Hi all,
I tried to install OpenHAB 2 beta 4 on this image. Because of the absence of a openhab2 folder in /var/log OpenHAB 2 doesn’t start. So rpi-rw, sudo mkdir openhab2, sudo chown openhab:openhab openhab2 and openhab 2 works. But after a reboot my openhab2 folder is gone… Any ideas?
Also started a thread here: Trying to install OH 2 beta 4 on OpenEnergyMonitor image - #4 by rlkoshak - Beginners - openHAB Community
This is because on the emonpi /var/log is mounted as a temp RAM partition.
You need to edit ~/emonpi/rc.local_jessieminimal which is symlinked to /etc/rc.local to create the folder you need on startup:
Once you get openHAB 2 up and running it would be great if you could update us on OpenHAB development. How soon should we all update to openHAB 2? How can we replicate the OpenEnergyMonitor OpenHAB setup on openHab2?
Done, now a small step further
pi@emonpi:/var/log $ sudo systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Fri 2016-09-30 12:35:16 UTC; 945ms ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 7024 ExecStop=/usr/share/openhab2/runtime/karaf/bin/stop (code=exited, status=1/FAILURE)
Main PID: 7172 (karaf)
CGroup: /system.slice/openhab2.service
├─7172 /bin/sh /usr/share/openhab2/runtime/karaf/bin/karaf server
├─7270 /bin/sh /usr/share/openhab2/runtime/karaf/bin/karaf server
├─7271 /usr/bin/java -version
├─7272 grep -E “([0-9].[0-9]..[0-9]). ”
├─7273 awk {print substr($3,2,length($3)-2)}
├─7274 awk {print substr($1, 3, 3)}
└─7275 sed -e s;.;;g
Sep 30 12:35:16 emonpi systemd[1]: Started openHAB 2 - empowering the smart home.
Sep 30 12:35:16 emonpi start.sh[7172]: Launching the openHAB runtime…
Active: active (running) since Fri 2016-09-30 12:35:25 UTC; 1s ago
Process: 7593 ExecStop=/usr/share/openhab2/runtime/karaf/bin/stop (code=exited, status=1/FAILURE)
Main PID: 7739 (karaf)
├─7739 /bin/sh /usr/share/openhab2/runtime/karaf/bin/karaf server
└─7852 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenh…
Sep 30 12:35:25 emonpi systemd[1]: Starting openHAB 2 - empowering the smart home…
Sep 30 12:35:25 emonpi systemd[1]: Started openHAB 2 - empowering the smart home.
Sep 30 12:35:25 emonpi start.sh[7739]: Launching the openHAB runtime…
Sep 30 12:35:27 emonpi start.sh[7739]: Unable to update instance pid: /usr/share/openhab2/runtime/karaf/instances/instance.properties (Read-only file system)
The other trick we do on the emonSD is mount var/lib/openhab onto tmpfs
~/emonpi/fstab is symlinked to /etc/fstab
tmpfs /tmp tmpfs nodev,nosuid,size=30M,mode=1777 0 0
tmpfs /var/tmp tmpfs nodev,nosuid,size=1M,mode=1777 0 0
tmpfs /var/log tmpfs nodev,nosuid,size=50M,mode=1777 0 0
tmpfs /var/lib/dhcp tmpfs nodev,nosuid,size=1M,mode=1777 0 0
tmpfs /var/lib/dhcpcd5 tmpfs nodev,nosuid,size=1M,mode=1777 0 0
tmpfs /var/lib/openhab tmpfs nodev,nosuid,size=40M,mode=1777 0 0
tmpfs /var/lib/php/sessions tmpfs nodev,nosuid,nofail,size=5M,mode=1777 0 0
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults,noatime,nodiratime 0 2
/dev/mmcblk0p2 / ext4 defaults,ro,noatime,nodiratime,errors=remount-ro 0 1
/dev/mmcblk0p3 /home/pi/data ext2 defaults,rw,noatime,nodiratime,errors=remount-ro 0 2
It looks like you might need to add an entry to also mount /usr/share/openhab2
I already changed that one to /openhab2
Some more log files
pi@emonpi:~ $ sudo systemctl status openhab2.service
Active: active (running) since Fri 2016-09-30 14:58:49 UTC; 2min 39s ago
Main PID: 982 (karaf)
├─ 982 /bin/sh /usr/share/openhab2/runtime/karaf/bin/karaf server
└─1590 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -...
Sep 30 14:58:49 emonpi systemd[1]: Started openHAB 2 - empowering the smart home.
Sep 30 14:58:49 emonpi start.sh[982]: Launching the openHAB runtime...
