:34:11 UTC 2018
emonSD base image check pass...continue update
EUID: 1000
Checking cron tab for service runner entry...
service runner crontab entry already installed
current settings.php md5: f9fa74b4e54adb7d760e875e0764955e
Default settings.php md5: f9fa74b4e54adb7d760e875e0764955e
git pull /var/www/emoncms
dev-mosquitto-php
master
* stable
symlinked_modules
On branch stable
Your branch is up-to-date with 'origin/stable'.
Already up-to-date.
NEW default settings.php md5: f9fa74b4e54adb7d760e875e0764955e
settings.php has NOT been user modifed
settings.php not updated
git pull /var/www/emoncms/Modules/app
9.0
* stable
On branch stable
Already up-to-date.
git pull /var/www/emoncms/Modules/config
9.0
* stable
On branch stable
Already up-to-date.
git pull /var/www/emoncms/Modules/wifi
9.0
* stable
On branch stable
Updating b7c690f..29cfb93
Fast-forward
module.json | 2 +-
wifi.php | 141 ++++++++++++++++++++++++++++++----------------------
wifi_controller.php | 33 ++++++++++--
3 files changed, 111 insertions(+), 65 deletions(-)
git pull /var/www/emoncms/Modules/dashboard
On branch stable
Updating 1b80ffb..f6a20e3
Fast-forward
Views/dashboard_config.php | 19 ++++----
Views/dashboard_edit_view.php | 10 ++--
Views/dashboard_view.php | 7 ++-
locale/fr_FR/LC_MESSAGES/messages.po | 88 ++++++++++++++++++++++++------------
module.json | 2 +-
5 files changed, 83 insertions(+), 43 deletions(-)
git pull /var/www/emoncms/Modules/graph
master
* stable
On branch stable
Already up-to-date.
git pull /home/pi/postprocess
Your branch is up-to-date with 'remotes/origin/emonpi'.
Updating c827999..7cc1498
Fast-forward
postprocess-module/postprocess_controller.php | 26 +++++---------------------
1 file changed, 5 insertions(+), 21 deletions(-)
git pull /home/pi/sync
Updating 93286d2..adaf7f7
Fast-forward
sync-module/sync_controller.php | 76 ++++++++++++++++++++++++++++++++++++-----
sync-module/sync_model.php | 15 --------
sync-module/sync_view.php | 68 +++++++++++++++++++++++++++++++-----
3 files changed, 126 insertions(+), 33 deletions(-)
git pull /home/pi/backup
master
* stable
On branch stable
Already up-to-date.
update mqtt_input systemd unit file
Update Emoncms database
Restarting Services...
Restarting OpenEnergyMonitor emonHub: emonhub has been restarted ok.
Log is turned off
Restarting feedwriter
Restarting openhab (via systemctl): openhab.service.
set log rotate config owner to root
Starting emonPi LCD service..
Filesystem is locked - Read Only access
type ' rpi-rw ' to unlock
Sun 17 Jun 17:36:19 UTC 2018
emonPi update done
No I didn’t…nothing have been touched/changed since the last update on may.
I reinstalled everything in order to solve that issues Paul, that’s the reason I’m on October17 emonSD but the system is online since 2016.
I’ve probably updated the systemy by apt get update/upgrade, but that was months before this issue. I think I’ll backup again my data, change the SD Card and put everything back with a fresh install.
I wasn’t suggesting there was any links at all, just using your previous system information post to point out the difference in that buffer line.
I cannot think of any particular reason why your system should have “just stopped” and certain cannot fathom why that issue would remain after a reboot if your system has run for so long without issue.
The difficulty now is that the info you are providing all relates to the system now rather than the system as it was when it failed. Not only did it break, but now it’s changed too, so we do not know where it’s at.
If the inputs page is updating, the issue has to be in emoncms, emonhub and mqtt etc are all working for the data to be on the inputs page. When the inputs are updated, that triggers the processing and that should cause the feeds page to “look like” it’s updating even if the buffer/feedwriter wasn’t working. If there were permission issues that should show an error in emoncms.log.
The only other thing that springs to mind is “duplicated inputs”, can you please open all the inputs on the input page of emoncms and confirm that ALL the inputs of each input node are updating and that there are no duplicated inputs (ie twice as many inputs as expected). When the inputs get duplicated, the second set of inputs get updated and the original inputs that have the processing are not, so the data doesn’t get processed.
If inputs are duplicated, just delete the newer input set (usually lower in the list, being updated and without any input processes) one at a time and the older original “stale” inputs will start to update again.
You really should not need to switch images and start afresh.
