I was looking at the feed page instead of the inputs, my mistake.
** Restart **
No clock yet: SD initialized.
10/29/17 15:03:06 Real Time Clock is running. Unix time: 1509289386
10/29/17 15:03:06 Version: 02_02_23
10/29/17 15:03:06 Updater: Installing update files for version 02_02_23
10/29/17 15:03:06 Updater: Installing CNFSTYLE.CSS
10/29/17 15:03:06 Updater: Installing GRAPH.HTM
10/29/17 15:03:06 Updater: Installing GRAPH.JS
10/29/17 15:03:06 Updater: Installing INDEX.HTM
10/29/17 15:03:07 Updater: Installing TABLES.TXT
10/29/17 15:03:07 Updater: Installing EDIT.HTM
10/29/17 15:03:07 Updater: Installation complete.
10/29/17 15:03:07 Reset reason: Software/System restart
10/29/17 15:03:07 Trace: 130,131,132,133,134,135,136,137,138,139,14,17,18,13,14,17,18,13,14,17,18,11,90,91,84,86,88,93,94,95,99,12
10/29/17 15:03:07 ESP8266 ChipID:11725030
10/29/17 07:03:08 device name: IotaWatt, version: 3
10/29/17 07:03:08 Local time zone: -8
10/29/17 07:03:09 MDNS responder started
10/29/17 07:03:09 You can now connect to http://IotaWatt.local
10/29/17 07:03:09 HTTP server started
10/29/17 07:03:09 dataLog: service started.
10/29/17 07:03:09 dataLog: Last log entry:1509289345
10/29/17 07:03:09 statService: started.
10/29/17 07:03:09 timeSync: service started.
10/29/17 07:03:09 WiFi connected. SSID: CarmenLeah5, IP: 192.168.0.202
10/29/17 07:08:09 EmonService: started.url: emoncms.org, node: IotaWatt, post interval: 10, encrypted POST
10/29/17 07:08:09 EmonService: Emonlog file created.
10/29/17 07:08:09 EmonService: Start posting from 1509289685
10/29/17 07:09:10 EmonService: POST failed. HTTP code: read Timeout
10/29/17 07:09:40 Resending EmonCMS data.
10/29/17 07:10:15 EmonService: POST failed. HTTP code: connection refused
10/29/17 07:10:45 Resending EmonCMS data.
10/29/17 07:11:50 EmonService: POST failed. HTTP code: read Timeout
10/29/17 07:12:20 Resending EmonCMS data.
10/29/17 07:14:20 EmonService: started.url: emoncms.org, node: IotaWatt, post interval: 10, unsecure GET
10/29/17 07:14:20 EmonService: Start posting from 1509290050
10/29/17 07:27:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 07:27:40 Resending EmonCMS data.
10/29/17 07:29:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 07:29:40 Resending EmonCMS data.
10/29/17 07:30:00 EmonService: GET failed. HTTP code: read Timeout
10/29/17 07:30:30 Resending EmonCMS data.
10/29/17 07:39:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 07:39:40 Resending EmonCMS data.
10/29/17 08:10:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:10:40 Resending EmonCMS data.
10/29/17 08:18:20 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:18:50 Resending EmonCMS data.
10/29/17 08:18:55 EmonService: GET failed. HTTP code: connection refused
10/29/17 08:19:55 Resending EmonCMS data.
10/29/17 08:20:00 EmonService: GET failed. HTTP code: connection refused
10/29/17 08:21:00 Resending EmonCMS data.
10/29/17 08:23:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:23:40 Resending EmonCMS data.
10/29/17 08:24:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:24:40 Resending EmonCMS data.
10/29/17 08:25:12 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:25:42 Resending EmonCMS data.
10/29/17 08:25:45 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:26:15 Resending EmonCMS data.
10/29/17 08:37:30 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:38:00 Resending EmonCMS data.
10/29/17 08:48:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:48:40 Resending EmonCMS data.
10/29/17 08:54:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:54:40 Resending EmonCMS data.
10/29/17 08:56:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 08:56:40 Resending EmonCMS data.
10/29/17 09:04:10 EmonService: GET failed. HTTP code: read Timeout
10/29/17 09:04:40 Resending EmonCMS data.
10/29/17 09:10:40 EmonService: started.url: emoncms.org, node: IotaWatt, post interval: 10, encrypted POST
10/29/17 09:10:40 EmonService: Start posting from 1509297030
10/29/17 09:12:02 EmonService: POST failed. HTTP code: read Timeout
10/29/17 09:12:32 Resending EmonCMS data.
10/29/17 09:16:00 EmonService: POST failed. HTTP code: read Timeout
10/29/17 09:16:30 Resending EmonCMS data.
PING emoncms.org (80.243.190.58): 56 data bytes
64 bytes from 80.243.190.58: icmp_seq=0 ttl=32 time=165.275 ms
64 bytes from 80.243.190.58: icmp_seq=1 ttl=32 time=166.042 ms
64 bytes from 80.243.190.58: icmp_seq=2 ttl=32 time=166.471 ms
64 bytes from 80.243.190.58: icmp_seq=3 ttl=32 time=166.392 ms
64 bytes from 80.243.190.58: icmp_seq=4 ttl=32 time=161.713 ms
64 bytes from 80.243.190.58: icmp_seq=5 ttl=32 time=166.011 ms
64 bytes from 80.243.190.58: icmp_seq=6 ttl=32 time=166.238 ms
64 bytes from 80.243.190.58: icmp_seq=7 ttl=32 time=166.711 ms
64 bytes from 80.243.190.58: icmp_seq=8 ttl=32 time=167.189 ms
64 bytes from 80.243.190.58: icmp_seq=9 ttl=32 time=166.137 ms
64 bytes from 80.243.190.58: icmp_seq=10 ttl=32 time=162.178 ms
64 bytes from 80.243.190.58: icmp_seq=11 ttl=32 time=166.168 ms
64 bytes from 80.243.190.58: icmp_seq=12 ttl=32 time=163.761 ms
— 80.243.190.58 ping statistics —
13 packets transmitted, 13 received, 0.00% packet loss
round-trip min / avg / max = 161.713 / 165.407 / 167.189 ms
