I’ve installed the new SD (16gb). Have activated SSH. Via PuTTy have followed instal for NodeRed
bash <(curl -sL https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/update-nodejs-and-nodered)
but am coming up with second error which I don’t know how to resolve.
First error required me to manually run:
sudo dpkg --configure -a
Did that and am now coming up with error
“E: The package nodejs needs to be reinstalled, but I can’t find an archive for it.”
nodered install 4.txt (8.2 KB)
transcript uploaded.
Any help appreciated as I’m now missing updates to my inputs
Regards
John
Have you tried running sudo apt-get install -f ?
Bill,
No I haven’t. Not up with this at all. what does this do?
John
Fixes “broken” packages.
After you run that, run sudo dpkg --configure -a again
Ref: E: dpkg was interrupted... run 'sudo dpkg --configure -a' - Ask Ubuntu
okay great will try this now.
comes up as follows:
pi@emonpi:/var/log $ sudo apt-get install -f
Reading package lists… Done
Building dependency tree
Reading state information… Done
pi@emonpi:/var/log $ sudo dpkg --configure -a
restarting node red install again
comes up with same error “FAiled to install node.js - exit”
Have you tried sudo apt-get install nodejs ?
Again, no but I’ll do it first thing tomorrow morning. Off out now. Thanks.
John
I’ve just fired up a stock emonSD-30Oct18 image and run
I had to answer a couple of questions and accept a warning that it would overwrite any other nodered currently installed, obviously not an issue! It installed fine.
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED ✔
Remove old version of Node-RED ✔
Remove old version of Node.js ✔
Install Node.js LTS ✔ Node v10.14.0 Npm 6.4.1
Clean npm cache ✔
Install Node-RED core ✔ 0.19.5
Move global nodes to local -
Install extra Pi nodes -
Npm rebuild existing nodes -
Add shortcut commands ✔
Update systemd script ✔
Any errors will be logged to /var/log/nodered-install.log
All done.
You can now start Node-RED with the command node-red-start
or using the icon under Menu / Programming / Node-RED
Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Did you copy and past the command directly from the nodred install page: Redirecting…
There were some funny html characters in the command in your post above, I thought this was just a formatting error which I corrected. Best double check. In the future please try and put code in tags e.g. ` ` for single lines or ``` ``` for a multiline code block. This makes code blocks much easier to read
Update:
It seems by default the script does not make noderes start on bootup. To start node-red manually after a reboot run:
node-red start
To enable node-red start automatically on boot each time run:
sudo systemctl enable nodered.service
borpin
(Brian Orpin)
9
Perhaps add to documentation somewhere?
JohnSchols
(John Schols)
10
Bill
I ran install nodejs. Is this the output that I should be expecting?
emonSD-30Oct18
pi@emonpi:~ $ sudo apt-get install nodejs
pi@emonpi:~ $
is this an error.
.node-red directory contains following
pi@emonpi:~ $ cd .node-red
pi@emonpi:~/.node-red $ ls -all
total 92
drwxr-xr-x 4 pi pi 4096 Aug 16 13:41 .
drwxr-xr-x 20 pi pi 4096 Nov 29 15:30 …
-rw-r–r-- 1 pi pi 14596 Aug 16 13:41 .config.json
-rw-r–r-- 1 pi pi 14538 Aug 15 16:17 .config.json.backup
-rw-r–r-- 1 pi pi 212 Aug 15 16:19 flows_emonpi_cred.json
-rw-r–r-- 1 pi pi 208 Aug 15 16:18 .flows_emonpi_cred.json.backup
-rw-r–r-- 1 pi pi 5723 Aug 15 16:19 flows_emonpi.json
-rw-r–r-- 1 pi pi 5708 Aug 15 16:18 .flows_emonpi.json.backup
drwxr-xr-x 3 pi pi 4096 Aug 15 13:32 lib
drwxr-xr-x 7 pi pi 4096 Aug 16 15:29 node_modules
-rw-r–r-- 1 pi pi 99 Aug 15 13:32 package.json
-rw-r–r-- 1 pi pi 715 Aug 16 13:41 .sessions.json
-rw-r–r-- 1 pi pi 11120 Aug 15 16:16 settings.js
Paul
(Paul Reed)
11
It would be better to stick to the script if possible, and let’s try and work out why that isn’t working.
