Every day a learning day
Do you have an internal NTP server the emonPi could get it’s time from? Often routers are able to generate an NTP response.
Thanks. yes i have colleagues who do it. i will ask them to fit an RTC on an EmonPi and will let you know about the results.
Hi Brain,
I have installed external RTC on emonpi as mentioned. Now i am trying to configure time on emonpi via SSH but it not working. can you please help?
What have you tried? What instructions came with the RTC.
This is really an RPi issue and you may find more help on the RPi forums. We will help if we can
Thanks got the information. working on implementation.
Thanks again
Hi Brian,
I have configured the RTC and the time is synchronised and up to date. i am not getting any reading on the input. i checked server status and logs but there isn`t an error. when i checked the device physically there are no readings for the power and Vrms. instead of Vrms it show connecting please wait. Can you please help?
And Config file. currently 2 TH and 1 TX are connected to the pi.
Moderator - file deleted as it had the API key in it
####################### emonhub.conf #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
loglevel = DEBUG
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[RFM2Pi]]
Type = EmonHubJeeInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 38400 # 9600 for old RFM12Pi
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
group = 210
frequency = 433
baseid = 5 # emonPi / emonBase nodeID
calibration = 230V # (UK/EU: 230V, US: 110V)
quiet = true # Disable quite mode (default enabled) to enable RF packet debugging, show packets which fail crc
# interval = 300 # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 1
nodevar_format_enable = 1
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
apikey = THEAPIKEY
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 1 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 30 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
[nodes]
## See config user guide: https://github.com/openenergymonitor/emonhub/blob/emon-pi/conf/emonhub.conf
[[5]]
nodename = emonpi
[[[rx]]]
datacode = h, h, h, h, h, h, h, h, h, h, L
units = W,W,W,V,C,C,C,C,C,C,p
[[6]]
nodename = emontxshield
[[[rx]]]
names = power1, power2, power3, power4, vrms
datacode = h
scales = 1,1,1,1,0.01
units = W,W,W,W,V
[[7]]
nodename = emontx4
[[[rx]]]
units = W,W,W,W,V,C,C,C,C,C,C,p
[[8]]
nodename = emontx3
[[[rx]]]
[[9]]
nodename = emontx2
[[[rx]]]
[[10]]
nodename = emontx1
[[[rx]]]
scales = 1,1,1,1,0.01,0.01,0.01,0.01,0.01,0.01,0.01,1
[[11]]
nodename = 3phase
[[[rx]]]
names = powerL1, powerL2, powerL3, power4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse
[[12]]
nodename = 3phase2
[[[rx]]]
[[13]]
nodename = 3phase3
[[[rx]]]
[[14]]
nodename = 3phase4
[[[rx]]]
[[15]]
nodename = emontx3cm15
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, E1, E2, E3, E4, T1, T2, T3, pulse
datacodes = L,h,h,h,h,h,l,l,l,l,h,h,h,L
scales = 1,0.01,1,1,1,1,1,1,1,1,0.01,0.01,0.01,1
units = n,V,W,W,W,W,Wh,Wh,Wh,Wh,C,C,C,p
whitening = 1
[[16]]
nodename = emontx3cm16
[[[rx]]]
whitening = 1
[[19]]
nodename = emonth1
[[[rx]]]
names = temperature, external temperature, humidity, battery
datacode = h
scales = 0.1,0.1,0.1,0.1
units = C,C,%,V
[[20]]
nodename = emonth2
[[[rx]]]
datacode = h
units = C,C,%,V
[[21]]
nodename = emonth3
[[[rx]]]
datacode = h
units = C,C,%,V
[[22]]
nodename = emonth4
[[[rx]]]
datacode = h
units = C,C,%,V
[[23]]
nodename = emonth5
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h,h,h,h,L
scales = 0.1,0.1,0.1,0.1,1
units = C,C,%,V,p
[[24]]
nodename = emonth6
[[[rx]]]
units = C,C,%,V,p
[[25]]
nodename = emonth7
[[[rx]]]
units = C,C,%,V,p
[[26]]
nodename = emonth8
[[[rx]]]
units = C,C,%,V,p
Can you post the emonhub log please.