Sep 30 14:58:52 emonpi start.sh[982]: Unable to update instance pid: /usr/share/openhab2/runtime/karaf/instances/instance.properties (Read-only file system)
Active: active (running) since Fri 2016-09-30 14:58:49 UTC; 2min 47s ago
Sep 30 15:01:34 emonpi start.sh[982]: at org.eclipse.osgi.storage.Storage.save0(Storage.java:1038)
Sep 30 15:01:34 emonpi start.sh[982]: at org.eclipse.osgi.storage.Storage.save(Storage.java:1009)
Sep 30 15:01:34 emonpi start.sh[982]: at org.eclipse.osgi.internal.framework.StorageSaver$StorageSaverTask.run(StorageSaver.java:28)
Sep 30 15:01:34 emonpi start.sh[982]: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
Sep 30 15:01:34 emonpi start.sh[982]: at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
Sep 30 15:01:34 emonpi start.sh[982]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
Sep 30 15:01:34 emonpi start.sh[982]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
Sep 30 15:01:34 emonpi start.sh[982]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
Sep 30 15:01:34 emonpi start.sh[982]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Sep 30 15:01:34 emonpi start.sh[982]: at java.lang.Thread.run(Thread.java:745)
Active: active (running) since Fri 2016-09-30 14:58:49 UTC; 2min 50s ago
Active: active (running) since Fri 2016-09-30 14:58:49 UTC; 2min 52s ago
pi@emonpi:~ $ ssh karaf@localhost -p8101
ssh: connect to host localhost port 8101: Connection refused
pi@emonpi:~ $ tail -f /var/log/openhab2/openhab.log
Unresolved requirement: Import-Package: org.eclipse.smarthome.ui.items; resolu tion:="optional"
-> Export-Package: org.eclipse.smarthome.ui.items; bundle-symbolic-name="org .eclipse.smarthome.ui"; bundle-version="0.9.0.b1"; version="0.0.0"
org.eclipse.smarthome.ui [130]
Unresolved requirement: Import-Package: org.osgi.service.http
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse. osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispat chEvent(ModuleContainer.java:1498)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispat chEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventM anager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(Even tManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
^C
Unresolved requirement: Import-Package: org.eclipse.smarthome.ui.items; resolution:="optional"
-> Export-Package: org.eclipse.smarthome.ui.items; bundle-symbolic-name="org.eclipse.smarthome.ui"; bundle-version="0.9.0.b1"; version="0.0.0"
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1498)[org.eclipse.osgi-3.10.2.v20150203-1939. jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar :]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
^[[A^[[A^[[A^[[A^C
^C
Active: active (running) since Fri 2016-09-30 16:08:04 UTC; 5min ago
Main PID: 988 (karaf)
├─ 988 /bin/sh /usr/share/openhab2/runtime/karaf/bin/karaf server
└─1610 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab...
Sep 30 16:08:04 emonpi systemd[1]: Started openHAB 2 - empowering the smart home.
Sep 30 16:08:04 emonpi start.sh[988]: Launching the openHAB runtime...
Sep 30 16:08:08 emonpi start.sh[988]: Unable to update instance pid: /usr/share/openhab2/runtime/karaf/instances/instance.properties (Read-onl...e system)
Hint: Some lines were ellipsized, use -l to show in full.
pi@emonpi:~ $ rpi-rw
Filesystem is unlocked - Write access
type ' rpi-ro ' to lock
Sep 30 16:13:34 emonpi start.sh[988]: at org.eclipse.osgi.storage.Storage.save0(Storage.java:1038)
Sep 30 16:13:34 emonpi start.sh[988]: at org.eclipse.osgi.storage.Storage.save(Storage.java:1009)
Sep 30 16:13:34 emonpi start.sh[988]: at org.eclipse.osgi.internal.framework.StorageSaver$StorageSaverTask.run(StorageSaver.java:28)
Sep 30 16:13:34 emonpi start.sh[988]: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
Sep 30 16:13:34 emonpi start.sh[988]: at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
Sep 30 16:13:34 emonpi start.sh[988]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolEx...java:180)
Sep 30 16:13:34 emonpi start.sh[988]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
Sep 30 16:13:34 emonpi start.sh[988]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
Sep 30 16:13:34 emonpi start.sh[988]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Sep 30 16:13:34 emonpi start.sh[988]: at java.lang.Thread.run(Thread.java:745)
pi@emonpi:~ $ sudo systemctl status openhab2.service -l
└─1610 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Xmx256m -Djava.awt.headless=true -Djava.endorsed.dirs=/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/jre/lib/endorsed:/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/lib/endorsed:/usr/share/openhab2/runtime/karaf/lib/endorsed -Djava.ext.dirs=/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/jre/lib/ext:/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/lib/ext:/usr/share/openhab2/runtime/karaf/lib/ext -Dkaraf.instances=/usr/share/openhab2/runtime/karaf/instances -Dkaraf.home=/usr/share/openhab2/runtime/karaf -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/usr/share/openhab2/runtime/karaf/etc -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/karaf/lib/boot/org.apache.karaf.diagnostic.boot-4.0.4.jar:/usr/share/openhab2/runtime/karaf/lib/boot/org.apache.karaf.jaas.boot-4.0.4.jar:/usr/share/openhab2/runtime/karaf/lib/boot/org.apache.karaf.main-4.0.4.jar:/usr/share/openhab2/runtime/karaf/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main
Sep 30 16:13:34 emonpi start.sh[988]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
Active: active (running) since Fri 2016-09-30 16:08:04 UTC; 6min ago
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1498)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
^C
└─1610 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/open...