Have you tried it again this morning, noting Glyn’s comments above?
JohnSchols
(John Schols)
12
Paul,
Following your comment I did a reboot, started PuTTy and ran:
answered 2 questions then this output
Stop Node-RED
Update Node.js LTS ✘ Failed to install Node.js - Exit
Clean npm cache
pi@emonpi:~ $
output log file is available but is same as previously posted. do you want me to load the new log?
Paul
(Paul Reed)
13
Could you try updating your package lists;
sudo apt-get update
and update the installed packages;
sudo apt-get dist-upgrade
Reboot,and then try the script again, and it it errors, paste your error log, with three backticks on the line above the code, and three on the lie below it.
Paste your code here
is the then rendered in the forum as
As it’s much easier to read than having to download a .txt file and editor!
JohnSchols
(John Schols)
14
emonSD-30Oct18
pi@emonpi:~ $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_10.x stretch InRelease
Reading package lists... Done
pi@emonpi:~ $ sudo apt-get dist-upgrade
Reading state information... Done
E: The package nodejs needs to be reinstalled, but I can't find an archive for it.
pi@emonpi:~ $
is that last line an error. please let me know before I continue
Paul
(Paul Reed)
15
It certainly looks like that is your problem - it can’t locate the source files for nodeJS.
Could your system source list files have become corrupted, so that it cannot locate the nodeJS package?
You could try deleting them, and re-installing them.
sudo rm /var/lib/apt/lists/* -vf
and then add them back;
sudo apt-get update
borpin
(Brian Orpin)
16
I found this answer from here by searching on
might work.
If not I’d install ‘npm’ (if not installed) and then ‘n’ and then nodejs. n is an excellent package manager. I have had to switch down a NodeJS version to get some BLE packages to work. I can give you more info if necessary.
borpin
(Brian Orpin)
17
Might seem an odd question, but what Pi are you using?
Paul
(Paul Reed)
18
I don’t think it’s a corrupted package Brian. Because the node-RED script is confirming that it has successfully removed it from the system, before trying to find the source URL to re install it.
JohnSchols
(John Schols)
19
as follows from admin page
Server Information
| Emoncms |
Version |
low-write 9.9.5 |
Modules |
Administration : App v1.2.0 : Backup v1.1.5 : EmonHub Config v1.0.0 : Dashboard v1.3.1 : Device v1.2.0 : EventProcesses : Feed : Graph v1.2.1 : Input : Postprocess v1.0.0 : CoreProcess : Schedule : Network Setup v1.0.0 : sync : Time : User : Visualisation : WiFi v1.3.0 |
Git URL |
GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data |
Git Branch |
* stable |
Buffer |
loading… |
Writer |
Daemon is running with sleep 60s |
| Server |
OS |
Linux 4.14.71-v7+ |
Host |
emonpi emonpi (192.168.1.121) |
Date |
2018-11-30 11:01:49 UTC |
Uptime |
11:01:49 up 1:11, 0 users, load average: 1.60, 1.71, 1.76 |
