Hi @pb66
Yes, i am looking at the local emoncms.
root@emonpi:/#sudo journalctl -b | grep emonpiLCD
Feb 10 08:08:41 emonpi sudo[12809]: root : TTY=pts/0 ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl status emonhub emonpiLCD mosquitto emoncms_mqtt
root@emonpi:/# ls -la /dev/{tty{ACM,AMA,S,USB,serial}[0-9] 2>/dev/null
root@emonpi:/home/pi# ls -la /dev/{tty{ACM,AMA,S,USB},serial}[0-9] 2>/dev/null
lrwxrwxrwx 1 root root 5 Feb 14 2019 /dev/serial0 â ttyS0
lrwxrwxrwx 1 root root 7 Feb 14 2019 /dev/serial1 â ttyAMA0
crw-rw---- 1 root dialout 204, 64 Feb 10 09:02 /dev/ttyAMA0
crw-rw---- 1 root dialout 4, 64 Feb 14 2019 /dev/ttyS0
2021-02-10 09:01:52,460 DEBUG MainThread Signal 15 received.
2021-02-10 09:01:52,605 INFO MainThread Exiting hub...
2021-02-10 09:01:52,752 INFO MainThread Exit completed
2021-02-10 09:01:54,260 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-10 09:01:54,261 INFO MainThread Opening hub...
2021-02-10 09:01:54,261 INFO MainThread Logging level set to DEBUG
2021-02-10 09:01:54,262 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-10 09:01:54,263 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-10 09:01:56,266 WARNING MainThread Device communication error - check settings
2021-02-10 09:01:56,267 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-10 09:01:57,269 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-10 09:01:58,272 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-10 09:01:59,274 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-10 09:02:00,276 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-10 09:02:01,278 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-10 09:02:01,279 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-10 09:02:01,281 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-10 09:02:01,284 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-10 09:02:01,285 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-10 09:02:01,286 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-10 09:02:01,286 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-10 09:02:01,287 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-10 09:02:01,288 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-10 09:02:01,290 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-10 09:02:01,291 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-10 09:02:01,291 INFO MainThread Setting emoncmsorg apikey: set
2021-02-10 09:02:01,292 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-10 09:02:01,292 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-10 09:02:01,293 INFO MainThread Setting emoncmsorg sendstatus: 1
LOG LEVEL: DEBUG