This might be a side effect of the rtc install depending on how that was done. Both the LCD and the rtc use the same i2c bus.
Looking Bach in this thread, you had reported that before starting the etc fitting, have the input updated at any point or not worked throughout?
2021-02-03 14:25:31,076 DEBUG MainThread Signal 15 received.
2021-02-03 14:25:31,250 INFO MainThread Exiting hub...
2021-02-03 14:25:31,466 INFO MainThread Exit completed
2021-02-03 14:25:34,161 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-03 14:25:34,163 INFO MainThread Opening hub...
2021-02-03 14:25:34,164 INFO MainThread Logging level set to DEBUG
2021-02-03 14:25:34,164 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-03 14:25:34,167 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-03 14:25:36,170 WARNING MainThread Device communication error - check settings
2021-02-03 14:25:36,171 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-03 14:25:37,173 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-03 14:25:38,176 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-03 14:25:39,178 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-03 14:25:40,180 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-03 14:25:41,183 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-03 14:25:41,184 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-03 14:25:41,185 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-03 14:25:41,189 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-03 14:25:41,190 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-03 14:25:41,191 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-03 14:25:41,191 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-03 14:25:41,192 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-03 14:25:41,194 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-03 14:25:41,195 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-03 14:25:41,196 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-03 14:25:41,196 WARNING MainThread Setting emoncmsorg apikey: obscured
2021-02-03 14:25:41,197 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-03 14:25:41,197 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-03 14:25:41,198 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-02-03 14:42:12,869 INFO MainThread Setting emoncmsorg apikey: set
2021-02-03 14:45:39,610 DEBUG MainThread Signal 15 received.
2021-02-03 14:45:39,725 INFO MainThread Exiting hub...
2021-02-03 14:45:39,891 INFO MainThread Exit completed
2021-02-03 14:45:42,617 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-03 14:45:42,619 INFO MainThread Opening hub...
2021-02-03 14:45:42,620 INFO MainThread Logging level set to DEBUG
2021-02-03 14:45:42,620 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-03 14:45:42,623 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-03 14:45:44,626 WARNING MainThread Device communication error - check settings
2021-02-03 14:45:44,628 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-03 14:45:45,630 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-03 14:45:46,632 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-03 14:45:47,634 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-03 14:45:48,636 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-03 14:45:49,639 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-03 14:45:49,640 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-03 14:45:49,641 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-03 14:45:49,645 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-03 14:45:49,645 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-03 14:45:49,646 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-03 14:45:49,647 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-03 14:45:49,647 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-03 14:45:49,650 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-03 14:45:49,651 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-03 14:45:49,652 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-03 14:45:49,652 INFO MainThread Setting emoncmsorg apikey: set
2021-02-03 14:45:49,653 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-03 14:45:49,654 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-03 14:45:49,654 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-02-03 14:52:06,228 DEBUG MainThread Signal 15 received.
2021-02-03 14:52:06,243 INFO MainThread Exiting hub...
2021-02-03 14:52:06,497 INFO MainThread Exit completed
2021-02-03 14:52:09,225 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-03 14:52:09,226 INFO MainThread Opening hub...
2021-02-03 14:52:09,227 INFO MainThread Logging level set to DEBUG
2021-02-03 14:52:09,228 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-03 14:52:09,230 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-03 14:52:11,234 WARNING MainThread Device communication error - check settings
2021-02-03 14:52:11,235 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-03 14:52:12,237 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-03 14:52:13,239 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-03 14:52:14,241 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-03 14:52:15,243 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-03 14:52:16,246 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-03 14:52:16,247 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-03 14:52:16,248 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-03 14:52:16,252 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-03 14:52:16,253 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-03 14:52:16,253 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-03 14:52:16,254 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-03 14:52:16,254 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-03 14:52:16,256 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-03 14:52:16,258 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-03 14:52:16,259 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-03 14:52:16,259 INFO MainThread Setting emoncmsorg apikey: set
2021-02-03 14:52:16,260 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-03 14:52:16,260 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-03 14:52:16,261 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-02-03 14:56:52,008 DEBUG MainThread Signal 15 received.
2021-02-03 14:56:52,096 INFO MainThread Exiting hub...
