Newly setup emon pi feed not updated in 95 mins
Hello,
I have created a new input and feed, for some reason when i look on the emon pi’s input page it says not updated for 97 minutes. Can anyone tell me why this is happening?
Emon pi has also created another power1 key (i renamed the original to machine1).
How precisely did you create the new Input?
hey thanks for replying. I followed the instructions on the website:
That is how you manage the automatically created inputs… Unless you’ve done something else to manually create an input?
You need to log power1 to a Feed then give the Feed the name Machine1. You cannot rename inputs. The inputs just gets recreated as power1 the next time the emonPi posts.
Thank you. problem solved.