| HTTP |
Server |
Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80 |
| MySQL |
Version |
5.5.5-10.1.23-MariaDB-9+deb9u1 |
Host |
127.0.0.1 (127.0.0.1) |
Date |
2018-11-30 11:01:49 (UTC 00:00) |
Stats |
Uptime: 4265 Threads: 3 Questions: 16944 Slow queries: 0 Opens: 23 Flush tables: 1 Open tables: 17 Queries per second avg: 3.972 |
| Redis |
Version |
3.2.6 |
Host |
localhost:6379 (127.0.0.1) |
Size |
221 keys (869.52K) |
Uptime |
0 days |
| MQTT Server |
Version |
Mosquitto 1.4.10 |
Host |
localhost:1883 (127.0.0.1) |
| Pi |
Model |
Raspberry Pi 3 Model B Rev 1.2 - 1 GB (Sony UK) |
SoC |
Broadcom BCM2835 |
Serial num. |
2A7E72D2 |
Temperature |
CPU: 52.62°C - GPU: 53.2’C |
Release |
emonSD-30Oct18 |
File-system |
Current: read-write - Set root file-system temporarily to read-write, (default read-only) |
| Memory |
RAM |
Used: 17.48% Total: 976.74 MB Used: 170.69 MB Free: 806.05 MB |
Swap |
Used: 0.00% Total: 100 MB Used: 0 B Free: 100 MB |
| Disk |
Mount |
Stats |
Used: 39.33% Total: 3.81 GB Used: 1.5 GB Free: 2.13 GB |
/boot |
Used: 51.69% Total: 42.52 MB Used: 21.98 MB Free: 20.54 MB |
/home/pi/data |
Used: 4.09% Total: 10.32 GB Used: 431.92 MB Free: 9.37 GB |
| PHP |
Version |
7.0.30-0+deb9u1 (Zend Version 3.0.0) |
Modules |
apache2handler : calendar v7.0.30-0+deb9u1 : Core v7.0.30-0+deb9u1 : ctype v7.0.30-0+deb9u1 : curl v7.0.30-0+deb9u1 : date v7.0.30-0+deb9u1 : dom v20031129 : exif v7.0.30-0+deb9u1 : fileinfo v1.0.5 : filter v7.0.30-0+deb9u1 : ftp v7.0.30-0+deb9u1 : gd v7.0.30-0+deb9u1 : gettext v7.0.30-0+deb9u1 : hash v1.0 : iconv v7.0.30-0+deb9u1 : igbinary v2.0.1 : json v1.4.0 : libxml v7.0.30-0+deb9u1 : mbstring v7.0.30-0+deb9u1 : mcrypt v7.0.30-0+deb9u1 : mosquitto v0.4.0 : mysqli v7.0.30-0+deb9u1 : mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ : openssl v7.0.30-0+deb9u1 : pcre v7.0.30-0+deb9u1 : PDO v7.0.30-0+deb9u1 : pdo_mysql v7.0.30-0+deb9u1 : Phar v2.0.2 : posix v7.0.30-0+deb9u1 : readline v7.0.30-0+deb9u1 : redis v4.1.1 : Reflection v7.0.30-0+deb9u1 : session v7.0.30-0+deb9u1 : shmop v7.0.30-0+deb9u1 : SimpleXML v7.0.30-0+deb9u1 : sockets v7.0.30-0+deb9u1 : SPL v7.0.30-0+deb9u1 : standard v7.0.30-0+deb9u1 : sysvmsg v7.0.30-0+deb9u1 : sysvsem v7.0.30-0+deb9u1 : sysvshm v7.0.30-0+deb9u1 : tokenizer v7.0.30-0+deb9u1 : wddx v7.0.30-0+deb9u1 : xml v7.0.30-0+deb9u1 : xmlreader v7.0.30-0+deb9u1 : xmlwriter v7.0.30-0+deb9u1 : xsl v7.0.30-0+deb9u1 : Zend OPcache v7.0.30-0+deb9u1 : zlib v7.0.30-0+deb9u1 |
Client Information
| HTTP |
Browser |
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.110 Safari/537.36 |
| Screen |
Resolution |
1920 x 1080 |
| Window |
Size |
1903 x 948 |
borpin
(Brian Orpin)
20
I think that is a default answer from the script rather than an actual confirmation as it keep repeating that answer despite not reinstalling.
@JohnSchols try
[edit] sorry should be
sudo dpkg --purge --force-all nodejs
and retry script.