^C
pi@emonpi:~ $
Just tried a empty jessie lite image and installed openhab2, this works fine.
So it only comes from removing openhab 1.8 and/or the read-only filesystem.
From the log files this seems to be the main issue. Any idea what this is and how it can be installed?
Ok, I retried. Took a clean image. How I started:
sudo apt-get update
sudo apt-get remove openhab-runtime
java -version
sudo apt-get install screen mc vim git htop
sudo apt-get install oracle-java8-jdk
sudo echo 'deb http://dl.bintray.com/openhab/apt-repo2 testing main' | sudo tee /etc/apt/sources.list.d/openhab2.list
sudo wget -qO - 'https://bintray.com/user/downloadSubjectPublicKey?username=openhab' | sudo apt-key add -
sudo apt-get update
sudo reboot
sudo nano ~/emonpi/rc.local_jessieminimal
Changed line 11 openhab to openhab2
Changed line 17 /var/log/openhab to /var/log/openhab2
sudo reboot
sudo nano ~/emonpi/fstab
Changed line 5 /var/lib/openhab to /var/lib/openhab2
added underneath line 5 tmpfs /usr/share/openhab2 tmpfs nodev,nosuid,size=40M,mode=1777 0 0
sudo apt-get install openhab2-offline
sudo systemctl start openhab2.service
sudo systemctl daemon-reload
sudo systemctl enable openhab2.service
sudo reboot
openHAB2 won’t run, also no log file in /var/log/openhab2
pi@emonpi:/ $ sudo systemctl status openhab2.service
Active: failed (Result: start-limit) since Mon 2016-10-10 22:23:32 UTC; 3s ago
Process: 32132 ExecStop=/usr/share/openhab2/runtime/karaf/bin/stop (code=exited, status=203/EXEC)
Process: 32130 ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=203/EXEC)
Main PID: 32130 (code=exited, status=203/EXEC)
Oct 10 22:23:32 emonpi systemd[1]: Unit openhab2.service entered failed state.
Oct 10 22:23:32 emonpi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 10 22:23:32 emonpi systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 10 22:23:32 emonpi systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 10 22:23:32 emonpi systemd[1]: openhab2.service start request repeated too quickly, refusing to start.
Oct 10 22:23:32 emonpi systemd[1]: Failed to start openHAB 2 - empowering the smart home.
Then again, a sudo reboot and a sudo apt-get upgrade. Same result .
Oh dear, this is not cool.
I can’t see anything useful in the log files. I’m afraid I don’t know the intricacies of how openhab works let alone openhab2 to debug further without better info from the log. Maybe it’s time to ask the openhab forum guys regarding running on R/O FS.
Mmm good conversation on that thread. I’m away this week but when I’m home I will try and install open hab 2 myself. Would be good to get install procedure written up to work with our r/o image.
Have you tried added in a line to rc.local to restart openhab2 after creating the log directory?
E.g
mattwire
(Matthew Wire)
26 November 2016 11:17
12
This is my effort so far once openhab2 is installed via deb:
> mount -t tmpfs tmpfs /var/lib/openhab2/cache
mount -t tmpfs tmpfs /var/lib/openhab2/mapdb
mount -t tmpfs tmpfs /var/lib/openhab2/tmp
mount -t tmpfs tmpfs /var/lib/openhab2/log
ln -s /var/lib/openhab2/tmp/port /var/lib/openhab2/port
ln -s /var/lib/openhab2/tmp/lock /var/lib/openhab2/lock
rm -rf /var/lib/openhab2/persistence && ln -s /mnt/rwdata/openhab2/persistence /var/lib/openhab2/persistence
mattwire
(Matthew Wire)
27 November 2016 21:27
14
Sorry! Yes it works. Just wanted to add to the thread in case it helps, I’ve got it running fine on a Pi with the above commands. /mnt/rwdata is a writeable usb stick here (there’s quite a lot of persistence data which could probably be stored in a ram disk if you don’t need to store it permanently). It may help to have mapdb on writeable storage because it takes quite a long time to start up openhab when mapdb database needs to be recreated (and it will store any config created via UI rather than stored in config files in /etc/openhab2).