2021-02-03 14:56:52,182 INFO MainThread Exit completed
2021-02-03 14:59:13,394 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-03 14:59:13,395 INFO MainThread Opening hub...
2021-02-03 14:59:13,396 INFO MainThread Logging level set to DEBUG
2021-02-03 14:59:13,397 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-03 14:59:13,402 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-03 14:59:15,405 WARNING MainThread Device communication error - check settings
2021-02-03 14:59:15,407 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-03 14:59:16,409 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-03 14:59:17,411 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-03 14:59:18,413 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-03 14:59:19,415 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-03 14:59:20,418 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-03 14:59:20,419 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-03 14:59:20,421 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-03 14:59:20,424 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-03 14:59:20,425 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-03 14:59:20,426 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-03 14:59:20,426 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-03 14:59:20,427 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-03 14:59:20,429 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-03 14:59:20,431 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-03 14:59:20,431 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-03 14:59:20,432 INFO MainThread Setting emoncmsorg apikey: set
2021-02-03 14:59:20,433 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-03 14:59:20,434 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-03 14:59:20,434 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-02-03 15:00:09,522 DEBUG MainThread Signal 15 received.
2021-02-03 15:00:09,640 INFO MainThread Exiting hub...
2021-02-03 15:00:09,804 INFO MainThread Exit completed
2021-02-03 15:02:15,609 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-03 15:02:15,610 INFO MainThread Opening hub...
2021-02-03 15:02:15,611 INFO MainThread Logging level set to DEBUG
2021-02-03 15:02:15,613 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-03 15:02:15,616 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-03 15:02:17,620 WARNING MainThread Device communication error - check settings
2021-02-03 15:02:17,621 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-03 15:02:18,623 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-03 15:02:19,626 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-03 15:02:20,628 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-03 15:02:21,630 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-03 15:02:22,633 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-03 15:02:22,634 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-03 15:02:22,635 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-03 15:02:22,640 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-03 15:02:22,641 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-03 15:02:22,642 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-03 15:02:22,642 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-03 15:02:22,643 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-03 15:02:22,644 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-03 15:02:22,646 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-03 15:02:22,647 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-03 15:02:22,647 INFO MainThread Setting emoncmsorg apikey: set
2021-02-03 15:02:22,648 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-03 15:02:22,649 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-03 15:02:22,649 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-02-04 07:53:50,432 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-04 07:53:50,434 INFO MainThread Opening hub...
2021-02-04 07:53:50,435 INFO MainThread Logging level set to DEBUG
2021-02-04 07:53:50,436 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-04 07:53:50,439 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-04 07:53:52,443 WARNING MainThread Device communication error - check settings
2021-02-04 07:53:52,444 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-04 07:53:53,446 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-04 07:53:54,448 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-04 07:53:55,451 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-04 07:53:56,453 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-04 07:53:57,455 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-04 07:53:57,456 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-04 07:53:57,458 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-04 07:53:57,461 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-04 07:53:57,462 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-04 07:53:57,463 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-04 07:53:57,463 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-04 07:53:57,464 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-04 07:53:57,466 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-04 07:53:57,468 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-04 07:53:57,469 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-04 07:53:57,469 INFO MainThread Setting emoncmsorg apikey: set
2021-02-04 07:53:57,470 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-04 07:53:57,470 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-04 07:53:57,471 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-02-04 07:56:34,327 DEBUG MainThread Signal 15 received.
2021-02-04 07:56:34,393 INFO MainThread Exiting hub...
2021-02-04 07:56:34,576 INFO MainThread Exit completed
2021-02-04 07:57:57,896 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-04 07:57:57,897 INFO MainThread Opening hub...
2021-02-04 07:57:57,899 INFO MainThread Logging level set to DEBUG
2021-02-04 07:57:57,900 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-04 07:57:57,903 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-04 07:57:59,906 WARNING MainThread Device communication error - check settings
2021-02-04 07:57:59,908 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-04 07:58:00,910 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-04 07:58:01,913 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-04 07:58:02,915 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-04 07:58:03,917 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-04 07:58:04,920 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-04 07:58:04,921 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-04 07:58:04,922 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-04 07:58:04,926 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-04 07:58:04,927 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-04 07:58:04,927 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-04 07:58:04,928 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-04 07:58:04,928 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-04 07:58:04,931 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-04 07:58:04,932 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-04 07:58:04,933 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-04 07:58:04,933 INFO MainThread Setting emoncmsorg apikey: set
2021-02-04 07:58:04,934 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-04 07:58:04,935 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-04 07:58:04,935 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-02-04 08:01:55,138 DEBUG MainThread Signal 15 received.
