More low, low, low pricing tomorrow.
Switch done. Of course all meter installs are stalled now…
Finally got a solution working for a local dashboard to go on my tablet with today’s Octopus Agile pricing.
Using Home Assistant and the Node-Red, InfluxDB and Grafana add-ons (really there is no easier way to install all 3 so they work seamlessly together).
The graph shows a rolling 24Hr so far left bar is the current price. When it gets beyond half 10 at night you start to see a blank area to the right as the new data does not come out until about 16:30 but that is fine for my purposes. It is easy for the rest of the household to understand when it will be cheap.
This is a Node-Red dashboard as I could not get HADashboard to authenticate and let me show the Grafana Graph.
[edit]
I added more detail on the HA community post
Grafana has a time window selection called today so far.
Have you tried that?
No I haven’t, but when the new pricing comes out, it fills the rest of the next 24Hrs up which is what I want - it tells you when the next cheapest period is (max 24hrs out) so I use now
to now+1d
which works well.
The other trick is to add a refresh to the URL.
You can also do things like now+1d/d
The /d limits just to the end of that day… rather than going all 24hrs?
Going all 24hrs keeps the size of the graph constant otherwise I suspect it will want to resize all the time. Instinctively you also know how far away the next cheapest period is.
The number one question asked of me when there are Agile price plunges…
How many price plunges have there been?
How frequent are they?
Well ask no more…
There was a bit on the BBC about the challenges NG have with the reduced load. What surprises me is that we are still often getting 2GW from France. Has this been forward purchased?
I do so wish I was on Agile
Hi @Zarch; I have been on the Go tariff for 3 months now, and I have just reviewed what I spent compared to what it would have been had I been on Agile. £86.85 as opposed to £92.24 - so not a huge saving (5.8%), but that could be improved upon if I switched use to match Agile’s peaks and troughs each day.
I have an EV, PV and a storage battery; we cook via oil, so it is easy to avoid the evening spike.
How easy do you find it to change charging times etc each day? I’m not even sure I would know how to add the flexibility to the battery charging times.
If I could bump the saving up to 10%, fag packet maths suggest I might only save ~£20 a year, and so am not convinced that adding complexity is the best thing for me to do…
Great stuff @Zarch, I have just discovered this thread. We had a SMETS2 installed last September and I bought a Hildebrand IHD/CAD about a month ago and @JaneatGlow told me about the Agile tariff during my request for MQTT data from Hildebrand. I reckon we can save quite a bit a month. Your site is a goldmine of information, excellent! Is the referral code still active?
If you’re already in Go and you want compare actuals for Go, you can use OctoComparison.
https://octopuscomparison.netlify.app/
I think if you can avoid 4pm to 7pm using PV and battery you have to save money. especially filling up the battery cheaply on days when there isn’t enough PV.
But, if its only going to be £20/year, is it really worth all the hassle?
I’ve got a Lux battery so there is a automatic tool to charge based on Agile pricing, so its dead easy for me.
Hope this helps.
Hi Garry,
Thanks for the month.
If you need historical data you can grab it via
In CSV format.
Hope this helps?
Cheers, Mick
PS. yes, referral code still works… £50 of free credit if you sign up using it.
We just switched to agile. The missis said that won’t work we cook at that time. And this is true. I suggested using the slow cooker during the day or I bbq every evening after work
Good luck with those plans. Let us know if they work.
Hi Shaun, welcome, What I see is that the cost is son much less than a standard tariff at other times, on balance (average) you pay less. I don’t generally avoid those periods when cooking but the emoncms app tells me my average p/kWh over the last few months would be half the cheapest tariff. I can improve that by not allowing the tumble dryer in particular at that time!
Whilst the fixed graphs on the my energy-stats site are great for at a glance views that suit most people, others have been asking for more control.
So I’ve set up a energy-stats user configurable dashboard containing the most popular graphs against the Agile Import and Agile Outgoing data. You can now choose the date ranges you want to explore and really get into the data.
Hope people find some use in this.
