How to publish data into heatpumpmonitor.org
Hi
I have a local version of emonCMS running, and i would like to share the data by creating an account on heatpumpmonitor.org, but it is a bit unclear for me, what is required to do so.
Credits are required, pr. feed, pr year - how many feeds are required pr. heatpump?
Morten
@TrystanLea will be able to help you out with an account.
Hi Tim - i think i have an account(ekallesoee) - i just dont know what to do with it :slight_smile:
Hello @MortenKK I’ve made your account a free account. On your local emoncms do you have the sync module? is it an emonPi? if you do then you can setup the sync module to upload the feeds you want to your account ekallesoee at regular intervals. Then the second step is to setup entry on HeatpumpMonitor which I can help you with once you get the data up on emoncms.org
Hi Trystan - its running on a Debian installation, the sync model is not starting up, and i have to do some debugging on why that is.
emoncms_sync service is not running, please start the service to enable feed syncing. - but there is no obvious log to go for, i’ll send some more time on it.
Is it OK to run an older version? (11.7.4) and still sync? (i did try to update earlier, but it said it was the latest, even though i see 11.9.7 released)
You may find some useful tips in this topic: Emoncms_sync does not start :-(
Thanks Tim - it was the /lib/systemd/system/emoncms_sync.service file that wanted a user “pi” - which i dont have in my system :slight_smile:
@TrystanLea i have manged to get the sync working