Nice work
I’ll add a link to this thread from the OpenEnergyMonitor OpenHAB git repo
mattwire
(Matthew Wire)
12 December 2016 22:13
16
There’s been a few changes with openhab2, not least the change to jsondb (replacing mapdb) for saving configuration through the UI. /mnt/rwdata is a read/write usb key. Any config I wish to save is moved to /etc/openhab2 so I can manage it easily.
Below are the steps I’m currently using:
rm /var/lib/openhab2/port && ln -s /var/lib/openhab2/tmp/port /var/lib/openhab2/port
rm -rf /var/lib/openhab2/lock && ln -s /var/lib/openhab2/tmp/lock /var/lib/openhab2/lock
mv /var/lib/openhab2/etc /etc/openhab2/etc
ln -s /etc/openhab2/etc /var/lib/openhab2/etc
mv /var/lib/openhab2/jsondb /etc/openhab2/jsondb
ln -s /etc/openhab2/jsondb /var/lib/openhab2/jsondb
mattwire
(Matthew Wire)
21 February 2017 12:22
17
Quick update on this to autoconfigure this:
Create file /usr/share/openhab2/start_pre.sh:
#!/bin/sh
test -d /var/lib/openhab2/cache || mkdir /var/lib/openhab2/cache
mountpoint -q /var/lib/openhab2/cache || mount -t tmpfs tmpfs /var/lib/openhab2/cache
test -d /var/lib/openhab2/tmp || mkdir /var/lib/openhab2/tmp
mountpoint -q /var/lib/openhab2/tmp || mount -t tmpfs tmpfs /var/lib/openhab2/tmp
test -d /var/lib/openhab2/log || mkdir /var/lib/openhab2/log
mountpoint -q /var/lib/openhab2/log || mount -t tmpfs tmpfs /var/lib/openhab2/log
Modify /usr/lib/systemd/system/openhab2.service:
[Unit]
Description=openHAB 2 - empowering the smart home
Documentation=http://docs.openhab.org
Documentation=https://community.openhab.org
Wants=network-online.target
After=network-online.target
[Service]
EnvironmentFile=/etc/default/openhab2
User=openhab
Group=openhab
WorkingDirectory=/usr/share/openhab2
PermissionsStartOnly=true
ExecStartPre=/usr/share/openhab2/start_pre.sh
ExecStop=/usr/share/openhab2/runtime/bin/stop
# Shutdown delay in seconds, before process is tried to be killed with KILL (if configured)
TimeoutStopSec=120
Restart=on-failure
[Install]
WantedBy=multi-user.target
(Note: The PermissionsStartOnly=true is important as the start_pre script needs to run as root).
You still need to run the commands on initial setup:
but don’t need the mount commands as they are taken care of in start_pre.sh each run.
Hi Matthew,
I tried your steps on a clean emonSD image (the latest nov16 release) and removed OH1.8 before installing OH2 (stable branch) and OH2-addons.
pi@emonpi(ro):~$ rpi-rw
pi@emonpi(rw):~$ sudo systemctl status openhab2.service
Active: failed (Result: start-limit) since Mon 2017-02-27 11:42:22 UTC; 3min 28s ago
Process: 1432 ExecStartPre=/usr/share/openhab2/start_pre.sh (code=exited, status=203/EXEC)
Feb 27 11:42:22 emonpi systemd[1]: Failed to start openHAB 2 - empowering the smart home.
Feb 27 11:42:22 emonpi systemd[1]: Unit openhab2.service entered failed state.
Feb 27 11:42:22 emonpi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Feb 27 11:42:22 emonpi systemd[1]: Stopping openHAB 2 - empowering the smart home...
Feb 27 11:42:22 emonpi systemd[1]: Starting openHAB 2 - empowering the smart home...
Feb 27 11:42:22 emonpi systemd[1]: openhab2.service start request repeated too quickly, refusing to start.
Active: failed (Result: start-limit) since Mon 2017-02-27 11:42:22 UTC; 3min 48s ago
pi@emonpi(rw):~$ sudo systemctl stop openhab2.service
Active: failed (Result: start-limit) since Mon 2017-02-27 11:42:22 UTC; 4min 1s ago
Feb 27 11:46:22 emonpi systemd[1]: Stopped openHAB 2 - empowering the smart home.
Active: failed (Result: start-limit) since Mon 2017-02-27 11:42:22 UTC; 4min 4s ago
I’m also struggling with the same issue. I think it could be that OH2 requires some contents in /var/lib/openhab2. I need to look into this further.
mattwire
(Matthew Wire)
27 February 2017 16:12
20
What is the content of your /usr/lib/systemd/system/openhab2.service and /usr/share/openhab2/start_pre.sh files?
It’s the start_pre.sh script that’s failing according to those logs which means openhab won’t try and start. Make sure PermissionsStartOnly=true is set in openhab2.service as the start_pre.sh script must run as root. Check that the start_pre.sh script will run by itself.
