My client has a Daikin f-split which was fitted for free under a grant 3 years ago, it had a Sontex monitoring system fitted, all of which is still there, and looks like a level 3 kit. As far as I can tell it just needs a hub to connect it to heatpumpmonitor. Can anyone tell me what else I need?
Parts already fitted:
SDM120M in consumer unit for immersion
Eastern SDM630 Modbus V2 in CU for HP
Sontex Supercal 531 heat meter with flow and return sensors
Sontex Superstatic flow sensor
Great! sounds like you just need the emonHP base-station, Modbus and MBUS readers.
You can either buy this through the level 3 bundle here without any electric meters, heat meters and fittings: Level 3 Heat Pump Monitoring Bundle (emonHP) - Shop | OpenEnergyMonitor this includes dedicated remote support, including configuring the meters as you attach them and setting up the dashboard, this would usually be done in our office before we send out the kit but in your case with the heat meter and electric meter already installed it’s something we can help with when it arrives.
Alternatively if your happy to do the setup yourself it’s possible to buy the hardware on its own it’s also possible to buy these separately: emonBase, Modbus and MBUS readers:
Hi Richard
Would this be for one of the heat pumps installed under the BEIS scheme with OVO? Your timescale seems about right. I’ve written a short guide on how to make the switch from their monitoring to the OEM kit, including what to buy. That price is right. I switched over pretty easily with @glyn.hudson’s help on the top-end side.
I am a little reluctant to post on here as the process involves going in to the consumer unit which I don’t want untrained people doing. It’s to change signal wiring to the electricity meter so I will message you separately if you want it.
My system is here. It’s about as good as it get without switching out the heat pump, but I had a horror story on the trial and that’s another story.
I’m happy for it to be posted here, it will be fine with a suitable warning, we sell SDM120 meters in the shop. Would you prefer me to post it? It’s a shame for it not to be shared.
I’m now set up thanks to @rich927 and can see my graphs (and am suitably impressed) but it hasn’t appeared on the main list yet ? It’s labelled Shared and Published on the My systems view. I there something else I need to do ?
Also mine is a split system and I’d like to compare it to any other split, but most appear to be monoblocs. Is there a way of identifying splits v monoblocs ?
The default view of the main list only shows systems with at least 24 days of data, so you may need to wait a few more days before yours will appear. You can change the number in the box to be smaller…
We don’t currently distinguish between monoblock and split units, but it’s something we could consider adding in future. In the meantime, filtering on “split” will show other split units.
Hey @JuliaC
I found you. Nice to have another BEIS install on the list. A shame it wasn’t working this well when the trial was under way!
You made top 5 in the last few days, I’m off the page unfortunately.
