Maybe this thread can save time finding your local issue with updates.
My emonpi were not able to update from administration panel, with the button “emonPi Update”. Also has not present any update in database , when i check with button “Update & Check” from admin panel. Application seem to be ok, internet access ok, iptables ok… but is not possible update from emoncms, why?
Update log not seems to have errors:
/home/pi/data/emonpiupdate.log
But in logfile:
/var/log/service-runner.log
I can see some messages relative to pending commit changes:
error: Your local changes to the following files would be overwritten by merge:
Lib/email.php
Please, commit your changes or stash them before you can merge.
Aborting
Already on 'emonpi'
backup/backup_view.php
backup/module.json
Aborting
Checking Glyn notes in another thread, i can notify some manual tests:
rpi-rw
cd /var/www/emoncms
git status
git log | head
git branch
git pull
rpi-ro
That give me the clue about the issue:
root@emonpi(rw):emoncms# git status
On branch stable
Your branch is behind 'origin/stable' by 90 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: Lib/email.php
modified: scripts/logger/logrotate.conf
Untracked files:
(use "git add <file>..." to include in what will be committed)
Lib/email.php_20170715
Theme/basic/dashboard/
Theme/basic/emon.css
Theme/basic/emoncms_logo.png
backup.settings.php
settings.php_20170615
settings.php_20171112
settings.php_20180106
no changes added to commit (use "git add" and/or "git commit -a")
After exclude both files:
root@emonpi(rw):emoncms# git checkout -- Lib/email.php
root@emonpi(rw):emoncms# git checkout -- scripts/logger/logrotate.conf
Status return now does not notify changes for these files:
On branch stable
Your branch is behind ‘origin/stable’ by 127 commits, and can be fast-forwarded.
(use “git pull” to update your local branch)
Untracked files:
(use “git add …” to include in what will be committed)Lib/email.php_20170715 Theme/basic/dashboard/ Theme/basic/emon.css Theme/basic/emoncms_logo.png backup.settings.php settings.php_20170615 settings.php_20171112 settings.php_20180106nothing added to commit but untracked files present (use “git add” to track)
root@emonpi(rw):emoncms# git add .
On branch stable
Your branch is behind 'origin/stable' by 127 commits, and can be fast-forwarded.
Changes to be committed:
(use "git reset HEAD <file>..." to unstage)
new file: Lib/email.php_20170715
new file: Theme/basic/dashboard/02-html-clean.png
new file: Theme/basic/emon.css
new file: Theme/basic/emoncms_logo.png
new file: backup.settings.php
new file: settings.php_20170615
new file: settings.php_20171112
new file: settings.php_20180106
root@emonpi(rw):emoncms# git branch
dev-mosquitto-php
master
* stable
symlinked_modules
root@emonpi(rw):emoncms# git pull
Updating a21a27e..86adaec
Fast-forward
Lib/dbschemasetup.php | 5 +-
Lib/email.php | 4 +-
Lib/tablejs/custom-table-fields.js | 45 ++-
Modules/admin/admin_main_view.php | 96 +++--
Modules/feed/engine/MysqlTimeSeries.php | 7 +-
Modules/feed/feed_controller.php | 12 +-
Modules/feed/feed_model.php | 244 ++++++++++---
Modules/feed/feed_schema.php | 6 +-
Modules/input/Views/input.js | 2 +-
Modules/input/Views/input_api.php | 4 +-
Modules/input/input_controller.php | 2 +-
Modules/input/input_methods.php | 6 +-
Modules/input/input_model.php | 263 +++++++++++---
Modules/input/input_schema.php | 2 +-
Modules/input/locale/fr_FR/LC_MESSAGES/messages.mo | Bin 9809 -> 11421 bytes
Modules/input/locale/fr_FR/LC_MESSAGES/messages.po | 1130 +++++++++++++++++++++++++++++++--------------------------
Modules/process/process_model.php | 4 +
Modules/process/process_processlist.php | 8 +-
Modules/schedule/Views/schedule_view.php | 5 +-
After that, from administration panel with the button “emonPi Update” and button “Update & Check” emoncms has been updated successfully from 9.8.10 to last present version 9.8.28.
I have not clear if the procedure is the best one, but at least for me has worked fine.