2021-02-04 08:01:55,227 INFO MainThread Exiting hub...
2021-02-04 08:01:55,288 INFO MainThread Exit completed
2021-02-04 08:03:18,319 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-02-04 08:03:18,320 INFO MainThread Opening hub...
2021-02-04 08:03:18,321 INFO MainThread Logging level set to DEBUG
2021-02-04 08:03:18,322 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-02-04 08:03:18,325 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-02-04 08:03:20,329 WARNING MainThread Device communication error - check settings
2021-02-04 08:03:20,330 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-02-04 08:03:21,332 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-02-04 08:03:22,334 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-02-04 08:03:23,336 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-02-04 08:03:24,339 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-02-04 08:03:25,341 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-02-04 08:03:25,342 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-02-04 08:03:25,353 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-02-04 08:03:25,356 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-02-04 08:03:25,357 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-02-04 08:03:25,358 INFO MainThread Setting MQTT node_format_enable: 1
2021-02-04 08:03:25,358 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-02-04 08:03:25,359 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-02-04 08:03:25,361 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-02-04 08:03:25,364 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-02-04 08:03:25,364 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-02-04 08:03:25,365 INFO MainThread Setting emoncmsorg apikey: set
2021-02-04 08:03:25,366 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-02-04 08:03:25,366 INFO MainThread Setting emoncmsorg senddata: 1
2021-02-04 08:03:25,367 INFO MainThread Setting emoncmsorg sendstatus: 1
Yes, initially it was a time problem as we are using it offline. we fitted RTC and configured it to solve that. now i am getting communication error in logs
Hi Paul/Brian,
I compared two Emonpi and bought both together. The one i installed RTC have different version and the highlighted one is the one without RTC have different config versions. I think that’s why its causing the COMM error.
Thanks. I know its too messy and trying to fix it. Thanks your help again
One is showing as 10.2.7 and the other 10.2.6 - the app versions just come with the emoncms updates.
Thanks. Can please tell me how to fix the communication error. As i looked into everything including config files but I am unable to solve it.
Thanks Again
I think it is best to tells us, what you have done (install RTC - what system setting were changed) and what the symptoms are.
I wonder if you have changed the serial port for the UART.
Hi Brian,
Below the commands i used for RTC configuration
sudo apt-get install python-smbus i2c-tools
sudo i2cdetect -y 1
sudo nano/boot/config.txt
add:
dtoverlay=i2c-rtc,ds3231
at the end of the file
reboot
Run:
sudo apt-get -y remove fake-hwclock
sudo update-rc.d -f fake-hwclock remove
sudo nano /lib/udev/hwclock-set
#if [ -e /run/systemd/system ] : then
# exit 0
# fi
sudo hwclock -D -r
sudo hwclock -w
sudo hwclock -r
Edit - reformatted text for readability. BT, Moderator
The symptoms are that the device isn’t providing any inputs, on the emonLcd there are no power reading and vrms gives a message of please wait. i have attached the images in the loop above.
As asked before…
You may have disrupted the I2C setup for this - not something I know anything about.
Can you please provide the output from ls-la /dev/tty*
please although @pb66 is probably a better person to help with this.
tty.txt (3.9 KB)
Hi Brian,
i was receiving input before RTC fitting. but the status of that input was inactive. i was missing some data due incorrect time. When i solder the RTC and configured the RTC after that I am unbale to receiving any input. Please find the attached for tty*.
Inactive means you were not receiving an input. That was just saying that at some point in the distant past you did receive an input (as was mentioned previously).
“Inactive” means that data has not been received for some time - I don’t know the exact duration.
If you were not getting inputs before doing this then something else is wrong.
Is this a standard EmonPi setup?
